Will a 2012 JK OEM soft top fit a 2007? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Will a 2012 JK OEM soft top fit a 2007?
Yukon Zip Lockers FREE AIR COMPRESSOR AND ROCKRIDGE REBATEToxic Brakes - 3000 PSI Braided Stainless Steel Brake LineTeraflex JK HD Hinged Carrier & Adjustable Spare Tire
Unread Yesterday, 12:22 PM   #1
Dakota
See subject...
The question means the top and all hardware, including door surrounds, etc.
The top is from a 2012 2dr & I have a 2007 2dr with the hardtop only.
For some reason, I think I will need to replace the door surrounds. Is this correct? Anything else?
Thanks.
'97 TJ Sport; '07 JK X
Dakota is online now   Reply With Quote Quick reply to this message
Unread Yesterday, 04:21 PM   #2
14Sport
2014 JK Wrangler
The door surrounds that come with the top are the ones you need. Your only issue will be the footman loop above the windshield moved which is an easy fix. Either remove the loop when running the soft top (it is only needed for the hard top) or grind a little off the soft top header to get it to sit tight.
2014 JK Sport, auto, 35x12.5x17, 3.73s.
My observations are based on my experiences...YMMV.
14Sport is online now   Reply With Quote Quick reply to this message
Unread Today, 02:19 AM   #3
mrsig
mrsig's Avatar
Yep as long as you have the surrounds for the 07 it will fit fine.
07 JKU To see mods & my Jeep in Action @ http://www.aaof.us/jeep.htm CEO of Black Sheep 4x4s http://www.blacksheep4x4s.org,
http://www.facebook.com/blacksheep4x4sorg
Member of CCJ, White Jeep Club Member #137.
mrsig is offline   Reply With Quote Quick reply to this message
