Window Cleaner For A Soft Top JK - JeepForum.com
post #1 of 10 Old 07-07-2013, 05:39 PM Thread Starter
killaquel
So from the forums and reading the manual I've learned not to take my car through the car wash unless it's "touch less" my question is ... what is the best way to clean the plastic windows ? and what is the best cleaner to use on the windows ?
killaquel is offline
post #2 of 10 Old 07-07-2013, 06:13 PM
jmb6420
Engr. & Mechanic 08 Rubi
jmb6420's Avatar
You can use Bestop Window Cleaner or any other quality plastic cleaner. I've used Mequiars for years and it works great..
Mike
08 Rubicon
"You can't fix stupid" Ron White
ɹǝʌo ǝɯ dıןɟ 'sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
jmb6420 is offline
post #3 of 10 Old 07-07-2013, 08:29 PM
Wavedatya
2010 JK Wrangler
Ragtopp vinyl top care kit. Has cleaner and protectant. Works great and has lasted long!
OF4WD member #7523. Durham 4x4 member.
Wavedatya is offline
post #4 of 10 Old 07-08-2013, 03:56 AM
AveCat
x2. BTW you shouldn't take it thru a car wash at all. The chemicals are bad for the window material. Can turn it yellow and deteriorate it.
2012 Wrangler JK 3.6 W/ 6 Speed bought 2/15/13
2.5" Rock Krawler Lift - Bilstein 5100s - 315/70/17 Duratracs - AEV Control Arms
TruckLite - Rigid
AveCat is offline
post #5 of 10 Old 07-08-2013, 05:47 AM
JWA
I love Plexus for the soft top windows: http://www.amazon.com/Vega-Plexus-Sp...eywords=plexus. A lot of HArley dealers carry it, and some boat shops.
JWA is offline
post #6 of 10 Old 07-08-2013, 07:07 AM
pismo61
pismo61's Avatar
2015 JK Wrangler
I use Plexus also.Works great
2015 Red 2 Door(half) 6sp.
pismo61 is offline
post #7 of 10 Old 07-08-2013, 09:02 AM
RogueStatus
i used Scratch-X on mine when I had a soft top.. worked real well and kept them looking brand new
Jeep-less again
RogueStatus is offline
post #8 of 10 Old 07-08-2013, 12:28 PM
Piker73
I take mine through Mr. Cash Wash all the time. No problems here.
Piker73 is offline
post #9 of 10 Old 07-08-2013, 01:22 PM
sleepjeep
You should avoid window cleaners with alcohol and ammonia in them. You can use a mild dishwasihing soap on them but make sure you use a clean terry cloth or microfiber cloth and change the cloth often. Then you should use a protectant after the cleaning. I use 303 protectant but others have there favorite protectant. Bestop the company that makes the OEM has a cleaning kit you can buy that comes with a cleaner for the top and windows, a protectant for the top and windows and a zipper cleaner and lubricant. Hope that helps. Remember that the plastic windows scratch fairly easily so try to rinse off major debris first. Scratches require a whole different product to remove if at all.
sleepjeep is offline
post #10 of 10 Old 07-08-2013, 04:53 PM Thread Starter
killaquel
Thank you all! it is much appreciated I will definitely be looking into all of these but atleast I know where to start!
