White smoke from AC vents and smells like antifreeze - JeepForum.com
post #1 of 16 Old 11-29-2012, 09:54 AM Thread Starter
projectman
Hey guys and gals...
New to the forum and I noticed a problem with my 2007 Jeep Wrangler Unlimited this morning.
It has around 38,000 miles on it.
Coolant level was a bit low, so I filled it yesterday.
What should I check first?
projectman is offline
post #2 of 16 Old 11-29-2012, 10:03 AM
ncb
Leaking heater core.
ncb is offline
post #3 of 16 Old 11-29-2012, 10:16 AM Thread Starter
projectman
Is this a DIY or a take it in for repair job?
post #4 of 16 Old 11-29-2012, 10:28 AM
Joevacs
2010 JK Wrangler
or a head gasket. Look at you oil, I hope you don't see milky oil.
2010 Rubicon, 4" lift, Currie control arms and trackbar, 40" Procomp MTR
Joevacs is offline
post #5 of 16 Old 11-29-2012, 10:47 AM Thread Starter
projectman
Changing oil later today, so we'll see
post #6 of 16 Old 11-29-2012, 11:04 AM Thread Starter
projectman
Do I need to stop driving the vehicle?
post #7 of 16 Old 11-29-2012, 11:08 AM
GPV
You will have to replace your heater core more than likely. It might be a leak at a connection or something but that is a bit optimistic honestly.
Sean
2008 Jeep JK Rubicon Unlimited (Bought for Wife)
2007 GMC 2500HD Duramax (Work Horse)
1982 Honda CB 900F Supersport
2001 Honda RC51
GPV is offline
post #8 of 16 Old 11-29-2012, 11:10 AM Thread Starter
projectman
Is heater core replacement difficult on this model?
post #9 of 16 Old 11-29-2012, 11:36 AM
GPV
I don't have any experience with the JK. I suspect that it is in the passenger cabin behind the glove compartment. If you are at all handy it should be a weekend job to change out.
Sean
2001 Honda RC51
GPV is offline
post #10 of 16 Old 11-29-2012, 12:49 PM Thread Starter
projectman
Carpet is wet under the passenger side floor mat...
post #11 of 16 Old 11-29-2012, 01:34 PM
JeepCares
FCA Customer Care
JeepCares's Avatar
HEATER CORE REMOVAL (from the 2007 JK Service Manual):
WARNING: Disable the airbag system before attempting any steering wheel, steering column or instrument panel component diagnosis or service. Disconnect and isolate the negative battery (ground) cable, then wait two minutes for the airbag system capacitor to discharge before performing further diagnosis or service. This is the only sure way to disable the airbag system. Failure to follow these instructions may result in accidental airbag deployment and possible serious or fatal injury.
NOTE: LHD model with A/C shown in illustrations. RHD and heater-only models similar.
See pic 1
1. Remove the HVAC housing assembly and place it on a workbench.
2. Remove the floor distribution duct from the passenger side of the air distribution housing.
NOTE: If the foam seal for the flange is deformed or damaged, it must be replaced.
3. Remove the foam seal (1) from the flange (4) located on the front of the HVAC housing (2).
4. Remove the screw (3) that secures the flange to the HVAC housing and remove the flange.
See pic 2
5. Remove the screw (1) that secures the bracket (2) retaining the heater core tubes (3) to the passenger side of the air distribution housing (5) and remove the bracket.
6. Carefully pull the heater core (4) out of the side of the air distribution housing.
JeepCares is online now
post #12 of 16 Old 11-29-2012, 01:35 PM Thread Starter
projectman
Changed oil and it looks normal. No milk.
post #13 of 16 Old 11-29-2012, 03:09 PM Thread Starter
projectman
Looks like I would have to remove the entire interior dash panel to get the heat core. That's crazy amounts of work for a part replacement. Ughhhh
post #14 of 16 Old 11-29-2012, 03:19 PM
Godholio
If you're smelling it through the vents and it's getting into the carpet, definitely a bad core/connections. Without those symptoms I would've been concerned about a head gasket.
Utah Jeep Crew #148
No powerball here? How am I supposed to finance the mods?!?
'12 Sport...miss my YJ for all the wrong reasons though
Godholio is offline
post #15 of 16 Old 11-29-2012, 03:47 PM Thread Starter
projectman
What should I expect to pay to have this repaired by a local mechanic if it is bad core/connections? Found the replacement heat core for about $100, but the labor looks like it would take me weeks.
ac , antifreeze , coolant , smoke , vent
