wheels? - JeepForum.com
post #1 of 13 Old 03-15-2010, 10:56 PM Thread Starter
drowe303
wheels?
So what 15" wheel will fit? I would like to get a 15x10. Preferably the steel pro comp street lock (bead lock copy) wheels.
drowe303 is offline
post #2 of 13 Old 03-15-2010, 11:12 PM
JLC08JK
What was I thinking?
JLC08JK's Avatar
There are lots of 16x10's available, I just looked at Pro Comp and they have them in all of their styles.
If you are going to use 12.5 or narrower tires most people go with an 8 inch rim. The narrow wheel helps to keep the bead seated when running low pressure and helps to protect the wheels edges from damage.
Jim
JLC08JK is offline
post #3 of 13 Old 03-16-2010, 12:36 AM Thread Starter
drowe303
So what about a 15x8 or 15x10 wheel? On quadratec.com, I cant find any 15" wheels for the jk.
drowe303 is offline
post #4 of 13 Old 03-16-2010, 12:38 AM Thread Starter
drowe303
nvm i found them on the pro comp website. I guess quadratec just doesnt carry them.
drowe303 is offline
post #5 of 13 Old 03-16-2010, 09:25 AM Thread Starter
drowe303
new question up top
drowe303 is offline
post #6 of 13 Old 03-16-2010, 11:06 AM
JLC08JK
JLC08JK's Avatar
15's are a tight fit on a JK.
You need back-space of 3" or less with steel wheels, I don't know if aluminum wheels will work.
With 15's you sometimes have to grind the front brake calipers for clearance.
There's a few threads around that show what you need to do, (search) and you shall find
Jim
JLC08JK is offline
post #7 of 13 Old 03-16-2010, 11:24 AM Thread Starter
drowe303
Alright thanks, Im going to try and make the 15" fit. Tires are cheaper also.
drowe303 is offline
post #8 of 13 Old 03-16-2010, 11:25 AM
mikebigh
mikebigh's Avatar
1987 YJ Wrangler
I run procomp series 97, 15" with a 3.75 backspacing. Works perfect. No grinding calipers, no rubbing anything. 15" wheels = cheaper tires.
Rock Krawler Suspensions
mikebigh is offline
post #9 of 13 Old 03-16-2010, 11:27 AM Thread Starter
drowe303
drowe303 is offline
post #10 of 13 Old 03-16-2010, 11:30 AM
mikebigh
mikebigh's Avatar
1987 YJ Wrangler
no, you need a bolt pattern of 5 on 5, not 5 on 5.5
mikebigh is offline
post #11 of 13 Old 03-16-2010, 11:31 AM Thread Starter
drowe303
The fourth one down is 5 on 5
drowe303 is offline
post #12 of 13 Old 03-16-2010, 11:33 AM
mikebigh
mikebigh's Avatar
1987 YJ Wrangler
oh werd, yeah your good.
mikebigh is offline
post #13 of 13 Old 03-16-2010, 11:37 AM Thread Starter
drowe303
Ok sweet, thanks.
drowe303 is offline
Picked my wheels, which size wheels and tires for a DD? JYogi JK Wrangler Technical Forum 7 09-11-2007 06:58 PM
Will the lug nuts for Ravine Wheels fit Moab Wheels? Thunderstrike TJ Wrangler Technical Forum 7 03-07-2007 05:47 PM
Everyday wheels and Trail wheels...balancing problems? Tacoma750 TJ Wrangler Technical Forum 1 08-19-2006 07:31 PM
Will the stock wagon wheels (15x7) with 31x10.50 tires fit on without wheels spacers? BIGCRAZYBELL TJ Wrangler Technical Forum 4 11-28-2004 12:10 AM
