Why not a SCUBA Tank for tire inflation? - Page 2 - JeepForum.com
post #16 of 41 Old 06-23-2009, 04:07 PM
DBA2GO
Arb
Originally Posted by Prot View Post
Why not run an ARB compressor with the tire inflation kit that way you never run out. I have the arb tire inflation kit. It comes with 20' of hose, which is almost long enough to reach the tires of my trailer.
Is that the portable compressor? Or the one for the lockers&tires?
DBA2GO is offline
post #17 of 41 Old 06-23-2009, 08:10 PM
Brent_f70
Brent_f70's Avatar
Originally Posted by N2rock View Post
Really? I did not know this. And since I never weighed it empty, I had no way to determine the amount still in there. Good to know
Just went out to double check the "code", look for "TW" as in Tank Weight followed by numbers. I have a 20lb tank that weighs 25.0lbs The side of mine says "TW25.0LBS". The guy at the local AirGas company says they are required to stamp this into the sides of all new tanks.
6.7 HEMI, ProRock 60's, Atlas 4 speed t-case, on board air, Teraflex long arm plus ACOS, 37 inch Maxxis Trepadors, 5.38 gears, AEV bumper, Custom AEV hood, Warn 9.5, Nemesis aluminum sliders and fenders, Or-Fab front cage, Poly Performance rear cage, Hutchinson Beadlocks, PJ rear bumper, HD Teraflex track bars, tantrum rock lights, woods shafts, corbeau LG-1 seats, Chaser Trailer........TIME TO PLAY!!! Colorado Jeep Club member #177
Brent_f70 is offline
post #18 of 41 Old 06-23-2009, 09:23 PM
No_Return
The #1 argument I can make for CO2 vs SCUBA is that SCUBA a whole lot of energy sitting in the trunk. Especially when you consider the odds of rolling over etc are there.
Yes I know both types of tanks are tough as nails but if you manage to bust open a CO2 tank Its not going to go off like a bomb or worse a rocket.
One does not establish a dictatorship in order to safeguard a revolution; one makes a revolution in order to establish a dictatorship. - Orwell
No_Return is offline
post #19 of 41 Old 06-23-2009, 10:07 PM
ronjenx
ronjenx's Avatar
Ah, yes it will. There is about 800 to 900 psi in a liquid CO2 tank. That's more energy than I want to see get loose.
It's most often the valve on top that gets broken off.
ronjenx is offline
post #20 of 41 Old 06-24-2009, 06:49 AM
wTheOnew
I've seen both a small CO2 tank explode and a small air tank explode in person and I would much rather have the CO2. The CO2 tank basically spun a little in place and made everything around it cold. The air tank on the other hand was flying around in the air for a good 5-10 seconds. (I don't remember exactly how long, time slows down when something like that happens...)
Georgia Institute
of
Technology
wTheOnew is offline
post #21 of 41 Old 06-24-2009, 07:47 AM
ronjenx
ronjenx's Avatar
You have your experience, I have mine.
I saw a guy filling a CO2 bottle for a life raft. He forgot to close the bottle's valve when he disconnected the fill line. It discharged, came out of the chain vice, flew through the dropped ceiling, hit the concrete floor above and took several chunks of concrete out as it kept trying to get to the second floor.
ronjenx is offline
post #22 of 41 Old 06-24-2009, 09:15 AM
N2rock
N2rock's Avatar
I just found this website that explains what all the marking on the tank mean
http://www.catalinacylinders.com/markco2.html
my tank's empty weight is 14.1 lbs
for details and info on our JK's, check out
His: '07 Unlimited X, Jeep Green, Hardtop, auto, 5.13, 2.5" RC lift and too many mods to list
Hers: '08 X Red Rock, soft top, auto. Bunch of mods
Originally Posted by tlgraham View Post
If you made a snuggy out of a Shamwow, ....would you have to get up off the couch to pee?
Originally Posted by Deepskyy View Post
At this point if Obama tried to move a little to the right, he would trip over Stalin's corpse.
N2rock is offline
post #23 of 41 Old 06-24-2009, 09:17 AM
N2rock
N2rock's Avatar
actually, even more psi than that, depending on temps.
* When a fully charged 20 lb. CO2 cylinder, warms up to room temperature (70F), the pressure inside the cylinder increases to 837 psi.
* A fully charged CO2 cylinder at 87.9F will have an internal pressure of approximately 1100 psi.
* At 120F the same cylinder will have an internal pressure of nearly 2000 psi.
* At 155F the same cylinder will reach a pressure of 3000 psi, a pressure great enough activate the safety venting
N2rock is offline
post #24 of 41 Old 06-24-2009, 09:33 AM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
I use CO2 and it also allows me to use it for MIG welding in CO2 mode - just an additional benefit of using it.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #25 of 41 Old 06-24-2009, 01:11 PM
Brent_f70
Brent_f70's Avatar
Got a better use....When Mine is in the garage, I use it to provide pressure for the Kegorator!!
Lets see an ARB compressor do that!!!!
post #26 of 41 Old 06-24-2009, 01:17 PM
RockyClymer
RedRock4Wheeler
Plus, the CO2 will put out enough air to re-seat the bead if necessary - yet to see a compressor do that.
NRA Life member
post #27 of 41 Old 06-24-2009, 01:25 PM
N2rock
N2rock's Avatar
brett- your pm's are full.
N2rock is offline
post #28 of 41 Old 06-24-2009, 01:26 PM
Brent_f70
Brent_f70's Avatar
SOOOO with Co2 we can:
  • drink a cold beer to get over being pissed about the stuff we broke
  • weld said broke ***** back together
  • re-seat the bead we broke when we broke the other stuff
  • re-inflate the tire
  • drive the rest of the way to the river and inflate the raft and drink more cold beer
did I miss anything??
post #29 of 41 Old 06-24-2009, 01:30 PM
Brent_f70
Brent_f70's Avatar
WOW...5 PM's and it is full!! Guess I should splurge for a paid membership
post #30 of 41 Old 06-24-2009, 01:30 PM
erickpl
erickpl's Avatar
Scuba tanks will require scuba certs before any GOOD scuba shop will fill it. FACT.
CO2 isn't as flammable as an oxygen tank would be. That said, standard Scuba tanks are basically regular breathing air, unless you decide to use a Nitrox mix with a higher percentage of oxygen.
I have a 10 lb CO2 tank, but I scuba dive as well. I would rather keep my scuba tanks for scuba and my CO2 for offroading and other things.
-Paul
Green Jeep Member #155
Low Output 4 Cylinder Jeep Member #35
Keep moving forward. But keep an eye on history, for if you don't, you are doomed to repeat it.
erickpl is offline
Co2 vs Scuba tank performance? ghost183 YJ Wrangler Technical Forum 8 03-31-2009 10:09 PM
Proper Tire Inflation Dines TJ Wrangler Technical Forum 10 03-23-2009 03:31 PM
Scuba tank? Gif38 YJ Wrangler Technical Forum 10 07-17-2007 03:07 PM
ARB Tire Inflation Kit Idahomie TJ Wrangler Technical Forum 11 11-25-2006 08:57 PM
Scuba tank to fill tires? chris06 TJ Wrangler Technical Forum 10 08-23-2004 10:30 AM
