Will '07-11 Hard Top Fit '12 - JeepForum.com
post #1 of 11 Old 05-06-2012, 11:55 AM Thread Starter
echowhisky
Does anybody know if a Freedom Top that fits my '07 JKU can be put on a '12 JKU. Did anything change as far as where the holes are drilled or anything like that?
echowhisky is offline
post #2 of 11 Old 05-06-2012, 12:11 PM
1222
RIP John
1222's Avatar
They are different. For one, the rear lift glass is now wider than previous Jeeps.
1222 is offline
post #3 of 11 Old 05-06-2012, 12:16 PM
Spank
2014 JK Wrangler
The hoop position on the a-pillar is different between the '07 and '10+ models, so that right there might give you issues securing the front panels. I don't believe the shape or hole positions for the "container" portion of the top have changed, though.
'14 Wrangler Unlimited Rubicon
Spank is offline
post #4 of 11 Old 05-06-2012, 12:21 PM Thread Starter
echowhisky
Thanks. I have seen some things about clips to make it work? Is that for that issue? Does the window size cause a fitting problem? I guess the question is, can it be used?
post #5 of 11 Old 05-06-2012, 12:33 PM
1222
RIP John
1222's Avatar
I just took a closer look at the rear of my Jeep and perhaps I was wrong about the tops not fitting do to the wider rear lift glass. Although the glass is indeed wider, it appears that the tub opening is still the same as before.
1222 is offline
post #6 of 11 Old 05-06-2012, 01:13 PM Thread Starter
echowhisky
Great! Thanks for following up! Do you know anything about the extra clips for the front? What the would be called?
post #7 of 11 Old 05-06-2012, 03:15 PM
1222
RIP John
1222's Avatar
Sorry, canít help you there but there are several members that have both earlier Jeeps and the 2012 so hopefully one of those will take a look and report in.
1222 is offline
post #8 of 11 Old 05-06-2012, 04:15 PM
Don G.
I'm going to sell my hardtop from my 2008 JKU on Craig's List. Do I understand correctly that it will only fit 2007 to 2009 Unlimiteds? Thanks!
Don G. is offline
post #9 of 11 Old 12-28-2012, 02:54 PM
JeepRenegade
Does anyone know if a ONE piece hardtop from a 2007 Jeep JK (2dr.) will fit a 2012-2013 Jeep JK (2dr.)? Will it fit? Does it require drilling....etc? . Jeep Service parts doesnʻt really know! My Jeep has been there for more than 3 times- Lemon law around the corner, but I want to know IF a ONE piece hardtop (2007) will prevent water leaking.Thank you in advance for any help, lead....etc
JEEP: Just Empty Every Pocket
JeepRenegade is offline
post #10 of 11 Old 12-28-2012, 08:28 PM
ncb
The center hoop for the latch on the windshield frame was moved to the left a couple inches starting in 2009.
ncb is offline
post #11 of 11 Old 12-28-2012, 08:44 PM
JeepRenegade
Thanks ncb for getting back to me. So that means I am out of luck here...
hard top
Striker from full hard doors appears too big for hard half door? LEOinFL YJ Wrangler Technical Forum 1 05-24-2010 09:31 AM
Hard Top - Hard Doors Improvised Rattle solving thread bparsel YJ Wrangler Technical Forum 7 07-22-2009 07:23 PM
Half Hard Doors vs Full Hard....Key Cylinders Swappable? Hunta TJ Wrangler Technical Forum 17 05-13-2009 02:57 PM
hard half doors/sliding windows/hard top tomthbomb YJ Wrangler Technical Forum 7 07-13-2007 07:42 PM
Who Sells Hard Door Inserts that match the Hard Top gtospeeding TJ Wrangler Technical Forum 7 05-06-2007 10:15 AM
