When did JK get upgraded rear axle - JeepForum.com
post #1 of 22 Old 04-27-2010, 09:00 AM Thread Starter
keithert
keithert's Avatar
I think that in 2008 the JK got the upgraded rear axle on all models. Why was this? Were they having problems with the axles in the 07s? Should I stay away from an 07 with the standard axle?
Current: 2016 Ram 1500 Sport - Past: 05 Wrangler LJ, 90 and 92 Trackers and 98 Wrangler SE
keithert is offline
post #2 of 22 Old 04-27-2010, 09:05 AM
Seanie
The early 07's came with the Dana 30 or 35, can't remember which off of the top of my head. They're very rare though. The good thing about the 07's is that if it's an Auto with a dana 44, it's got 4.10's.
Don't drink the water, there's blood in the water... DMB
Seanie is offline
post #3 of 22 Old 04-27-2010, 09:15 AM
N2rock
N2rock's Avatar
rear axle is the same. As mentioned, the early '07 models had a D35 rear. But that was short lived- only some of the ones with a build date in '06 have them. IIRC December '06 builds is when they switched to D44 for all models.
for details and info on our JK's, check out
His: '07 Unlimited X, Jeep Green, Hardtop, auto, 5.13, 2.5" RC lift and too many mods to list
Hers: '08 X Red Rock, soft top, auto. Bunch of mods
Originally Posted by tlgraham View Post
If you made a snuggy out of a Shamwow, ....would you have to get up off the couch to pee?
Originally Posted by Deepskyy View Post
At this point if Obama tried to move a little to the right, he would trip over Stalin's corpse.
N2rock is offline
post #4 of 22 Old 04-27-2010, 09:19 AM Thread Starter
keithert
keithert's Avatar
Thanks for the info. Was the D35 rear bad news?
keithert is offline
post #5 of 22 Old 04-27-2010, 09:28 AM
N2rock
N2rock's Avatar
Yes- if you wheeled it, you were probably going to grenade it. It didn't take long for Jeep to realize it was a big mistake.
N2rock is offline
post #6 of 22 Old 04-27-2010, 09:49 AM
ronjenx
ronjenx's Avatar
A friend of mine has an '07, 6 speed, 4.10 gears. He bought it off the lot, not special ordered.
ronjenx is offline
post #7 of 22 Old 04-27-2010, 10:05 AM
N2rock
N2rock's Avatar
Tow package
N2rock is offline
post #8 of 22 Old 04-27-2010, 10:09 AM
limeking
Not so true. They used that crappy 35 since 1987.
If there wasn't stuff that sucked, how would we know what was cool? Beavis and Butthead
Jeremy : )
2004 Lime Rubicon, NV3550, JKS arms, and trackbars, UCF tummy tuck, LoPro and engine skid, 3 in tera springs 33 KM2s
1994 Red Wrangler, 2.5 in lift, 31 in no names, 4.0 ax15 30/35
limeking is offline
post #9 of 22 Old 04-27-2010, 10:15 AM
juiceparn
Sure they used to get away with it but the 35 just wouldn't stand up to the increased HP and torque of the 3.8 I had to!
07 JK 4DR 3.5" Rubicon Express, C gussets, Front XHD stubby, winch, Taboo Customs rear bumper with tire carrier, Taboo Customs Rock sliders.
juiceparn is offline
post #10 of 22 Old 04-27-2010, 10:25 AM
N2rock
N2rock's Avatar
Yeah- that was one of the mistakes they learned from the TJ
I would like to thank the TJ's for being the guinea pig, so that they could then build the JK perfect!
N2rock is offline
post #11 of 22 Old 04-27-2010, 10:26 AM
ronjenx
ronjenx's Avatar
Tow package
Nope. It didn't have it when he bought it. Tow package not on his build sheet, either.
ronjenx is offline
post #12 of 22 Old 04-27-2010, 10:29 AM
jake_blue
So then maybe this is a dumb question but chalk it up to being a Jeep newbie... why is the D35 unsuitable for the rear axle but still suitable for the front axle? You have to get the Rubicon to get a D44 front axle. Unless it just has to do with the duty rating and that the rear axle is always engaged versus the front axle only part-time.
"My other car is..." Who needs another car, I'm driving a Jeep!
jake_blue is offline
post #13 of 22 Old 04-27-2010, 10:31 AM
juiceparn
They don't use it in the front either. The front is a Dana 30 on all JK's except Rubis.
post #14 of 22 Old 04-27-2010, 10:38 AM
N2rock
N2rock's Avatar
Rubi, Auto, Tow package- those were the standard 4.10's in '07
Sounds like your friend found an oddball.
N2rock is offline
post #15 of 22 Old 04-27-2010, 10:39 AM
ronjenx
ronjenx's Avatar
He appreciates his good luck. He bought it after the Lifetime Warranty started, too
ronjenx is offline
upgraded rear ends 00dutchTJ TJ Wrangler Technical Forum 4 03-28-2010 10:06 PM
Should the Front Axle & Rear Axle be off centered to the passanger side by .5"? Lemmiwinks TJ Wrangler Technical Forum 3 07-07-2009 09:27 AM
Solid Axle Hd 44 Rear Axle Assembly SuperWade2 TJ Wrangler Technical Forum 128 06-05-2009 12:01 AM
Tire/Rear Axle question....out of alignment, rear axle "turned". (Thrust Angle) Sparty TJ Wrangler Technical Forum 5 09-19-2007 02:23 PM
upgraded axle shafts - what year/month? 1995? Mark_ZZ3 YJ Wrangler Technical Forum 5 01-13-2005 04:30 AM
