Wheel Confusion by a foreigner - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Wheel Confusion by a foreigner
Stainless Steel Door Hinge PinsPoly Door Hinge BushingsLabor day sale @ rockridge 4wd! 8/29-9/1 site wide..promo
Unread 11-15-2010, 08:00 PM   #1
MACollegeKid
Hello Everyone,
This is my first post and I did read through the FAQ and did get a little smarter, but still do not fully get it. So, I do own a 2010 JK Sahara 2 door and want to get rid of the normal Dueler tires. I think I want to go with the GoodYear MT/R with Kevlar or the BFGoodrich Mud-Terrain Tire. As I own a Sahara, I thought about going with the stock 18inch rims, or should I change to 17inch? (if so, what would be the advantage?)
I dont want to lift the Jeep nor use wheel spacers, so I guess I will have to go with 32inch tires. Which would be also beneficial to fit the spare tire on the original mount, correct?
Last but not least, if it would be better to go with 17inch rims, should I use steel or aluminum?
Kind regards from the Swiss
MACollegeKid is offline   Reply With Quote
Unread 11-15-2010, 08:02 PM   #2
240Dbio
2010 JK Wrangler
steel if you want to go off roading. 17inch or smaller if you want the tires to be WAY CHEAPER. I got 17s because I planned on sticking with stock wheels, but changed my mind after I bought the tires.....oh well.
240Dbio is offline   Reply With Quote
Unread 11-16-2010, 03:44 AM   #3
1222
Make mine a Jeep!
1222's Avatar
Just wanted to say welcome to the forum.
1222 is offline   Reply With Quote
Unread 11-21-2010, 10:20 PM   #4
MACollegeKid
Thanks for the answers, even if just for a Hi. Now, I might think about a lift, but only 2". The tire guide says nothing about lifting if it will make the tires scratch if I lift the car by 2". Do I need wheel spacers with 33inch wheels and a 2inch lift? Are there any original Mopar wheel spacers?
Thanks
Unread 11-21-2010, 11:30 PM   #5
saharac
Smaller wheels are cheaper and cost of tires for them are also lower....
You can run run 33' tires with a stock JK with no rubbing, so you should be good with a 2" lift..
saharac is offline   Reply With Quote
