Will 36x14.50R15 tires work on my JK? - JeepForum.com
post #1 of 5 Old 08-28-2012, 10:15 PM Thread Starter
pbuchanan
Does anyone here have experience with going to 14.50" wide tires on a JK Rubicon?
I currently have stock 31x10R17 tires on the stock rims which I believe have 6 1/4" back spacing. I am putting a 3.5 inch lift and want to go with 36x14.50R15 tires and I have found some steel 15" rims that will clear the brake calipers and have 4" back spacing. The new tires should be 2 1/4" wider on each side and the back spacing difference is by the same amount so I'm hoping it will clear.
Does anyone have experience doing this? I want to make sure I am right about this.
(Also does anyone know where I might be able to find 15x10 inch aluminum rims in a 5 on 5 pattern that will clear the JK brakes? I found the steel ones but would love aluminum if there are any out there.)
pbuchanan is offline
post #2 of 5 Old 08-28-2012, 10:21 PM
topalmer4
I dont have any experience with the jk but if your running tires that size you need at least some better brakes. Just my .01
Say Goodbye To your Bank Account, Say Hello To Your New Jeep :D
topalmer4 is offline
post #3 of 5 Old 08-28-2012, 10:39 PM
saddis
2014 JK Wrangler
You'll need a lot of BS on those wheels with a tire that wide and only certain 15" wheels fit a JK. There was a thread a few days ago asking for all known 15" wheels by manufacturer that would fit a JK.
Steven
saddis is offline
post #4 of 5 Old 08-28-2012, 10:54 PM
222Doc
222Doc's Avatar
Back space has nothing to do with rim size width in respect to inside fit. Excepting things like calipers. So a 15x8 and 15x10 rim with both at 4" back space have the same inside clear. That extra 2 inches is on the OUT side. so you added 4"inches of width as compared to say a 35x12.5 to your Jeep add the 3 inches of back spacing. so your 7"wider now. Thats more width than most go in hieght.
Why are going 14.5 wide, unless you are running say 40"s. But 36? very hard on the axles bearings C"s ball joints stearing the list grows. MPG is out the door with 14.5 wide. odd choice for sure.
I run 15" on my Jk with 35"s. Steel though. as hard as i am on the rim seem a total waist to put an money in rims
222Doc is online now
post #5 of 5 Old 08-28-2012, 11:04 PM Thread Starter
pbuchanan
Sorry, what I am worried about is will the 14.5 inch tires run on the inside. With 4" back spacing that should push me out 2 1/4 inch out and then the tire will be 2 1/4 inches on each side. Or am I wrong about that calculation?
I want to get as much rubber as I can for bogging around in the mud but if this gets too complicated I may just save money and effort and just do 36x12.50R16s and then I should be fine on 16 x 8 rims with 4.5 inches of back spacing without even cutting it close.
back spacing , rim size , rims , tire choice , tire clearance
This sucks - No 37x12.50R15's? Area.3.Fiftyone YJ Wrangler Technical Forum 32 05-28-2010 05:36 PM
33x12.50r15 tires on stock height YJ? BP88 YJ Wrangler Technical Forum 25 01-25-2010 07:27 PM
33x9.50R15 SOLIDJP44 TJ Wrangler Technical Forum 31 09-24-2008 08:37 PM
Death Wobble----36x14.50-15 elkfan2 TJ Wrangler Technical Forum 4 03-16-2007 10:04 PM
BFG's 33x12.50R15 Owners Viet15philong TJ Wrangler Technical Forum 7 05-19-2004 08:34 AM
