10-07-2007, 09:29 PM
#1
will 33" tires fit on a stock rubicon...?
will 33" tires (33 x 12.5) fit on a stock rubicon with AEV Pintler rims (4.7" backspacing) without any rubbing problems? or do i need to put a 2.5" Teraflex BB lift on as well?
And if I do need to put on a 2.5 Teraflex BB, how much would a dealer usually charge for that?
10-08-2007, 02:24 AM
#2
All Around Nice Guy
i'm going to say yes, they will fit.
please don't pay anyone to install a BB for you. particularly not a stealership. you can do it yourself in a couple hours, with hand tools, in your driveway.
10-08-2007, 05:36 AM
#3
Thats easier said than done. Some of us dont have Driveways, and as part of my home ownership rules, you are not allowed to do any car repair/mods in their parking lot. I am not the OP, but I would love to be able to do it myself, but a lack of knowledge, and no real place to do it make it kinda diffacult for some. I know alot of people do it themselves in a couple hours though, I wish I could say that
2008 White 4Dr Rubicon
3" TF Coil Lift
35" KM2's on Pintlers
RR Stubby w/M8000
RR Rear w/Tire Carrier
LOD Rails|JKS Adj TrackBars & LCA's| Solid Diff Covers
10-08-2007, 07:15 AM
#4
Load up your lift and the tools you'll need and do it in a school parking lot on the weekend. It's not as hard to install as you might fear. There's plenty of writeups on this and other forums with detailed instructions and tips on how to do it.
Strength and honor.
10-08-2007, 07:57 AM
#5
Let's look at the math:
The stock JK Ruby 32" tire is 10.2" wide.
A 33x12.5" tire would be 2.3" wider.
The stock rim has an offset of 6.25"
An aftermarket rim with an offset of 4.7" will be outboard 1.5" more than stock.
So... you've got room because the additional offset of 1.5" will allow a tire to fit that is 3" wider (only half the width of the larger tire is inboard).
Note: Normally, circumference would be an issue as well but the new 33" tire will only add 1/2" to tire height. And, of course, all numbers assume accurate reporting by the tire company of tire measures.
Bill
2003 Rubicon auto w/3" TeraFlex System & 33" Goodyear MTR's
TJ Ruby Pic 1 TJ Ruby Pic 2
2012 JK Rubicon 2-dr, 6 speed
10-08-2007, 08:55 AM
#6
DETN8R
Adding the 3/4 leveling spacer in the front would be perfect for your tires.
'08 DETN8R Yellow Unlimited Rubi
6-Spd / Soft top / Power / Side Air Bags
Installed:
R.E. Modified 4" Super Flex Kit/Ft. & Rr. U-joint driveshafts/Full Traction Rear Adj. Trackbar/Custom Ft. Adj. Trackbar/Rancho 9000XL shocks/Superior 4.88 Gears & Evo Rear Axle Shafts/37" Pitt Bull Rockers on Custom Allied Beadlocks/Poly Perf. Rock Sliders/Shrockworks Mid Ft. & Rear Bumper/Custom Trans. Crossmember and Skid/Custom High Steer with PSC Hydro Assist/Plumbed Warn PowerPlant HP/Cobra 75 WS XT C.B./Bully Dog Programmer/Custom Exhaust/Dual Optimas/48" X-treme Hi-Lift Jack on Custom Rear Mount/...
____oooo
[ l_,[____],
l---L -[OlllllllO]
( )_) ( )_)--)_)
10-08-2007, 11:52 AM
#7
The Oct. '07 Off Road Adventures Magazine has a chart on p. 93 about the BFG M/T TA KM2 tires. The LT 285/70R17/D is 33" in dia. and will fit approved Rim Widths of 7.5"-8".
10-09-2007, 05:59 AM
#8
All Around Nice Guy
to hop off topic for a bit...i understand your plight, but there is always a way, like Broken Soldier said. Or, join a club, they'll have all kinds of helpful information, tools, time, and motivation to help out.
