Will this center axles? - JeepForum.com
post #1 of 11 Old 12-03-2010, 03:58 PM Thread Starter
GunDude
2011 JK Wrangler
I am planing on putting on a OME soon, and was wondering how to center it when I put adj. track bars front and rear.
Was wondering if I hang a plum line off the oil pan, frame, etc. to the axle and mark the axle at that point. Then, when I install the lift, all I would have to do is adj. the mark on the axle back up with the plum line hanging down and should be back at factory center! At least in my mine.
Well, does this sound like it will getr done?
GunDude is offline
post #2 of 11 Old 12-03-2010, 04:03 PM
No_Return
That should do it, If you have a $15 laser level that would to it too. I recommend getting it aligned at a reputable shop post lift. Tires are too darn $$$$ to skip this step in an attempt to save $50-$60.
One does not establish a dictatorship in order to safeguard a revolution; one makes a revolution in order to establish a dictatorship. - Orwell
No_Return is offline
post #3 of 11 Old 12-03-2010, 04:18 PM
JLC08JK
What was I thinking?
JLC08JK's Avatar
Just remember that when you center the axle the Jeep needs to be sitting on the ground with the suspension settled in its rolling form.
I tried to do mine by figuring the track-bar length mathematically then I ended up using my precision eyeball for the final adjustment
Jim
JLC08JK is offline
post #4 of 11 Old 12-03-2010, 04:35 PM
Charles
2017 WK
Plum off the fender.
Charles is offline
post #5 of 11 Old 12-03-2010, 04:43 PM
Imped
Imped's Avatar
That's less precise than using a point on the frame and a consistent point on the axle.
OlllllllO
IndyORV
Imped is offline
post #6 of 11 Old 12-03-2010, 04:47 PM
Charles
2017 WK
Why? Fenders and tires are just as accurate as frame and axle, as long as your tires are the same size and your fenders are equal width. And, in all honesty you can only really get it good enough for government work by the time you get sick of adjusting the track bar a dozen times.
2017 TrailHawk Hemi, Everything but the TV's.
Charles is offline
post #7 of 11 Old 12-03-2010, 05:09 PM
\\WK//
Copied this from another forum...
1. In order to set an adjustable front track bar, you will first need to determine how much your front axle is off by. To do this, firmly hold a carpenters level up against the sidewall of your driver side front tire making sure that it is aligned to the center of the wheel. Make sure that the bubble in the level is centered and then, using a tape measure, measure the distance between it and the edge of your fender flare (or other pre-determined point like the spring perch). If your level is making contact with a shoulder lug on your tire, be sure to make a note of it especially if the lugs are of different sizes or are located at different points along the edge of the tire and would influence your measurement. Repeat the process on the passenger side of your Jeep (again being aware of the shoulder lugs and how they might influence your measurements) and then calculate the difference between the two sides.
\\WK// is offline
post #8 of 11 Old 12-03-2010, 05:36 PM Thread Starter
GunDude
2011 JK Wrangler
I like my ideal better, seems much easier. And then yes, will get it aligned.
GunDude is offline
post #9 of 11 Old 12-03-2010, 06:45 PM
JLC08JK
JLC08JK's Avatar
This is one of those things where close is close enough!
Just remember that no matter how perfectly centered the axles are to start with they will be off center in opposite directions as soon as you add any weight to the vehicle. This could be fuel, passengers, groceries, mud, etc.
If you center with a full tank of gas and a driver and one passenger in the front seat then this will be the only configuration in which it will be centered.
The best you could do would be to center them for the average load that you will be driving with.
Jim
JLC08JK is offline
post #10 of 11 Old 12-04-2010, 11:52 AM
thedirtman
thedirtman's Avatar
For the rear I used a sharpie marker and marked the center of the frame and center of the axle then used a plumb bob to get them lined up. For the front I made a tool to hang a plumb bob from above the engine compartment. Here is a link to the post I did when I built it. I hope it helps.
http://www.jeepforum.com/forum/f96/f...-tool-1114037/
If you learned something new today, you had a good day.
thedirtman is offline
post #11 of 11 Old 12-05-2010, 06:26 AM Thread Starter
GunDude
2011 JK Wrangler
Dirtman, I have not looked yet what I can hang a plum off on the front yet, but that will give me options when I get to that point!
GunDude is offline
Axles off center? Strossy TJ Wrangler Technical Forum 3 06-09-2010 03:08 PM
AXLES off center limejeep TJ Wrangler Technical Forum 9 03-21-2008 07:28 PM
RE 3.5 SF Lift Done...Now My Axles Are Way Off Center. SteelBlueTJ TJ Wrangler Technical Forum 8 08-18-2006 03:05 PM
Off-center Axles... loudog3114 TJ Wrangler Technical Forum 11 03-13-2006 12:06 AM
How did you center your axles when installing Front Adjustable Track Bar blackjeep04 TJ Wrangler Technical Forum 24 07-09-2005 12:20 AM
