wheels to fit stock Sahara - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > wheels to fit stock Sahara
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffStuff Memorial Day Sale!Rugged Ridge Modular XHD Snorkel Now for both 3.8L and 3.6
Unread 05-23-2008, 07:29 AM   #1
specs
Am looking for a set of wheels, preferably in black, that will fit under the stock fender flares of a 2007 Sahara. I will be running the BF Goodrich T/A KM tires in 255/75/17.
I know the wheels need 4.5" of backspace, but what about the 45mm of offset that the stock wheels have? I do not plan on lifting and do offroad however not very agressivly.
What would you all suggest?
specs is offline   Reply With Quote
Unread 05-23-2008, 10:52 AM   #2
Prot
Gold Member
Prot's Avatar
Get the Helo Black Maxx 6 wheels. Mine are 17 X 9 with 4.5" backspacing. That's the only specs you need. I got mine at www.offroadtoystore.com Chris was great to deal with. Last year I paid $140 each for them. Do yourself a favor and get a set of gorilla nuts to go with them. Gorilla nuts run $30 for a set.
2007 Black Unlimited Sahara, Black Hard Top, Khaki Soft Top, Khaki Interior, 3" Black Diamond Springs and sway bar links, Rancho Steering Stabilizer, Helo Black Maxx 6 17 X 9 wheels, Goodyear Duratrac 315/70-17 Tires, Poly Peformance High Steer Kit, Poly Performance Upper and Lower Front and Rear Adjustable Control Arms, Poly Performance Rear Track Bar Bracket, Poly Performance Chromoly Tie Rod, Offset Upper Ball Joints, Mopar Front and Rear Bumpers and Skid Plate, Warn 9.5ti winch, ARB High Output Compressor with tire inflation kit, PIAA 510 SMR Fog Lights , Silverstar Headlights, Front Rancho 9000 shocks, Rear Bilstein 5100 series shocks, 5.13 gears, Kenwood DNX9990HD, Infinity 6020CS, Infinity 6022si, Alpine MRP-F250, JBL P1024, Alpine MRP-M650
Prot is offline   Reply With Quote
Unread 05-23-2008, 02:46 PM   #3
wrnglrguy
MotoMetal 951...17x9 with 4.5" backspacing....
wrnglrguy is offline   Reply With Quote
Unread 05-23-2008, 02:49 PM   #4
waterboarder
Hey, can I have your old wheels?
waterboarder is offline   Reply With Quote
Unread 05-23-2008, 02:54 PM   #5
Prot
Gold Member
Prot's Avatar
I also forgot to mention you need to get 5X5 bolt pattern. Wheels from previous models such as the TJ and YJ have 5 X 4.5 bolt pattern and will not fit, unless you use adapters.
