Why not a SCUBA Tank for tire inflation? - Page 3 - JeepForum.com
post #31 of 41 Old 06-24-2009, 02:34 PM
N2rock
N2rock's Avatar
Originally Posted by Brent_f70 View Post
SOOOO with Co2 we can:
  • drink a cold beer to get over being pissed about the stuff we broke
  • weld said broke ***** back together
  • re-seat the bead we broke when we broke the other stuff
  • re-inflate the tire
  • drive the rest of the way to the river and inflate the raft and drink more cold beer
did I miss anything??
You forgot: Run air tools to disassemble & reassemble the broken ****
for details and info on our JK's, check out
His: '07 Unlimited X, Jeep Green, Hardtop, auto, 5.13, 2.5" RC lift and too many mods to list
Hers: '08 X Red Rock, soft top, auto. Bunch of mods
Originally Posted by tlgraham View Post
If you made a snuggy out of a Shamwow, ....would you have to get up off the couch to pee?
Originally Posted by Deepskyy View Post
At this point if Obama tried to move a little to the right, he would trip over Stalin's corpse.
N2rock is offline
post #32 of 41 Old 06-24-2009, 05:20 PM
Kenbo-Slice
Co2 is a better option for many. The only reason that I run the air setup that I have, is because I got the tank free, the hydro testing free, and the fills for free (I fill it myself). You would REALLY need to bang one of the breathing air bottles to make it rupture. I have one strapped to my back when I go into fires, and they occasionally take some HARD hits. I am yet to break, or see one break.
Jeep build up...ONGOING
Kenbo-Slice is offline
post #33 of 41 Old 06-15-2011, 09:02 AM
Neoxxis
Thread back from the dead!!
I have a scuba setup too.
I always ask people how do you think divers transport their tanks?
And most divers go off-road also.
These tanks can take quite a hit right on the valve and nothing's gonna happen.
My diving teacher got hit in his car with 12 tanks in the trunk, all facing valve to the back.
The tanks got moved in the trunk but the car did not explode.
If it was that dangerous you wouldn't be allowed to take it in your car at all.
07 Unlimited Rubi Rescue Green/Auto/pwr
Neoxxis is offline
post #34 of 41 Old 06-15-2011, 09:39 AM
jeeperjk
2009 JK Wrangler
Originally Posted by RockyClymer View Post
Plus, the CO2 will put out enough air to re-seat the bead if necessary - yet to see a compressor do that.
Get beadlocks and you won't have to worry about that.
jeeperjk is offline
post #35 of 41 Old 07-25-2013, 06:40 PM
firedogkp911
How do u fill it and did u get it pressure tested?
firedogkp911 is offline
post #36 of 41 Old 07-26-2013, 05:58 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
The 4x4 shop I fill it at will do the required testing for me....they will not fill a tank without a current test cert. Alt, I think any welding gas supply will also test it.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #37 of 41 Old 07-26-2013, 09:38 PM
ancientspear
From my paintballing days... Scuba tanks need re-testing every 5 years or so to ensure they are structurally sound and still DOT/TC approved. Not sure if the same applies to CO2. Also, if you need to air up in the cold, you will want air and not CO2 or else it will freeze up on you. Another reason air is preferred is you can mount the tank at any angle and it will work, tilt CO2 tanks the wrong way and you shoot liquid... Again think iceing issues or potentially exposing your tire rubber to extreme temperature changes quickly. Finally, not sure if they are available in CO2 but compressed air tanks are available in fiberglass as well as steel if you are into weight savings
ancientspear is offline
post #38 of 41 Old 07-27-2013, 12:42 AM
Filthy-Beast
Before getting my york based OBA I've used the $50 MV50 compressor to reseat a bead. Only works if you lost one bead not both.
For Sale:
97 TJ: daughter 1 - 2.5L, Auto, 2" BB, 31" GY Duratrac
98 TJ: Daugher 2 - 4.0L, 5spd, D44 rear
06 LJ Rubicon: mine - Rokmen full up-armor, 8 adjustable CAs, front bumper, sliders, corners, Shrockworks rear bumper, 3" AEV/BDS lift, Currie HD stearing and Antirock, MT/r - k 35x12.5, SuperWinch, MC Overlines, York OBA
13 JKU Rubicon: Wife's for now, Ace Rock rails & rear bumper tire carrier, Truck Lites, MC Game changer 3.5 lift, RR skids, PSC Brawler front bumper, Warn 9.5cti-s, 35" GY MTRs
Filthy-Beast is offline
post #39 of 41 Old 07-28-2013, 12:19 AM
sardog12
sardog12's Avatar
On the opposite side, CO2 holds the same pressure until the tank is empty, meaning that it will take the same amount of time to fill tires from full to empty. Every time that you fill from an air tank, the pressure is going to go down, which means that the time that it takes to fill tires will go down. Also, with CO2, you eliminate the need for pressure gauges since they are mostly meaningless. Gauges are more needed on an air tank.
As for the angle, a CO2 tank can be fitted with a tube that would allow it to work standing up or on it's side. The only downside to this is that it would have to be re-tested. This would make it easy to be mounted on it's side and you wouldn't have to move it at all.
GEAUX TIGERS
sardog12 is offline
post #40 of 41 Old 07-31-2013, 08:15 PM
Neoxxis
Local scuba diving shop...
Neoxxis is offline
post #41 of 41 Old 08-01-2013, 01:49 AM
torange
over the weekend, we got 3 sets of 35's and 1 set of 37's out of 1 scuba tank, and still had air left!!
RK 3.5 Flex, 37' BFG KM2's, 17x9 ATX Slots, pro rock 44 front
torange is offline
Co2 vs Scuba tank performance? ghost183 YJ Wrangler Technical Forum 8 03-31-2009 11:09 PM
Proper Tire Inflation Dines TJ Wrangler Technical Forum 10 03-23-2009 04:31 PM
Scuba tank? Gif38 YJ Wrangler Technical Forum 10 07-17-2007 04:07 PM
ARB Tire Inflation Kit Idahomie TJ Wrangler Technical Forum 11 11-25-2006 09:57 PM
Scuba tank to fill tires? chris06 TJ Wrangler Technical Forum 10 08-23-2004 11:30 AM
