Will these tires/rims work on a JK? - JeepForum.com
post #1 of 1 Old 08-28-2012, 02:42 PM Thread Starter
pbuchanan
Does anyone here have experience with going to 14.50" wide tires on a JK Rubicon?
I currently have stock 31x10R17 tires on the stock rims which I believe have 6 1/4" back spacing. I am putting a 3.5 inch lift and want to go with 36x14.50R15 tires and I have found some steel 15" rims that will clear the brake calipers and have 4" back spacing. The new tires should be 2 1/4" wider on each side and the back spacing difference is by the same amount so I'm hoping it will clear.
Does anyone have experience doing this? I want to make sure I am right about this.
(Also does anyone know where I might be able to find 15x10 inch aluminum rims in a 5 on 5 pattern that will clear the JK brakes? I found the steel ones but would love aluminum if there are any out there.)
pbuchanan is offline
back spacing , rim size , rims , tire clearance , tire fitment
will my rims work? crusaderstar TJ Wrangler Technical Forum 6 05-05-2011 08:19 AM
Upgrade stock tires/rims with larger stock tires/rims (08 Wrangler Unlimited)QUESTION makstuss JK Wrangler Technical Forum 3 02-20-2011 05:23 PM
will 8" rims work for 12.50 tires? did I loose my brain?? pwoens YJ Wrangler Technical Forum 15 08-30-2007 01:15 AM
will soft 8 17x8" rims work with 315x70x17 tires? Warlord2 JK Wrangler Technical Forum 16 07-18-2007 08:04 PM
Will 31" tires work with Canyon rims? itchyandscratch TJ Wrangler Technical Forum 8 07-02-2006 09:10 PM
