Wheel spacers - Page 2 - JeepForum.com
Closed Thread
post #16 of 44 Old 01-01-2013, 01:29 PM
SubAtomicGenius
2011 JK Wrangler
Personally, I don't think that the 1.5" spacers do anything significant with regard to wear. The spacer, in effect, is the same as purchasing/installing wheels with different backspacing.
SubAtomicGenius is offline
post #17 of 44 Old 01-02-2013, 05:22 AM Thread Starter
tadam
How often do you recommend checking them? Every wheel rotation, more/less?
Originally Posted by 08rubinewb View Post
I have the 1.5 spacers on my stock rubi. I'll get you a picture tomorrow. Been wheeling with them no issues, but make sure you check and recheck them to assure they are tight. Also i don't know about other places but i was told that anything over a 1/4 inch here and they will not pass inspection. Not really an issue since you can take them off easily, or maybe it won't be an issue where you live.
2012 Call of Duty
tadam is offline
post #18 of 44 Old 01-02-2013, 06:59 AM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
If you apply locktite, every time you check them and break the locktite you'll need to reapply it.
Mine are custom milled 2" spacers and I've had them on for the past 10,000 miles and I've checked them once
My builds:
and
or follow us on
spyder6 is offline
post #19 of 44 Old 01-02-2013, 09:09 AM
Demp
Every Oil Change/Rotation should be fine. I checked the ones on my 2005 each time and never a single lugnut worked loose, I was also guilty of not using locktite
Demp is offline
post #20 of 44 Old 01-02-2013, 11:11 AM
SilverStreaker
I've been running spidertrax 1.5" spacers for a year now and no issues at all. I check the nuts each time I rotate my tires. A trick that I picked up on this forum is, since I did locktite them, is I set my torque wrench to 10 or 15 lbs under what I originally tightened them to and just bump them to make sure they are still tight (and not breaking the locktite hold). So far I haven't had to re-tighten them at all.
My Jeep - 2012 Wrangler Unlimited Sport S
My Wife's Jeep - 2007 Grand Cherokee - only mod - K&N Cold Air Intake system
SilverStreaker is offline
post #21 of 44 Old 01-02-2013, 04:24 PM
DECJ
Hey, that's a nice solution for generally checking the tightness without breaking the loctite.
BTW, here are some shots of my 1.5" Spidertrax spacers that I installed on my TJ in 2009 for the OP ...
2000 TJ, Dodge Magnum 5.9L V8/46RE auto, NV-241OR Rock-Trac tcase, Full-Traction LA, SwayLOK, 35" MT/R Kevlars on forged Center Line wheels, ARB's/Superior Super axles, etc.
DECJ is offline
post #22 of 44 Old 01-02-2013, 04:36 PM
battybluecb
I'd rock them.
My Build
battybluecb is offline
post #23 of 44 Old 01-02-2013, 04:39 PM
1shotwonder
What kind of brake pads are you running there?
Save 1000 elk. Smoke a wolf pack
Sometimes the light at the end of the tunnel is a muzzle flash
1shotwonder is offline
post #24 of 44 Old 01-02-2013, 04:48 PM
DECJ
Secret brake pads
Actually, that's a Vanco "Big Brake" kit that Blaine installed on my TJ. I don't specifically know whether this is strictly the "old" Vanco set-up or whether Blaine added any of the subsequent improvements that have led up to the latest version.
DECJ is offline
post #25 of 44 Old 01-02-2013, 05:27 PM
rick700raptor
2011 JK Wrangler
Any pics?
I'm probably not going to be doing any rock crawling, just two tracking, some mud and snow.
Thanks
On side note, you mentioned BFG mud tires and snow, I am assuming you have the BFG KM2 . I have them my Wrangler Unlimited and also on my 3/4 ton truck. They work well in deep snow and most everything else, but are Extremely bad on snow pack and ice. I like the tire a lot, but watch them on hard packed snow.
rick700raptor is offline
post #26 of 44 Old 01-02-2013, 05:44 PM
sstewart252
1978 CJ5
Older Jeeps
What about older Jeeps, are they safe ie CJ5 1978?
sstewart252 is offline
post #27 of 44 Old 01-02-2013, 06:00 PM
spyder6
spyder6's Avatar
2010
i dont see why not
My builds:
and
or follow us on
spyder6 is offline
post #28 of 44 Old 01-02-2013, 07:42 PM
erschrader
I had 1.5 spacers on my TJ with 33s went through 3 sets of wheel bearings in 2 years, they put stress on the wheel bearings because the tires are to far out from the Axel !
They look nice, but it starts to cost is to much !!!
erschrader is offline
post #29 of 44 Old 01-02-2013, 07:52 PM
spyder6
spyder6's Avatar
2010
lower offset wheels would do the same thing. dont blame the spacer
My builds:
and
or follow us on
spyder6 is offline
post #30 of 44 Old 01-02-2013, 08:45 PM
JKPaul
Why not just do it the right way and go with a wheel that will give you the backspacing you want. The wheels don't have to be checked at specific intervals to prevent failure. Call it peace of mind and safety for you, your loved ones and the family headed toward you in the other lane.
JKPaul is offline
Closed Thread
