Where is a good location to mount a Vair air compressor under the hood? - Page 2 - JeepForum.com
post #16 of 22 Old 07-13-2010, 02:27 PM
Dragline
Do you also get the manifold and bracket? Or did you just get the compressor bracket? No issues with mine using both brackets and the manifold.
Dragline is offline
post #17 of 22 Old 07-13-2010, 04:30 PM Thread Starter
xj37
2014 JK Wrangler
I just got the compressor bracket. i have all of the parts from my TJ setup and I am not using the air tank since it is a 2.5 gallon and will not work withthe tank mounts. only gunna use it to air up tires.
xj37 is offline
post #18 of 22 Old 07-16-2010, 02:01 PM Thread Starter
xj37
2014 JK Wrangler
Installed the compressor yesterday. It was easy with the bracket just a little tight getting the master cylinder nuts back on. Was surprised a bit that the master cylinder nuts were not that tight from the factory, guess it does not need to be that tight.
xj37 is offline
post #19 of 22 Old 12-08-2013, 08:18 PM
13blackjk
I have the 2.5 gallon tank and I need a place to mount it I was gonna order the skid plate that mounts the tank and covers the evap canister but says only jk till 2011 I have a 2013 does anyone know a good spot to mount it where it's out of the way
13blackjk is offline
post #20 of 22 Old 12-08-2013, 11:54 PM
JLC08JK
What was I thinking?
JLC08JK's Avatar
You could relocate the muffler and mount the tank in its place.
I cut out the rear tub and built a custom tub to house the entire system.
I think there are more pictures in my build "Obsession" thread linked below.
Jim
JLC08JK is offline
post #21 of 22 Old 12-09-2013, 09:13 AM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
Originally Posted by xj37 View Post
I have the bracket now but was thinking on how strong is the brake booster with the added weight of the compressor? Does anyone know if this could be a issue over time?
3 years hasn't been a problem. The only thing I don't like about it - if I am coming down on the brake pedal at the same time as the compressor kicks in the vibration makes it feel like ABS is engaging and I end up altering my brake input before I realize what happened! For that reason I typically only run the compressor when I need it.
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #22 of 22 Old 06-23-2014, 05:02 PM Thread Starter
xj37
2014 JK Wrangler
@jwmbishop -Thanks for the update. I did not have the 2010 Wrangler to long after mounting the compressor. Glad it is not a problem since I just installed it in my new 2014 Wrangler (new bracket was needed again).
xj37 is offline
air compressor , JK Wrangler , mounting , under hood , viair , wrangler
ARB Compressor Location bradentaala TJ Wrangler Technical Forum 7 03-17-2010 07:21 PM
ARB Compressor location steve3911 TJ Wrangler Technical Forum 12 03-07-2007 04:54 PM
Air compressor to mount under hood...? fxbrry TJ Wrangler Technical Forum 39 02-05-2007 06:07 PM
on board compressor mount location bigV TJ Wrangler Technical Forum 10 11-05-2006 09:23 PM
ARB Compressor location? RD YJ Wrangler Technical Forum 1 01-09-2003 02:39 AM
