Window zipper - JeepForum.com
post #1 of 16 Old 04-06-2010, 08:06 AM Thread Starter
mandalayjim
Window zipper
Has anyone found a good way to zip and unzip the rear window? I have cleaned the dirt and lubed the zipper but no improvement. The main problemarea is on the curves. TIA
mandalayjim is offline
post #2 of 16 Old 04-06-2010, 08:11 AM
redrockin7
That thing is a big PITA, isn't it?
The mopar lube works fairly well for me, but still far from a bulletproof solution. I sometimes will attach a small carabiner clip to the zipper to get some leverage on it and not scrape up my hands/fingers in between zipper and top.
I think the most important thing is getting it lined up just right before zippering it up; sometimes mine is a major pain, and other times it is as easy as the sides to open (which I have absolutely no problems on the sides)... All depends if I am off a tooth or three in one direction, it seems.
Easy solution - don't put it in from spring - fall. LOL. Just pull drain plug in your rear cargo areas and the storage bin.
redrockin7 is offline
post #3 of 16 Old 04-06-2010, 08:22 AM
sdebol
2010 JK Wrangler
I agree it can be a PITA and, after 3 summers, I still haven't hit on the perfect method. Some have recommended zipping in the back window before zipping in the two sides.
I'm not sure if it really helps or not, but I tend to slide the rear window off-center toward the driver side to start the zipper. After I zip up this side and make it around the driver side upper corner, I then slide the window back toward the passenger side until it's centered before I continue across, around the passenger side upper corner and down. The other key seems to be having some momentum to make it around the two upper corners.
I do feel like the Mopar zipper lube stuff helps some. If you search you'll see recommendations for other products to help lubricate the zipper.
Steve
sdebol is offline
post #4 of 16 Old 04-06-2010, 08:35 AM
nemoek
Only time I've had problems is when mine got caked with dirt/salt. Keep it clean & lubed.
I have noticed that the corners will bind a little if the window is wedged inside or outside the top, especially if it's cold. Pull the corner back to the right position & it's fine.
'96 XJ Sport - SOLD
'07 JK Unlimited - Stock, for now
'77 CJ5 - Project
Originally Posted by Rik84 View Post
If someone mails me a letter about why my newish to me Jeep sucks I will personally poop in a paperbag and mail it back to them.
nemoek is offline
post #5 of 16 Old 04-06-2010, 08:39 AM
redrockin7
Also pull down on rear-most bow to alleviate some tension?
post #6 of 16 Old 04-06-2010, 09:14 AM
1398653
2017 JK Wrangler
I zip up the rear window with two hands. My right hand pulls the cord and my left gently pushed from the rear of the zipper. Makes it go a lot faster and prevents the zipper from shifting up of down making it harder to zip close. I also use mopar zipper lube and cleaner. This stuff works good.
Steve, Allegany NY, 2017 JK Unlimited Rubicon
1398653 is offline
post #7 of 16 Old 04-06-2010, 09:16 AM
redrockin7
Have done the two handed technique (push and pull) when the going gets tough also...
post #8 of 16 Old 04-06-2010, 09:52 AM
tennistom1
2009 JK Wrangler
Mine's screwed up too. The teeth don't mesh correctly at the top curves. Maybe the guy in China who made it was having a bad day. I've seen on Jeep forums that people were getting replacements under warranty. I would try that but I've got no dealerships within 60 miles of me since the three closest were shut down in the interest of "job creation".
I haven't dealt with it but now that the good weather is here, I'll look into it. I'll probably take a road-trip and stop at Jeep dealers until I can find one that will replace it under warranty. My TJ has no such problem, it's a quality control issue.
2009 JK Rubicon 4-Door
2006 TJ Rubicon Unlimited
tennistom1 is offline
post #9 of 16 Old 04-06-2010, 10:03 AM
Jordon83
2009 JK Wrangler
I pull what would be the C-pillar (don't remember what Jeep calls this) in to make the window opening smaller. I install the rear before the sides. Seems to zip alot easier this way. I managed to tear up the zipper on a previous top and had to have the dealer warantee out both the window and the top. Since I have started to pull the sides in (after they are attached to the body) I have not had a problem.
Jordon83 is offline
post #10 of 16 Old 04-06-2010, 10:33 AM Thread Starter
mandalayjim
Hey, Thanks for all the suggestions. So, if put on a caribier, push and pull with both hands and with my third hand :<) pull down on the bows it should work great.
I think I'll try the caribier idea.
post #11 of 16 Old 04-06-2010, 10:42 AM
stockrubi
There are a few tricks to it. First make sure the 2 clamps on the channel up front are not locked all the way down. Just place them on the loop. Second zip the back windows up before the sides. The top will also soften in the sun so warm it up a little.
It is more a finesse thing. I find it to be fairly easy, yanking on the zipper does not work.
08 Flame Red Rubi, first Jeep and loving every minute!
stockrubi is offline
post #12 of 16 Old 04-07-2010, 10:40 AM Thread Starter
mandalayjim
Okay, I tried the caribier metheod. I like it but not perfect!
post #13 of 16 Old 04-17-2010, 09:03 PM
texasflusher
2010 JK Wrangler
The back window removal is such a pain for us the we now just leave it on when we lower the soft top. The soft top seems to still fold down just fine.
texasflusher is offline
post #14 of 16 Old 04-17-2010, 09:09 PM
GEM1N1
I only zip up the sides of the rear window and don't "round the curve" if you will. I then roll it up and wrap the factory elastic bands around it to hold it up. At that point you can lower your top with no damage (creasing/cracking) to your rear window. When you raise the top back up you only have to zip the sides straight down (no corners). Works like a champ!
2008 2dr Black Rubicon Automatic.
2.5" Rough Country BB
295/70/17 Nitto Trail Grapplers
GEM1N1 is offline
post #15 of 16 Old 04-17-2010, 09:46 PM
BigRed09
2009 JK Wrangler
Steve
x2.
this worked for me like a charm the last time i put the window back in. it helps keep the gaps between the one set of teeth on the top and the teeth on the window closer together for easier zippering.
BigRed09 is offline
Back Window Zipper jj88jeepdog TJ Wrangler Technical Forum 24 11-01-2011 07:45 PM
Back window zipper LUCHIAN78 TJ Wrangler Technical Forum 2 03-10-2009 10:35 AM
window zipper help!! 76silvercj5 JK Wrangler Technical Forum 7 03-08-2009 04:21 PM
window zipper pigglywiggly TJ Wrangler Technical Forum 7 09-23-2006 01:21 PM
Rear window zipper? jblfitness TJ Wrangler Technical Forum 8 08-03-2006 12:42 PM
