When did JK get upgraded rear axle - Page 2 - JeepForum.com
post #16 of 22 Old 04-27-2010, 11:56 AM
Liquor
BOUNTY HUNTER
Liquor's Avatar
2008 XK Commander
i have an '07 bought Oct 15th '06. 6 speed and 4.10 gears, not a tow package. D30 front and D44 rear...
ive never seen these so called D35 JKs
2007 Unlimited Sahara Steel Blue - I call it "CAIN"
2002 TJ Sport - Sold
"CAIN" '07 Jeep JK 426 HEMI 685 HP & 650 ft lbs
Your Jeep and Gaming Social Network
2012 Sponsors:
Magazine Feature:
Liquor is offline
post #17 of 22 Old 04-27-2010, 12:40 PM
terrahawk
Originally Posted by jake_blue View Post
So then maybe this is a dumb question but chalk it up to being a Jeep newbie... why is the D35 unsuitable for the rear axle but still suitable for the front axle? You have to get the Rubicon to get a D44 front axle. Unless it just has to do with the duty rating and that the rear axle is always engaged versus the front axle only part-time.
C-clip
Tiny ring gear
Rubber band housing
total piece of @#$*
Speed has never killed anyone - suddenly becoming stationary, that's what gets you!
terrahawk is offline
post #18 of 22 Old 04-27-2010, 12:44 PM
N2rock
N2rock's Avatar
Well- now you have. This one trashed the spider gears in his D35 during this run
for details and info on our JK's, check out
His: '07 Unlimited X, Jeep Green, Hardtop, auto, 5.13, 2.5" RC lift and too many mods to list
Hers: '08 X Red Rock, soft top, auto. Bunch of mods
Originally Posted by tlgraham View Post
If you made a snuggy out of a Shamwow, ....would you have to get up off the couch to pee?
Originally Posted by Deepskyy View Post
At this point if Obama tried to move a little to the right, he would trip over Stalin's corpse.
N2rock is offline
post #19 of 22 Old 04-27-2010, 12:51 PM
Liquor
BOUNTY HUNTER
Liquor's Avatar
2008 XK Commander
was it just on the 2 door models? i dont see jeep putting them on an unlimited
2012 Sponsors:
Magazine Feature:
Liquor is offline
post #20 of 22 Old 04-27-2010, 01:07 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
I believe the D35s used the older C clip retainer which was a real problem - if it broke, your axle slid out! Know some who had this problem. The newer D30 in the front uses a unit bearing that retains the axle, not a C clip in the pumpkin...also, the D30 in front is a high pinion which is inherently stronger because the pinion rides on the correct (strong) side of the ring gear. All for the better if you ask me.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #21 of 22 Old 04-27-2010, 01:19 PM
Hussler
1992 XJ Cherokee
Seeing that the 2 door JK Rubicon weighs 4,100 dry, I would say a D35 would be screaming under there. Can't even imagine what that thing would do under a four door.
Originally Posted by chris87xj View Post
Sometimes a restoration project is a labor of love, at which point cost, time, and labor involved become irrelevant.
Originally Posted by BorderC View Post
I see you also twizzled your scart lead. Well done! :thumbsup:
92 XJ with ARB's, 5" lift, too much armor, 33's and some other garbage
Hussler is offline
post #22 of 22 Old 04-28-2010, 12:04 AM
aznjeep
aznjeep's Avatar
2014 WK
Couldn't decide who to quote from above..
On my '99 TJ, I've got the D30 front, D35 rear, on 3.73 and 33x12.5 on 15" rims. I ran a Lock-Right locker in the front, until it cracked, then replaced it with an Aussie Locker. The D30 is still going strong, although I think my knuckle joints are going out. I just started to take it apart to find out what's going on.
My D35... well, one time I blew out the clutch pack from the Trac-Lok, and the other time, I blew out my side and spider gears on a moderate trail (my fault really, the rear-end hopped up, and I didn't let off the gas fast enough before it came down). Mine is c-clipped, and a Super35 is on my list. However, I do know they made 2 versions of the D35.. c-clipped and non-c clipped... FWIW...
-Ken
'96 XJ Sport
'14 WK2 Overland EcoDiesel
'13 JKUR 10A (sold)
'10 JKUR (sold)
'99 TJ (sold)
aznjeep is offline
upgraded rear ends 00dutchTJ TJ Wrangler Technical Forum 4 03-28-2010 10:06 PM
Should the Front Axle & Rear Axle be off centered to the passanger side by .5"? Lemmiwinks TJ Wrangler Technical Forum 3 07-07-2009 09:27 AM
Solid Axle Hd 44 Rear Axle Assembly SuperWade2 TJ Wrangler Technical Forum 128 06-05-2009 12:01 AM
Tire/Rear Axle question....out of alignment, rear axle "turned". (Thrust Angle) Sparty TJ Wrangler Technical Forum 5 09-19-2007 02:23 PM
upgraded axle shafts - what year/month? 1995? Mark_ZZ3 YJ Wrangler Technical Forum 5 01-13-2005 04:30 AM
