Where to mount CB antenna on JK - JeepForum.com
post #1 of 4 Old 11-16-2006, 03:31 AM Thread Starter
cliffmelanie1
I just got the JK and want to put my cb in it. Where do I mount the ant. Is there metal under the bumper to be able to get a ground? I don't really want to drill into the side of the body if I don't have to.
05 Rubicon 31/2" RE lift, 305 70 16 Duratracs
cliffmelanie1 is offline
post #2 of 4 Old 11-17-2006, 06:18 PM Thread Starter
cliffmelanie1
I looked at the spare tire carrier. It looks like I might be able to mout it there. I'll try it over the weekend and reply in case anyone else has the same question.
post #3 of 4 Old 11-17-2006, 07:25 PM
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
Steel square tube from Home Depot. Mounted on spare tire carrier, drilled and bolted to the side; mounted flushed to the door. Got a L shaped antenna mount from a truck stop. High mount gives you the best SWR reading.
2009 JK Rubicon
Shrockworks Mid-width, Warn 9.5Ti; Skid Row Engine Skid, LCA & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Diff Skids, 11,000# Pull-Pal. Uniden 520XL CB; 1" Front & 1/2" Coil Spacer Rear; Aeroforce Interceptor, Valentine 1.
Moab - TJ-4/2006, TJ-5/2008, 4/2009, 5/2011, 4/2013, 5/2016, 4/2017
Ouray - TJ-8/2007
Rubicon - TJ-9/2008
Thunderstrike is offline
post #4 of 4 Old 11-18-2006, 06:50 PM
MZP
Originally Posted by Thunderstrike
Steel tube from Home Depot. Mounted on spare tire carrier, flushed to the door. High mount gives you the best SWR reading.
Your good man! Mice and clean.
MZP is offline
CB Antenna Mount for JK nota4re JK Wrangler Technical Forum 90 02-22-2011 06:46 PM
Opinion on Antenna Mount / Antenna HammerG26 JK Wrangler Technical Forum 22 01-04-2011 06:49 PM
capping antenna mount when antenna is off Jeeper-4-Life TJ Wrangler Technical Forum 0 02-10-2007 08:57 PM
Your CB antenna mount LOCKED UP YJ Wrangler Technical Forum 22 09-30-2006 10:59 PM
CB antenna - where to mount? Keymaster YJ Wrangler Technical Forum 7 09-01-2002 11:05 AM
