winterizing the jeep??? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > winterizing the jeep???
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineXJ guys, clock your transfer case!Super Low Prices on TJ Bumpers and $399.95 Tire Carriers!
Unread 11-19-2010, 04:28 AM   #1
monkers
2010 JK Wrangler
Im planning to park my Jeep for the winter to avoid the salt eating it up, what should I do to it for the winter? I will go out and start it weekly and let it warm up, I cant block it up to take weight off the suspension because I will have to pull it in and out of the garage to do other work. Should I put Stabil in the gas?
monkers is offline   Reply With Quote
Unread 11-19-2010, 05:13 AM   #2
jsebastian
2010 JK Wrangler
I say drive it and just wash it once a week, making sure to get the undercarriage. Should keep the corrosion in check.
John
http://www.fuelly.com/driver/jsebastian/wrangler
jsebastian is offline   Reply With Quote
Unread 11-19-2010, 05:51 AM   #3
vanwrangler
Exactly - wash once/week - ESPECIALLY thorough flush of undercarriage, whether it is an auto car wash or do it yourself high pressure. That takes care of corrosion on modern cars, even here in central, VERY snowy & salty NY.
vanwrangler is offline   Reply With Quote
Unread 11-19-2010, 06:10 AM   #4
RAZORBILL
At the very least I would take it out on dry days. That way you don't need to worry about stabil in the gas.
"Do not burn yourselves out. Be as I am --- a relunctant enthusiast . . . a part-time crusader, a half-hearted fanatic. Save the other half for yourselves and your lives for pleasure and adventure. It is not enough to fight for the land; it is even more important to enjoy it. While you can. While it's still here. So get out there and hunt and fish and mess around with your friends, ramble out yonder and explore the forests, encounter the grizz, climb the mountains, bag the peaks, run the rivers, breath deep of that yet sweet and lucid air, sit quietly for a while and contemplate the precious stillness, that lovely mysterious and awesome space. Enjoy yourselves, keep your brain in your head and your head firmly attached to the body, the body active and alive, and I promise you this one sweet victory over our enemies, over those desk-bound people with their hearts in a safe deposit box and their eyes hypnotized by desk calculators. I promise you this: you will out live the bastards."
-Edward Abbey
Currently Jeepless...
Previously owned: 80 CJ-5, 97 TJ, 99 XJ, 95 YJ 10 JK Rubicon Unlimited
RAZORBILL is offline   Reply With Quote
Unread 11-19-2010, 06:32 AM   #5
mandalayjim
Send it to me here in AZ and I'll excerize it on the trails. Oh, I also wash it once a week.
Seriously, I've had/have cars that are stored for winter months and never started that are just fine. Unless you drive it for 10 to 20 miles in cold weather to warm everything up you will do more damage. The biggest problem is to keep the battery maintained. That's my story and I'm sticking to it!
mandalayjim is offline   Reply With Quote
Unread 11-19-2010, 06:43 AM   #6
jeepmom5
Rust treatment?
Hey guys,
Just got a '89 wrangler lifted and all...but the frame down under is very rusted.....solid but RUSTED! I was thinking about using the Nautical gel to clear it up than the Marine wash followed by Rust ready solution and coat it with POR15. Any thoughts?..and can I do the same thing on the rusted spots on the body and hood before having it painted?
ps: Por15 is EXPENSIVE!
Thanks for your inputs.
jeepmom5 is offline   Reply With Quote
Unread 11-19-2010, 07:05 AM   #7
JK-Ford
If your dead set on storing it then:
Test antifreeze for cold weather protection. If you have to add any, start the engine and let it circulate
Add Stabil to the gas. Start engine and circulate through the system.
Buy a battery tender.
Buy a cover.
Tuck her in and kiss her goodnight.
Happy wheeling. Uh - next year.
The Green Monster
2007 JK-XS 2-door Jeep Green
130w KC 6" Long Range on Smittybuilt brackets
130w KC 6" Driving Beams on Grab Bar Mod
Rock light mod
Reverse light mod
JK-Ford is offline   Reply With Quote
Unread 11-19-2010, 07:07 AM   #8
JeffinWesternWA
2010 JK Wrangler
Don't start it weekly,!! if you could start it and drive it a bit- at least back and forth, AND letting it run at various RPM's (not just idle) for an hour~ once a month, that's be great to stir ALL the fluids and move the suspension. Starting weekly willl just add condensation and sludge formation. I've stored many classics over the years, ....so
start with : a COMPLETE cleaning, in/out/under/between with a nice wax finish. Treat teh soft top. (Over detail it). Clean and "full" fluids, espcially oil. Fill the tires (all 5) to MAX pressures. Put the Jeep "away" only after running about an hour (hot enough to burn off condensation). A sheet over the engine (after it's cooled). Park on a "mat" of something covering concrete/tar/wood to lesson moisture coming UP from the ground. Turn all electrical switches "off" but leave inside vents or windows very slightly craked. REMOVE the battery and store in moderate temp (not on concrete) with a trickle charger or charge at a low amperage monthly. COVER the Jeep (Goodwilll sells sheets for about $1~, great for inside/engine, over top/body) or use a BREATHABLE car cover. If you could, jacking up the Jeep (cheap jackstands work fine) and storing on jackstands helps (for cleaning, flat spots and suspension relief). Add a bottle of Stabil to a full tank of gas before the last hour~ run before storing. Synthetic fluids/oil don't moisture and are preferred. Stuff some newspaper into the exhaust pipe tip and duct tape over (keeps mice/moisture outa the exhaust - don't forget when starting . Diddo the air intake under the hood! Check fluids monthly and tire pressures too. In spring:recehck all, THEN start, warm up slightly, drive gently for an hour+, recheck all and run the gas tank low and refill, do it again. You can do this with any vehicle year after year and be sure of maintaining it's value and mechanical reliability.
JeffinWesternWA
JeffinWesternWA is offline   Reply With Quote
Unread 11-19-2010, 07:08 AM   #9
JeffinWesternWA
2010 JK Wrangler
Of course having a JEEP for winter is part of the reason to own one I thought? Otherwise, I'd go back to a nice comfy coupe!
JeffinWesternWA
Unread 11-19-2010, 08:14 AM   #10
montero1
2010 JK Wrangler
Hmm
Wow, storing a Jeep for the Winter....but to each their own.
Stabil for the gas.
Don't start it unless you're going to drive it.
You can get by without a cover if you wax/paint seal it good.
Battery tender is a must.
montero1 is offline   Reply With Quote
Unread 11-19-2010, 08:31 AM   #11
paul84043
SO this is the second thread in a month I've seen on Jeep corrosion, is it really that much more of a problem than any other modern vehicle? I haven't worried about rust on a vehicle in 20+ years???
paul84043 is offline   Reply With Quote
Unread 11-19-2010, 08:53 AM   #12
tavic
2010 JK Wrangler
Actually depends on where you are at in the US. From what I've been told the North Eastern states use more powerful salts.
tavic is offline   Reply With Quote
Unread 11-19-2010, 09:44 AM   #13
paul84043
We put TONS of salt down here in Utah and lately they have been spraying a mixture of Brine from the Great Salt Lick and Mazola cooking oil (well, is seems like it). So, I'm not exactly not exposed to it...just wondering, I haven't had a vehicle rust on me since my last 1976 Toyota Celica. Out last truck sat outside for 10 years with no problem.
Unread 11-19-2010, 10:50 AM   #14
MacK
2010 JK Wrangler
Winter is what the Jeep waits for, why winterize it?
I don't want your d**n lemons! What the hell are these?! Demand to see life's manager! Make life rue the day it thought it could give Cave Johnson lemons! Do you know who I am? I'm the man who's gonna burn your house down! WITH THE LEMONS! I'm gonna get my engineers to invent a combustible lemon that BURNS YOUR HOUSE DOWN!
Mango Tango 2010 JK Wrangler Rubicon
Silver 2000 TJ Wrangler Sport
The 2008 Jeep Wrangler is not so much an SUV as it is an experience. It's slow and loud, handles poorly, has crummy interior materials and features doors that provide virtually no crash protection. But when it comes to off-road performance, the Wrangler is simply the best choice available.
MacK is offline   Reply With Quote
Unread 11-19-2010, 11:38 AM   #15
Ravik
2010 JK Wrangler
Colorado used to be famous for the bright orange multi-lane plows and caravans of snow removal and sanding equipment running around, and between that and the dry climate, cars lasted forever.
But these days they just spray that car-eating goop (magnesium chloride) on the road and hope. And the first thing the magchloride eats is your ball joints.
CDoT actually puts up billboards in the winter advising folks to thoroughly wash the underside of the car as soon as possible after a snow.
Great excuse to buy a hotsy
2010 2dr Rubicon
Ravik is offline   Reply With Quote
