Where is Sirius antenna located? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Where is Sirius antenna located?
Looking for a rear bumper for your JK? Check out what JcrOIntroducing the Dagger, JcrOffroad's new Slimline bumpers.JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Unread 07-19-2009, 05:34 AM   #1
MacK
2010 JK Wrangler
Does anyone know where the Sirius antenna is located? I really want to move it to a better spot because reception really sucks.
In other words, has anyone had success improving Sirius? I go under a freaking tree with one leaf and it goes out.
I don't want your d**n lemons! What the hell are these?! Demand to see life's manager! Make life rue the day it thought it could give Cave Johnson lemons! Do you know who I am? I'm the man who's gonna burn your house down! WITH THE LEMONS! I'm gonna get my engineers to invent a combustible lemon that BURNS YOUR HOUSE DOWN!
Mango Tango 2010 JK Wrangler Rubicon
Silver 2000 TJ Wrangler Sport
The 2008 Jeep Wrangler is not so much an SUV as it is an experience. It's slow and loud, handles poorly, has crummy interior materials and features doors that provide virtually no crash protection. But when it comes to off-road performance, the Wrangler is simply the best choice available.
MacK is offline   Reply With Quote
Unread 07-19-2009, 06:17 AM   #2
GhostRiderLJ
Not sure if they changed it on the JK's but on my 06 LJ it's on top of the cage bar. Left side, you'll see a hump in the padding. Unzip the padding, and it'll be there. As far as better reception goes, run with the top off/down and the antenna exposed, if it doesn't get any better then it might be the satelite or your location, not the antenna. I can see where it would be tough to permantly mount that style antenna on the jeep, unless you put it on top of a hard top and never take the top off. Or put it on an upright stick of some kind, but that would probably look bad. I would find a shop that installs audio and talk to them to see if they can help. Maybe there's a booster or something they can install. I'm certainly no expert, I just thought I'd throw all that out for ya. Good luck, I love mine, comercials suck!
Carl[FONT="Arial"][/FONT]
"[I]A Country Boy Can Survive"[/I]
GhostRiderLJ is offline   Reply With Quote
Unread 07-19-2009, 07:01 AM   #3
Bucknell07
According to the instructions that come with the Mopar Satellite Radio Installation Kit (See PDF from Quadratec), the antenna should be located on the roll bar just above the front passenger seat. I haven't verified this with my own JK, but I experience your pain with the intermittent outages caused by trees, overpasses, etc. However, I've read in numerous posts that the hardtops/softtops should not impact the satellite radio reception. If this is true, then it would likely seem that the antenna is positioned too far to the passenger side and better reception would be experienced if the antenna were in the middle of the roll bar. Just my thoughts. Hope this helps.
Bucknell07 is offline   Reply With Quote
Unread 07-19-2009, 07:58 PM   #4
rwr613
Sirius
The antenna is located under the plastic dash lid over the top of the radio.
rwr613 is offline   Reply With Quote
Unread 07-19-2009, 08:02 PM   #5
albrechtmj
That's for the compass, not the satellite radio.
It's above the rollbar/plastic like everybody else said.
--Mike
albrechtmj is offline   Reply With Quote
Unread 07-20-2009, 07:01 AM   #6
devilsfiddle
mine is on the hood and that works too.
JK 08 X
devilsfiddle is offline   Reply With Quote
Unread 07-20-2009, 08:47 AM   #7
unsocbl
2011 JK Wrangler
That's where mine was! Replaced it with an XM antenna in the same place and rarely lose the signal, although I don't remember the Sirius signal dropping much either.
unsocbl is offline   Reply With Quote
Unread 07-20-2009, 08:49 AM   #8
DBA2GO
Happy Trails!
DBA2GO's Avatar
Ding Ding Ding
This is exactly where it is.
DBA2GO is offline   Reply With Quote
Unread 07-20-2009, 02:24 PM   #9
chumpmann
I hate when I am at sonic and under the awning and it goes out, I have to backup or pull up to try and get a reception.
"Never trust quotes on the internet" - Bejamin Franklin
¡ɹǝʌo ǝɯ dıןɟ 'sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
Other Jeeps...
1994 YJ - 2.5" RC lift, 31x10.5 BFG AT
Hers - '07 XK
chumpmann is offline   Reply With Quote
Unread 07-20-2009, 02:46 PM   #10
MacK
2010 JK Wrangler
I have XM also, and has no reception issues what so ever. It's just a simple magnetic clip on antenna. Sirius goes out way too much. It's constant. Especially on roads that have trees on both sides. I'll try moving it, and see what happens and post back. Thanks!
Unread 07-20-2009, 03:43 PM   #11
premo
1992 XJ Cherokee
its located on the drivers side of the roll cage underneath the cloth part..if you unzip that thing you will see it right there. it's got some double sided sticky tape or somethign on it...not sure if there's enough wire to move it, i didn tlook when i had my cage apart last...
-Scottish proverb
premo is offline   Reply With Quote
Unread 07-20-2009, 07:01 PM   #12
SkipperTW
Mine is located under cloth on overhead rollbar (09 Sahara 2dr). Was also located in same on 07 Saharh 2dr),
SkipperTW is offline   Reply With Quote
Unread 07-21-2009, 07:32 AM   #13
MacK
2010 JK Wrangler
Well if it's located on the driver side, then that's probably no point in moving it.
Unread 07-21-2009, 01:27 PM   #14
premo
1992 XJ Cherokee
sorry, im retarded....i meant passenger side! (17hr drive + 4 hrs sleep + work next day = idiot lol)
-Scottish proverb
Unread 07-22-2009, 01:12 PM   #15
MacK
2010 JK Wrangler
Haha, nice. Yea, long trips suck.
