Winch wire route - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Winch wire route
Paracord grab handles, door limiting, etc at JeepHut.comRough Country Deals at JeepHut.comNew! JK/U skid plate system.
Unread 05-12-2014, 01:22 PM   #1
Airborne Lee
Winch wire route
What is the best wire route for my new Quadratec 9500si winch? All routes leave the back wire lead short 10 inches.
please buy this NEW IN BOX:JK Rugged Ridge Light Bar
2013 JK Rubicon, Commando Green, CB, GPS, KC lites
KC Jeep Club Info - M416 Trailer Project
3 Previous Jeeps - 01 WJ Ltd, QD & UC - 01 WJ Ltd, QT II - 98 XJ Ltd
Airborne Lee is offline   Reply With Quote Quick reply to this message
Unread 05-12-2014, 02:12 PM   #2
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Not sure about 2013, but in my 08 I ran them through the grill, up by the air intake, and then along the passenger side of the engine compartment to the battery.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline   Reply With Quote Quick reply to this message
Unread 05-12-2014, 02:22 PM   #3
Airborne Lee
tried that. they are a foot short. the only way i could get them to reach is straight up beside the radiator over the air filter box between the engine and the fuse box.
Unread 05-12-2014, 03:50 PM   #4
MyJKU14
2014 JK Wrangler
That's weird. I would call them up maybe and see which way they recommend routing it?
'14 JKU
'05 LJ Rubicon (husband's)
Colorado Jeep Club #281
Past Jeeps: '02 WJ Overland, '02 WJ Limited, '08 KK Sport
MyJKU14 is offline   Reply With Quote Quick reply to this message
Unread 05-12-2014, 06:06 PM   #5
TheBoss
Use a quick disconnect in line with the battery. Buy a couple of feet of pos and neg cable and you will be good to go. This way there will be no accidental draw or unintended misuse of the winch. I routed mine as rocky clymer did and added an abrasion guard sleeve like they use on hydraulic lines to eliminate any risk of shorting out the wires.
TheBoss is offline   Reply With Quote Quick reply to this message
Unread 05-12-2014, 06:48 PM   #6
CJ7nvrstk
This, and I even had extra cable but my winch is an Engo.
RED Friday. Remember Everyone Deployed
CJ7nvrstk is offline   Reply With Quote Quick reply to this message
Unread 05-12-2014, 06:52 PM   #7
SubAtomicGenius
2011 JK Wrangler
I upgraded the cables to #1 welding wire, copper lugs, quick disconnects, and fused positive. Better for hard pulls. Interesting, but stock winch cables dont meet electrical codes for their amperage draw... Suppose it is rated for intermittent duty...
SubAtomicGenius is offline   Reply With Quote Quick reply to this message
Unread 05-13-2014, 09:51 AM   #8
Airborne Lee
Great idea, can't believe i didn't think of that. any links for disconnects? Did you do both pos and neg? or just one, which one?
I thought about changing the battery terminals also but the factory is crimped and there is an extra post that I am using. thoughts?
Unread 05-13-2014, 10:12 AM   #9
Airborne Lee
what do you guys think of this:
Fuse:
http://www.amazon.com/Scoshe-EWFH-Si...productDetails
Disco:
http://www.wirthco.com/rotary-dial-d...-switches.html
Disco:
http://www.amazon.com/Volt-Battery-D.../dp/B007O0BBFM
Unread 05-13-2014, 01:11 PM   #10
PhatBasturd
Got chiggers?
PhatBasturd's Avatar
1976 CJ7
I went the same route as SubAtomic using 2/0 welding wire.
Pics are examples of what I used:
TemCo 2/0 welding wire (eBay):
Anderson 350 AMP quick disconnects:
VTE Warehouse Hi amp ANL fuse holder with cover:
VTE Warehouse 400a ANL fuse:
In the process of replacing/re-wiring battery terminals with this type of "military" terminal (delcity.net):
military-battery-terminal-google-search-internet-explorer_2014-05-13_13-59-41.jpg military-battery-terminal-google-search-internet-explorer_2014-05-13_14-01-13.jpg
PhatBasturd is offline   Reply With Quote Quick reply to this message
Unread 05-13-2014, 01:58 PM   #11
Anticanman
The Thunder Chunky
Anticanman's Avatar
Attachment 1336921
Attachment 1336689
Attachment 1336713 Attachment 1336721
Attachment 1336777
Attachment 1336889 Attachment 1336897
That's what I'm doing with mine (though my yj battery is easier to access). I used these battery terminals and instead of just a single quick connect, add jumper cables to the second connector and mount it on the bumper. A pic of my marine terminals
Luck Favours The Prepared
Originally Posted by rambo3489 View Post
Listen to what the canman says. You don't have to take it all word for word. But at least listen to the man. He knows his ****. Its a no BS straight to the point realistic approach to things. You may not like it. But someday you might have an Anticanman moment. Like you just had. I know I have. Hell I had 2 last week.
Anticanman is offline   Reply With Quote Quick reply to this message
Unread 05-13-2014, 03:37 PM   #12
RockyClymer
RedRock4Wheeler
I used the Anderson 350 amp disconnect also so that there was no "accident" and also placed the positive lead in one of the plastic wire looms for some extra abrasion resistance. So far, no problem. Even though the APP is rated at 350 amps, the know that at max draw the M8000 is close to 400 amps, but usually intermittent.
NRA Life member
