Wheel & Tire Combo - JeepForum.com
post #1 of 4 Old 04-26-2007, 07:50 PM Thread Starter
Jayme
Wheel & Tire Combo
Newbie here, just bought my first Jeep. 07 Sahara with the 18" wheel package. Need to replace the rubber on it and MT's are to just to expensive for 18" wheels. My question is will 16" wheels fit with the rotors and calipers on this Jeep. Also what is the largest tire that will fit without rubbing. Any help would be appreciated.
Jayme is offline
post #2 of 4 Old 04-27-2007, 08:18 AM
Prot
Prot's Avatar
2014 JK Wrangler
You can go with 16, 17, or 18 inch wheels, as all of these are factory options. Some have reported certain 15's with appropriate backspacing will fit. Looks wise, I prefer 17" on the JK, especially the 4 door, but that's just an individual preference. There are more options available for 17" than there are for 18". Without a lift kit or anything, you can safely go with 32" as this is what comes on the Rubicon, and incidentally, is the same size you have now on your 18" wheels. Some people run 33", but report minor rubbing with heavy wheeling. It's hardly worth the expense of new tires for only a 1" gain in diameter. Budget boosts will raise the Jeep 2" and get you a little more clearance for cheap (enough for 33" without rubbing). A good 3" regular suspension lift will let you run 35" without a problem. If you stay with the 18" wheels and go with a 3" suspension lift and 35" tires, you will need wheel spacers. If you want aftermarket wheels, 17 X 9 with 4.5" backspacing works good with 315/70-17 tires (which is 35" for those of you in Rio Linda) and a 3" suspension lift. That combination will not require wheelspacers because 4.5" is adequate backspacing. Here is a picture of my BF Goodrich All Terrains 315/70-17 on 17 X 9 wheel. I had it just sitting on the ground in front of my truck, so there is something to reference to for size. My JK is still on order (since February 24)
2014 JKU Copperhead Pearl
Too many mods to list. Too awesome to sell.
Prot is offline
post #3 of 4 Old 04-27-2007, 08:28 AM
Malpaso
What are the best tires for snow, wide or skinny?
It's not that life is so short, it's that you're dead for so long.
Malpaso is offline
post #4 of 4 Old 04-27-2007, 08:28 AM
Bamoman
Bamoman's Avatar
here is mine with the 2.5 Teraflex BB and a 3/4 leveling spacer up front for leveling with Mickey Thompson MTZs 315/70 r17 on Pro comp 1069s 17x9s
easy lift to put on, took me less than 3 hours with the help of one. lift cost 364.00 spacer 30.00 5 tires and rims, mounted,balanced, Gorilla lugs, and no questionms asked Road Hazzard 2200 bucks? give or take?
BAMO
2007 4 Door Sahara---REDROCK BABY !!
(O|||||||O)
_____________________________________________
Auto|Sirius|Trac-lok Rear Diff |35 12.50 17 MT Radial MTZs| Pro Comp 1069 polished 17x9s|Teraflex 2.5 BB|3/4 Skyjacker leveling spacer
Trail Guide Nav|Amsteel Synthetic rope 100'|Shrockworks Alum Fairlead|Grab Handles x 4|Front Winch Bumper|Rear Bumper w Tire Carrier
Tow Grp|Shrockworks Rock Sliders|T-Max 9k Winch|Wireless Winch Remote|Roadboy Fog Lights
With more to come, always more....
Bamoman is offline
Wheel/Tire combo?? juiceparn Wrangler General Discussion 21 06-01-2008 09:00 PM
Wheel Tire combo Brett7 TJ Wrangler Technical Forum 2 06-06-2007 10:04 PM
tire wheel combo drm822 TJ Wrangler Technical Forum 2 01-31-2007 10:19 PM
31x10.5x15 wheel tire combo on stock tire carrier? ADIDAS TJ Wrangler Technical Forum 13 06-24-2005 11:20 AM
Help! Wheel/Tire combo... DaBurghBoy TJ Wrangler Technical Forum 4 09-26-2002 09:29 AM
