Wheel spacers - JeepForum.com
post #1 of 22 Old 03-20-2017, 08:30 PM Thread Starter
sinawalli
Wheel spacers
I have a 2.5" lift for my 2013 4 door Rubicon. I will have flat fenders. I want 285-75-17 tires. What is the least amount of wheel spacer I need for stock rims? 1", 1.25"? Or do I need 1.5"? Thanks.
sinawalli is offline
post #2 of 22 Old 03-20-2017, 10:22 PM
Moezer
2015 JK Wrangler
all u can do is get a full spacer that bolts to the wheel hub that would be 1.5 inch
Moezer is offline
post #3 of 22 Old 03-21-2017, 03:27 AM
SLADE
1.25" spacers will work fine.
1.5" spacers are most common.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline
post #4 of 22 Old 03-21-2017, 12:04 PM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
best balance of scrub to clearance considerations on OEM wheel widths is:
1.25 for 33 and down.
1.5 for 33.2 and up.
1.5 IS the most common but mainly because that matches the most common tire mod (35s) with AEM wheel BS to the OEM BS so requires no further thought! But smaller diameter tires factor in a lot. A scrub too wide wears bearings, steering ends and ball joint needlessly...
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #5 of 22 Old 03-30-2017, 02:19 AM
bluefoam
Q: I'm going to have 33's (285/70r17) with a 2" lift. Will 1.5" spacers be okay? They are easy to get here, other sizes not so much.
bluefoam is offline
post #6 of 22 Old 03-30-2017, 06:16 AM
GreenbayTJ06
2014 JK Wrangler
Quadratec has 1.75" spacers. I have a set and love them. 15k miles with no issues
Jeep is life
GreenbayTJ06 is offline
post #7 of 22 Old 03-31-2017, 03:05 PM
jwmbishop
jwmbishop's Avatar
2011 JK Wrangler
again YES but under 35s 1.25 is the better choice. Just as ^ uses a 1.75 - its not an instant killer to be a bit wide - it just means you stay up on maint more (due to stresses from track being unnecessarily wider).
Quadratec does also have the 1.25.
post #8 of 22 Old 04-01-2017, 08:35 PM
Bill123
2016 JK Wrangler
Try to keep it as close to 1" as possible. The wider you go, the more stress it places on your hubs, especially with larger and heavier wheels and tires.
2016 Wrangler Unlimited
2.5" Teraflex Lift
305/70-17 Toyo Open Country AT2
Fuel Lethal Wheels
Bill123 is offline
post #9 of 22 Old 04-02-2017, 02:35 AM
yoyoyo109
2015 JK Wrangler
Is there any difference between using spacers or wheels with better backspacing in reference to hub stress?
95 YJ 4.0L 5 speed
15 JKU Hard Rock Rubicon 6 speed
yoyoyo109 is offline
post #10 of 22 Old 04-02-2017, 08:37 AM
Bill123
2016 JK Wrangler
Yes, there is a difference. It's called offset. I could explain it, but it might be easier for you to look it up yourself.
2.5" Teraflex Lift
Fuel Lethal Wheels
Bill123 is offline
post #11 of 22 Old 04-02-2017, 12:00 PM
jwmbishop
jwmbishop's Avatar
2011 JK Wrangler
If total backspace is same (comparing a 5.75 backspace wheel with 1.25 spacer to a 4.50 backspace wheel, the inside side wall is in same place. Rim width then determines total track (the OEM wheel is an 8 inch so makes half inch narrower track than the most common size 17x9 aem) So a spaced oem at 1.25 is narrower than an aem at 4.50 (unless the aem is 17x8). Where I don't like spacers is unsprung weight - speeds up tires wearing out of balance, shock wear and bearing wear plus the spacers themselves adds several points of maintenance diligence. But do grant a way to get remaining life of tire without stresses of remount (especially if anticipated life is years of low miles), while budgeting out wheels...
post #12 of 22 Old 04-02-2017, 12:22 PM
222Doc
222Doc's Avatar
have to say that in the 6 plus years on our JKR and most of its 35k is off road and mostly hard trails on 35s on 15x8 at 3.75 BS. The unit bearings are still stock. The ball joints started getting bad at 15k and lowers by 20 were totally shot.
35k on it now. after a lot of mods to the front axle and steering, am now on 37s on 17x9 at 4.36 BS....see how long the units go from here. i plan to pack extras this summer when we head to Fordyce. i carry a full set of axles as well. just in case.
222Doc is offline
post #13 of 22 Old 04-03-2017, 11:59 AM
jwmbishop
jwmbishop's Avatar
2011 JK Wrangler
Great recap info. Seemed like low numbers until I remind myself your ratio is probably less than 5% at highway speed. And work it pretty hard on rocks... remember just like wind force - the faster you go the higher the frequency effect on all the moving stuff. With wind its double the speed quadruple the effect. rotating freqs is approximately double to triple (and very material dependant).
post #14 of 22 Old 04-03-2017, 06:28 PM
fooddude
5 years.
72k miles
No issues with spacers.
fooddude is offline
post #15 of 22 Old 04-06-2017, 10:23 AM
lloydsmale
2015 JK Wrangler
no real world difference. I would even think a steal wheel with the proper offset would be worse then an aluminum rim with spacers. More unsprung weight.
2015willys 4 cyl tj 2017 silverado yamaha grizzly, Polaris rzr 04 z06 vette, 600/800 crossfire cat
lloydsmale is offline
