Window switch lights - JeepForum.com
post #1 of 18 Old 12-01-2012, 02:05 PM Thread Starter
waterboarder
waterboarder's Avatar
So, last night, I noticed that the illumination dots on 3 of the 4 power window switches were not working. Does anyone know if this is going to be a little bulb issue, a fuse problem, or something else?
Vehicle is under (extended) warranty, I'm wondering if something like this is going to be covered. I'm not looking forward to trying to fix that myself.
2007 Sahara.
waterboarder is offline
post #2 of 18 Old 12-01-2012, 03:16 PM
CooterTKE
2010 JK Wrangler
Mine have been out for a while. I have yet to see what the issue is.
CooterTKE is offline
post #3 of 18 Old 12-01-2012, 03:25 PM
JIMBOX
They aren't much for LUMEN output anyway, so just learn the switch location by "BRAILE" and no problemo !
I never even look to operate my windows !
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #4 of 18 Old 12-01-2012, 03:26 PM
BigNunz6
2015 WK
On my 08 and the 11 they worked for a bit and both eventuality went dark.
If you like it, buy it!!!!
BigNunz6 is offline
post #5 of 18 Old 12-01-2012, 03:56 PM
1222
RIP John
1222's Avatar
The two rear ones (front dash) on my 08 never worked from the day I bought it (new).
(2011-2016)
1222 is offline
post #6 of 18 Old 12-02-2012, 07:46 AM
rirrgang
The rear switches on my 07 were never lit and there's no opening for the bulb.
-Rick
07 Sahara Unlimited
rirrgang is offline
post #7 of 18 Old 12-02-2012, 07:51 AM
eastcoastcam
What does it matter as long as the windows go up and down when you push on the switch?
eastcoastcam is offline
post #8 of 18 Old 12-02-2012, 08:39 AM
rirrgang
It doesn't unless you want the switches lit.
-Rick
07 Sahara Unlimited
rirrgang is offline
post #9 of 18 Old 12-02-2012, 10:17 AM
ncb
On my 2009 unlimited only the top two switches under the stereo have lights. The two on the back of the center console don't have lights.
ncb is offline
post #10 of 18 Old 12-02-2012, 01:31 PM
Coolcatracing
There are small bulbs inside the switch, I doubt you can buy them anywhere though. You'll have to replace the switch itself to fix the bulb issue.
08 Unlimited Rubicon 6 speed, 315/70-16 Kelly TSR, 1.5" Spidertrax spacers factory Moab's, Rubicon Express Flex arm 3.5" lift, Smittybilt XRC front bumper with D-rings, Body Armor Extreme rock slider steps, AEV snorkel, trimmed fender flares, Hella 8" HID driving lights
Coolcatracing is offline
post #11 of 18 Old 12-02-2012, 03:38 PM Thread Starter
waterboarder
So, that would point toward a warranty issue.
Thanks for the info (:
post #12 of 18 Old 12-02-2012, 03:41 PM
bluegrassguitar
2011 WK
I think only the top 2 are lit, at least it's been that way on mine since it was new.
bluegrassguitar is offline
post #13 of 18 Old 12-02-2012, 04:04 PM
Coolcatracing
Possibly but I wouldn't personally consider a bulb burning out as a warranty defect over 5 years later. Did you get them to warranty your headlights or brake lights when they burned out, or replace your brake pads, or change the oil for you under warranty? Stuff wears out, that's not a warranty issue
post #14 of 18 Old 12-02-2012, 07:18 PM Thread Starter
waterboarder
Possibly but I wouldn't personally consider a bulb burning out as a warranty defect over 5 years later....
I would, if it is integrated into the switch and you can't simple replace a bulb.
post #15 of 18 Old 10-21-2013, 10:53 PM
skates04
skates04's Avatar
Came across this looking for info for a solution
http://wayalife.com/showthread.php?4...indow-Switches
skates04 is offline
