Where is the AC drain located on a 2012 Jeep Wrangler? - JeepForum.com
post #1 of 7 Old 04-22-2013, 11:41 AM Thread Starter
mbu
I've been getting water in both driver and passenger side footwells and wanted to make sure the AC drain was working properly before going further.
Please note: It's probably a good bet it's the AC drain as I haven't washed the Jeep and it hasn't rained since I dried out the footwells. I did run the AC during that time and the moisture is back.
Thanks...
mbu is offline
post #2 of 7 Old 04-22-2013, 11:48 AM
JBTJ
On my TJ it's under the battery tray. Should be a rubber hose about 1/2" sticking out of the firewall. It should also have a 90 degree bend on it with another short piece of hose pointing down to the ground. If this 90 degree bend is not there they what is happening is air is being forced back up the condensate line thus draining on the floorboard.
JBTJ is offline
post #3 of 7 Old 04-23-2013, 02:28 PM
LSSB
I would sure like to find out where the water is coming from. I am getting it on the driver side floor, but I have no clue where it is coming from.
LSSB is offline
post #4 of 7 Old 04-23-2013, 02:36 PM
toxicwaste29
Thanks...
It isnt from the ac. Send me both of your emails and i can send you a dealer water leak diagnosis pdf. It shows how to find where the leak is coming from and how to fix it.
toxicwaste29 is offline
post #5 of 7 Old 04-23-2013, 06:03 PM Thread Starter
mbu
I'm posting a picture of where the AC drain tube is located on the 2012 Wrangler in case someone else may want to know. The photo is taken from the driver side looking back to the firewall.
mbu is offline
post #6 of 7 Old 04-23-2013, 06:16 PM Thread Starter
mbu
That would be most helpful, PM sent with address.
I have the following one but it only covers vehicles up to 2009. I would think Jeep would have fixed those areas for the 2012.
http://www.google.com/url?sa=t&rct=j...,d.b2I&cad=rja
Thanks...
mbu is offline
post #7 of 7 Old 04-23-2013, 07:44 PM
toxicwaste29
Thanks...
That might be the one i had sent to you. I have checked mine with the one i sent you and it still had the same problem areas
