Why not just order an X? - JeepForum.com
post #1 of 13 Old 10-16-2006, 08:58 PM Thread Starter
planman
Thanks to all Mod erators
planman's Avatar
If I were going to do a 3" lift, regear to 4.56 or 4.88, and put 35s on a JK Unlimited, why wouldn't I just buy an X instead of a Rubi?
If I regear to 4.56 or 4.88, don't I have to buy aftermarket selectable lockers anyway? Or, would I be able to use the Rubi lockers after the regear?
With a 3" lift on a JK Unlimited X, can't I get away without installing a SYE and longer driveshaft?
Thanks.
planman is offline
post #2 of 13 Old 10-16-2006, 09:03 PM
2K1TJ
2K1TJ's Avatar
You should be able to reuse the Rubi lockers when re-gearing to 4.56's/4.88's, but don't quote me on that.
From what I've read, a 3" kit shouldn't need longer shafts. And the JK uses fixed yokes, i.e. no sye necessary.
2K1TJ is offline
post #3 of 13 Old 10-17-2006, 08:35 AM
Fropleyqk
Fropleyqk's Avatar
-You won't have the stronger 44's with the X.
-You won't be under any warranty
-It'll cost you a lot more to build an Rubicon-ish-X than just to buy a Rubi outright.
But if youre under budget and building in small phases, maybe the X is right for you.
Fropleyqk is offline
post #4 of 13 Old 10-17-2006, 08:37 AM
Fropleyqk
Fropleyqk's Avatar
post #5 of 13 Old 10-17-2006, 12:06 PM
Jason, aka: Jeepin.com
Vendor
Jason, aka: Jeepin.com's Avatar
1995 XJ Cherokee
Don't forget the 4:1 t'case. Plus everything is rolled into your car payment, not your credit card payment like it would be if you bought an X and then had to go buy all the other upgrades out of pocket.
Jason West -
'16 JKUR Hard Rock, RE/Synergy 3.5", 37" GY MTR/Ks
'95 XJ, RE 5.5", 35" MT/Rs, D30 w/hubs & ARB, D44 w/Detroit, 4.56s, C4x4 bumpers, etc, etc.
'00 TJ, SOLD, wife's, RE 4.5" long-arm, 35" MT/Rs, D30+OX, D44+ARB, 4.88s, full cage, winch, C4x4 & Jeeperman bumpers, etc, etc.
Jason, aka: Jeepin.com is offline
post #6 of 13 Old 10-17-2006, 12:57 PM
Karamba
Thanks.
Do you really want front locker in the 30? With 44 sit hould be OK. With 4:1 transfer - you could get away with running 35" on 4.1 gears. And electronic sway bar disconnect (though it remain to be seen how reliable it is) looks like the greatest thing since sliced bread - as you now can run both open and connected on the same trail...
I bet that just getting a stock Ruby, maybe some minor lift to fit 33- 35, and not doing pretty much anything else will get you as far on the trail, or farther, then your intended setup and will cost you less, and will be under warranty, and with a better resale. Considering that you could take away and sell your 32" MT that comes on the Rubi, I just can not see how you could beat the factory setup starting from X.
In fact - you could just hit the trails without doing ANYTHING, and see how it goes, and it may be just good, and then just replace what breaks, wears out...
Karamba is offline
post #7 of 13 Old 10-17-2006, 01:59 PM
chris269
Junior Member
warrenty
Am I wrong or don't you lose your warrenty as soon as you lift it.
chris269 is offline
post #8 of 13 Old 10-17-2006, 02:03 PM
Karamba
Not all of it. Only for the parts that they can prove had been affected by the lift.
Karamba is offline
post #9 of 13 Old 10-17-2006, 03:05 PM
Vendor
1995 XJ Cherokee
Why not? The 30's in our XJ and TJ are holding up just fine to low gears, lockers, and 35's. A lot depends on your wheeling/driving style.
Jason West -
post #10 of 13 Old 10-17-2006, 03:39 PM
Karamba
Originally Posted by Jason, aka: Jeepin.com
Why not?
Well, I guess in this guess my point was - because you can get a 44 with a nice locker from the factory for not that large of a price differential.
Karamba is offline
post #11 of 13 Old 10-17-2006, 03:53 PM
Vendor
1995 XJ Cherokee
Ah, ok, totally agree with you on that. Rubicon is definitely the way to go. But for those folks that for whatever reason choose not to get a Rubicon, locking the D30 isn't that big of an issue.
Jason West -
post #12 of 13 Old 10-17-2006, 05:28 PM
2K1TJ
2K1TJ's Avatar
I wan thinking about a 4 dr. That's what I have (d44 in the rear) Forgot that the d35 is still standard on the 2 drs.
2K1TJ is offline
post #13 of 13 Old 10-17-2006, 07:45 PM
Karamba
And for milder trail use, it is less needed now, with the electronic brake actuated traction control available, you could get by quite a lot with that and a rear locker...
Karamba is offline
Where to order OME kit PanthrosRevenge YJ Wrangler Technical Forum 1 10-20-2007 11:43 AM
New '08 on Order - "C" order status? NorthBendJeeper JK Wrangler Technical Forum 8 08-06-2007 07:06 PM
How to order a D44? Airborne4X4 TJ Wrangler Technical Forum 2 09-21-2006 04:02 AM
Before I order... Dubakountry TJ Wrangler Technical Forum 8 07-29-2006 04:44 PM
Where to order D44 Avor TJ Wrangler Technical Forum 3 05-02-2005 07:49 AM
