Quantcast Winch Kit Items - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Winch Kit Items
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-TJ 5.25" Speaker Adapters - NalinMFGFree Shipping on TIRES at KrawlOff-Road
Old 01-16-2008, 10:43 AM   #1
tx-Skydiver
1979 CJ5
Winch Kit Items
What are some if the items in a winch kit used for?
Snatch Block???
Drag Chain???
Has anyone found one at a good price that is not worthless? I probably just need a Tree strap and tow strap.
[B]Current Jeep:[/B]
2007 JK Wrangler Unlimited (Black), 4" SuperliftRanchoExpress Lift, 36" Super Swamper Irok's covering 16" ProComp's, AFE CAI, FlowMaster 40 Series, Shrockworks Rock Sliders, Rock Hard line of undercarriage skids, Warn Powerplant, Shrockworks Mid-width front bumper, Dana 44 Front
tx-Skydiver is offline   Reply With Quote
Old 01-16-2008, 10:52 AM   #2
PeteC
The snatch block will almost double your winch capacity. Basically it is used as a pully. Attach it to a tree saver and then run the winch rope through it and back to your Jeep.
Theoretically, with enough line and snatch blocks/pullies you can get your Jeep unstuck by hand.
As far as the drag chain, well I would imagine I would only use that to tow on a relativily flat surface. I am not a fan of chains during recovery efforts.
'00 TJ With toys, lift and tires.
'10 Dodge Ram 1500 Quad 4x4. Daily driver and tow rig
'05 Dodge Neon. Wifes daily driver and gas sipper.
There is no Bandaid for Stupidity
Sorry if my support of legal wheeling offends you
PeteC is offline   Reply With Quote
Old 01-16-2008, 10:59 AM   #3
ge2
Gold Member
ge2's Avatar
I'm a complete noob to anything offroad, so I have spent a good deal of time looking for videos and such explaining equipment. I found this one to be pretty good about snatch blocks.
http://youtube.com/watch?v=nOXUtJptDlM
ge2 is offline   Reply With Quote
Old 01-16-2008, 11:53 AM   #4
tx-Skydiver
1979 CJ5
Good info. Thanks guys.
Old 05-25-2009, 10:22 PM   #5
labbeJ92
1994 XJ Cherokee
whats a good lb capacity that i should be looking for ex 2000 lbs 9000 lbs seem to be the most common. if im using snatch blocks and the such can i get away with a lighter winch because they are compensating for pulling capaicity or should i just do it the right way wait a few more weeks and get a heavier one
thanks
jon
labbeJ92 is offline   Reply With Quote
Old 05-26-2009, 12:25 AM   #6
desertjk
Another use of the snatch block is to allow you to change the direction of the pull. For example, if you are pointed due north and you need to pull someone out that is pointed, say, east, you may be able to attach the snatch block to a tree (via a tree saver) or a rock (via a chain) that is sitting at the intersection of the north and east paths. Then you can run the line through the block from vehicle to vehicle and you'll be able to pull in the desired easterly direction. That might be handy if you were on a trail where you couldn't position your vehicle for the direct pull.
2007 2 door Rubicon. 3.5" RE lift, 35" Goodyear MTRs, Procomp 8179 15x8 wheels, 4.88 Superior gears and alloy shafts. Shrockworks stubby front bumper, Rockhard rear bumper, JE Reel 1350 driveshafts, Warn Powerplant winch, CB, GPS.
desertjk is offline   Reply With Quote
Old 05-26-2009, 02:14 AM   #7
No_Return
thanks
jon
You definitely want at least 8000 lb capacity and 80 - 100 feet of Cable. From what I've seen anything under 8000 lbs is not up to pulling a 4000 lb vehicle out of Stuck so Bad I need a Winch in the first place. The snatch block helps but you can not always count on being able to use it. Also Winches are rated for pull on the first row of line on the winch. So the more line already spooled on the winch the less power it has.. the loss can be upwards of 20 - 30%. So if you are using the first 15 feet on a 100 foot cable then the 85 are on the spool your 8000 is only pulling approximately 5500. If you have a 5000 lb winch and ... well you get the idea.
Ideally you want to have Gloves, Snatch Strap, a Tree Saver, and a decent snatch block and a static tow rope and I'm sure I'm forgetting stuff.
Gloves are not optional for me I always keep a set of decent mechanics gloves in my Jeep. And I don't even have a winch on it yet.
ARB and WINCHLINE.com both have great kits but they can cost as much as a Winch. If you have the $$$ go for it... If you are Just getting started the best thing you can have is good tow hooks on the front and rear of your Jeep and a decent 30' snatch strap. And another friend with a Jeep.
I like ARB Gear but even a cheep 20' snatch strap is better than nothing at all.
Great danger lies in the notion that we can reason with evil. Doug Patton.
No_Return is offline   Reply With Quote
Glock Forum
