Quantcast Windshield torx bolts torque specs? I have a bad Light bar vibration. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Windshield torx bolts torque specs? I have a bad Light bar vibration.
Old 10-11-2009, 09:01 AM   #1
SigMtnMan
2011 JK Wrangler
Anyone know the torque specs for the 6 bolts on either side of the body/windshield?
I am getting a violent harmonic vibration at 55-60ish from the light bar portion of my gobi rack.
SigMtnMan is offline   Reply With Quote
Old 10-11-2009, 03:10 PM   #2
Sgalway
I don't think the bolts being tighter will help. You are seeing one of two things: Vortex induced vibration (VIV), or your tires are out of balance just a little bit and you are seeing a harmonic vibration in the rack.
Balancing = You probably can't feel it, but when you hit the sweet spot the rack sure does.
VIV = It's a common problem and easy to fix. Take some small diameter rope or string, and wrap it around the tubes similar to the wraps that are on your radio antennea. You want good spacing between the wraps. This will change the shape of the vortex shedding pattern and keep it from ocsillating.
S Galway -- Sugar Land, TX -- KB5ODA
07JK Sahara 4dr -- 6sp 4.88gears -- ARB Lockers F/R
dual tops -- Kenwood DNX7100 indash nav
Banks Monster exhaust -- K&N 77 CAI -- 3" Black Diamond Lift
17" Pro Comp Extremes with 35" BFG A/T's
AEV front bumper w/ Warn Powerplant -- Custom safari roof rack
Sgalway is offline   Reply With Quote
Old 10-11-2009, 04:01 PM   #3
1222
Make mine a Jeep!
1222's Avatar
Hu? Is that true (VIV)? I’ve never heard of something like that, but I’m always wanting to learn more.
1222 is offline   Reply With Quote
Old 10-11-2009, 05:45 PM   #4
Sgalway
Sounds crazy, but believe it...
Vortex-induced vibration - Wikipedia, the free encyclopedia
Look at your radio antenna, there is a winding of thicker material going the length of the wire. The strakes help to reduce the vibration, thus reducing the humming that can come from un-straked antennae.
What is happening is that a low pressure von Karmen vortex street is being formed behind the tubular which is ocsillating from side to side. The ocsillating low pressure is inducing drag on the tubular thus causing the vibration.
This video (although not exactly round) illustrates how the vortex vibration sets up. This computer simulation was part of a job I did a few weeks ago. It is part of a submerged leg of an offshore oil platform.
[YT]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/VN64We4b2yg&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/VN64We4b2yg&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/YT]
Old 10-11-2009, 05:54 PM   #5
1222
Make mine a Jeep!
1222's Avatar
Do you work at area 51? Thanks.
Old 10-11-2009, 06:04 PM   #6
alaskanthunder
Yeah, I learned about that when riggin' up the straps to roof top carriers. Put a little twist in the tie down straps and you won't get any wind vibration at high speeds. The wind funnels through the twists reducing the vibration.
2007 JK 2-dr X | Steel Blue | 4.10 Auto D44
alaskanthunder is offline   Reply With Quote
Old 10-11-2009, 07:39 PM   #7
1222
Make mine a Jeep!
1222's Avatar
Damm, thanks for that tip. If I ever run into a situation like that I’ll remember this and give it a try.
Old 10-12-2009, 10:45 AM   #8
SigMtnMan
2011 JK Wrangler
Thanks for the input. I reckon I will start with getting the tires balanced and go from there.
Glock Forum
