where to run wires from engine compartment to rear? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > where to run wires from engine compartment to rear?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFREE Shipping Sale!FS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 06-03-2015, 09:54 AM   #1
Swamp_Stomper
2011 JK Wrangler
I have a 2011 JK and I need to run some large power cables, 1/0 Gauge, to the rear bumper. I want to keep them to the exterior of the Jeep. Has anybody done this and if so I would appreciate any help you could give. Thanks!
Swamp_Stomper is offline   Reply With Quote Quick reply to this message
Unread 06-03-2015, 11:13 AM   #2
Moezer
2015 JK Wrangler
Under the jeep make sure u wrap it with heat resistant wrapping and then tucking it behind the heat shields on the driver side of the deep
What u can also do is run it inside the frame on the driver or passenger side
Moezer is offline   Reply With Quote Quick reply to this message
Unread 06-03-2015, 06:08 PM   #3
JLC08JK
What was I thinking?
JLC08JK's Avatar
I have 2-#4 cables run down the passenger side above the frame zip tied to the factory harness. You can feel the factory harness if you reach over the frame towards the fuel tank. I wrapped each cable in flexible wire loom to prevent abrasion.
The passanger side was better for me because it is a straight shot to the battery. I put a 100 amp fuse close to the battery just in case the cable gets damaged and shorts.
JLC08JK is offline   Reply With Quote Quick reply to this message
Unread 06-04-2015, 08:08 AM   #4
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
Good stuff - but I would add to make damn sure you have NO possible pinch points (during body flex, in an accident, roll etc) anywhere near that fuel tank!
J Wm Bishop EA, ASADE
Waiting for the JAMBOREE at Rubicon is worse than waiting for Christmas...
jwmbishop is offline   Reply With Quote Quick reply to this message
Unread 06-08-2015, 08:21 AM   #5
Swamp_Stomper
2011 JK Wrangler
Thank You for the responses.
