Wiring in aftermarket subwoofer, with stock radio? - JeepForum.com
post #1 of 7 Old 10-03-2013, 06:43 PM Thread Starter
MoonyJohn
Is it possible to install an aftermarket subwoofer with a stock head unit? I have the Sahara with the factory subwoofer and want a little more push without upgrading the whole system for an arm and a leg.
I have a buddy of mine selling his 2 Alpine type R's 10" subs in an enclosure for a good price so thats why Im wondering. I tried looking for another thread on it but never found anything.
Thanks
MoonyJohn is offline
post #2 of 7 Old 10-03-2013, 07:32 PM
TheBoss
I highly doubt the factory amp would have enough power to push those efficiently. You would need to run an additional amp possibly using a line converter between the sub woofer amp and signal from the factory amp. I think Mol had a signal processor hooked up to his somehow, forgot what brand though.
TheBoss is offline
post #3 of 7 Old 10-03-2013, 07:36 PM Thread Starter
MoonyJohn
Ok so its possible atleast? I would definitely get an aftermarket amp.. Nothing fancy I dont think. Snowboarding season is coming up and need some tunes for all the road trips!
Is this something that say, cartoys could do for me without them telling me something I need when I really dont. What would you recommend overall? Save up for an aftermarket radio and do it all? I like the stock radio so Id like to keep it stock for now atleast.
post #4 of 7 Old 10-04-2013, 03:22 AM
TheBoss
With a sound processor and a higher wattage 5 channel amp you could drive all the speakers . It's alot of work and rewiring , but this would give you better overall control and sound while still using the factory head unit. They may be able to take the signal wires coming into the factory amp and use it to supply a mono sub amp. I don't know for sure the wiring for the amp if it is indeed possible or how great it would sound.
On my WJ with the factory Infinity system I was able to splice the incoming rear signal wires to an amp powering one MTX 10" sub. I am also using an aftermarket head unit ,though not neccesary gives a lot better control in overall sound. As you are aware access to that amp and wiring doesn't require a chiropractic visit unlike the JK.
TheBoss is offline
post #5 of 7 Old 10-04-2013, 08:25 AM
rangerr47
2012 KK Liberty
I just added new door speakers and a sub to my Liberty..If you want to keep the stock headunit, you have to get a PAC module. Very easy, you just pop the headunit out and plug this module in, now you will have RCA plugs to use an amp.
rangerr47 is offline
post #6 of 7 Old 10-04-2013, 08:29 AM
efm-7
Using an amp with speaker-level inputs makes adding a sub super simple.
For my 2-door jk, I just mounted the amp under a seat and tapped into the wires at the bottom of the rollbar.
2017 JKU Big Bear
efm-7 is offline
post #7 of 7 Old 10-04-2013, 09:41 AM
Psycho-X-Jeep
2009 JK Wrangler
Definitely easy to do. Any shop, or person with installation experience should be able to help you out. But if you are planning on running 2 10" type R's you will want to upgrade your other speakers as well. You will completely drown out the stock speakers running off of a factory head unit without an amp.
Call me Eddo
09 JKUR
13 WK2 Trailhawk
Psycho-X-Jeep is offline
