why wont my jeep accept a sub and amp? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > why wont my jeep accept a sub and amp?
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! USA Standard Chromoly Front Axle Shaft Kits with Dana 30 4The Jeep Forum Discount is ON!
Unread 08-26-2015, 03:17 PM   #1
Littlefootjk15
2015 JK Wrangler
Hey guys im having a hard time finding out whats wrong when i wire my sub and amp. I have the stock head unit. i taped into the speaker bar and the 12v outlet. Everything works but when i go and shut the jeep down it stays running, engine light comes on as does the security alarm light, any thoughts?
Littlefootjk15 is offline   Reply With Quote Quick reply to this message
Unread 08-26-2015, 04:41 PM   #2
arbakken
Need more info. What equipment did you install, and where did you get the power from? I assume your amp accepts high level inputs and you got those by tapping into the sound bar.
arbakken is offline   Reply With Quote Quick reply to this message
Unread 08-27-2015, 03:40 AM   #3
Littlefootjk15
2015 JK Wrangler
Power is from the battery and its a 12" kenwood sub and a 1000watt amp. 2 channel
Unread 08-27-2015, 03:41 AM   #4
Littlefootjk15
2015 JK Wrangler
All kicker wiring
Unread 08-27-2015, 05:41 AM   #5
Digger838
What are you using the 12v outlet power for? Your rem wire to turn your amp on and off? If so I think that's most likely what's messing with your can-bus system and keeping your amp on try wiring the rem from the battery with and aux switch to turn the amp on and off I know it's a pain but it works temporarily
Sent from a jeepers iPhone
Digger838 is online now   Reply With Quote Quick reply to this message
Unread 08-27-2015, 12:57 PM   #6
Littlefootjk15
2015 JK Wrangler
Yes to turn the amp on and off, any chance it could be the wiring thats taped into the speaker bar?
Unread 08-27-2015, 03:15 PM   #7
arbakken
Isolate the systems. I'd start by disconnecting the remote turn on wire. See if that fixes your problem. If not, hook it back up and disconnect the sound bar wiring
Unread 08-27-2015, 03:44 PM   #8
Digger838
so when you say "speaker bar" do you mean the speakers in the upper sound bar? I have yet to dive into my stereo on my 14' yet but have been into a lot of sound system and stock stereos. Or are you just taking hi levels from out of the back of the stock deck? Wither way that wouldn't be the reason for the system not to turn off or for the engine light to come on, I would imagine that taping into the 12 aux power which is as I do believe incorporated into the can-bus electrical system of the jeeps, I would get out if that first. I'm sure they make a plug and play adaptor to get a rem wire out of the factory deck
Sent from a jeeper
Unread 08-27-2015, 04:51 PM   #9
Littlefootjk15
2015 JK Wrangler
Sent from a jeeper
Yeah i taped into the speakers in the sound bar, also ive tried a mini add a fuse that did the same thing also
Unread 08-27-2015, 04:53 PM   #10
Littlefootjk15
2015 JK Wrangler
Also just making something clear, the engine stays running, not the system
Unread 08-27-2015, 05:21 PM   #11
Digger838
OH! I didn't understand that part, how do you shut if off? Ummm that almost sounds like you tapped into a wire that has something to do with the ignition/key switch electronics?
As for the fuse? Where did you put that?
Sent from a jeeper
Unread 08-27-2015, 05:51 PM   #12
Littlefootjk15
2015 JK Wrangler
Just pull the k10 fuse, shuts it off, and i added the mini add a fuse to the fuse that said radio
Unread 08-27-2015, 05:53 PM   #13
Littlefootjk15
2015 JK Wrangler
Im not really sure where it would be if it was linked to the ignition
Unread 08-28-2015, 07:01 AM   #14
Digger838
Ok I think I understand what your doing now you took one of those jumper fuses that has a little tail on it and a place for the original fuse on top, and ran that to your amp for the rem wire, am I rite? I guess the only thing I can think of now is that it might not be the correct fuse position ? Just a guess
Unread 08-28-2015, 01:30 PM   #15
Littlefootjk15
2015 JK Wrangler
Yup your right, but ive tried two different locations with that and same result. I dont think its gonna work
