Whats going on.. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Whats going on..
Introducing MONSTALINERô UV Permanent DIY Roll On Bed LineCHASSIS SAVERô Labor Day 2 for 1 Sale!!!JKS Flex Connect in Actions!
Unread 02-28-2013, 06:36 PM   #1
Jeepzeroone
Whats going on..
just put new tires (285/70/17D1) rocky mountain ATS.
jeep rides great until
I come to a stop on a bumpy part of the road.
I have to fight it to keep it in my lane.
Just driving over the same spot on a green light its fine.
If i get the red and have to stop its a war.
Happens on any bumpy road i stop on.
Tires the issue here or something else?
Jeepzeroone is offline   Reply With Quote Quick reply to this message
Unread 02-28-2013, 06:48 PM   #2
Waltjason
2011 JK Wrangler
Sounds like a ball joint or steering stabilizer or something on the front end is loose. Are all your lug nuts tight? Or it could be the death wobble. How many miles do you have? Do you have a lift or other mods?
Waltjason is offline   Reply With Quote Quick reply to this message
Unread 02-28-2013, 06:50 PM   #3
Jeepzeroone
2 inch spacer lift ( fixing that) 2008 40k miles.
Lug nuts should be tight (ill check) got the tires last sat, had the tire place tighten them after 35 miles.
Unread 02-28-2013, 07:26 PM   #4
toxicwaste29
It might be a warped rotor on the side its pulling. Could be why it only pulls when braking. Also could it be the road, when i went home every day, semi's wore grove into the pavement so the jeep followed the groves and you could feel it move into the groves on its own?
toxicwaste29 is offline   Reply With Quote Quick reply to this message
Unread 02-28-2013, 08:35 PM   #5
Jeepzeroone
Dont think its a rotor it breaks fine on smooth roads.
not sure about the road, happens on a different road also
Not sure how i forgot this, put a winch and bumper on it two weeks ago.
Unread 03-01-2013, 04:26 AM   #6
Remmy18
Spacer lift, wider tires than you're used too and a heavy bumper and winch all will certainly have a negative response in road handling over stock, if that's what you're used too. I'm not saying there isn't another issue but I do know you will see a decrease in road handling characteristics with that setup. I had 13.50s and bumpers with winch on my last JK and it wandered all over from grooves in the road that would be worse when breaking.
Remmy18 is offline   Reply With Quote Quick reply to this message
Unread 03-01-2013, 04:28 AM   #7
Remmy18
Braking
Unread 03-01-2013, 10:02 AM   #8
jpin321
To much air in your new tires?
"Anyone who has never made a mistake has never tried anything new." ~Albert Einstein
My Jeep History -- 1980 CJ5 > 2005 TJ > 2013 JK > ?
jpin321 is offline   Reply With Quote Quick reply to this message
Unread 03-01-2013, 10:04 AM   #9
MeatCurtains
Whats happening is it is pulling towards the side with the most traction, and when the road is uneven and bumpy it will pull back and forth a little bit as you stop. It is a result of more contact patch on a wider tire. It actually will happen with any tire, but the bigger and wider the tire the more you feel it.
MeatCurtains is offline   Reply With Quote Quick reply to this message
Unread 03-01-2013, 11:07 AM   #10
SilverStreaker
I tend to agree this may be a big part of your problem. I know when I first got my 35's the tire shop filled them to the rated pressure and the drive home was a nightmare.
My Jeep - 2012 Wrangler Unlimited Sport S
[URL="http://www.jeepforum.com/forum/f22/its-started-silverstreaker-jk-build-thread-1306308/"]SilverStreaker Build Thread[/URL]
My Wife's Jeep - 2007 Grand Cherokee - only mod - K&N Cold Air Intake system
SilverStreaker is offline   Reply With Quote Quick reply to this message
Unread 03-01-2013, 11:11 AM   #11
jpin321
Yea when I first got my new tires they put 45 psi in 33s. I had to drive with both hands on the wheel to stay in the road. Every bump walked me toward the ditch lol.
Unread 03-01-2013, 04:26 PM   #12
Jeepzeroone
Ill take it down a pound or two in each tire and toy around with it this weekend.
Thank you all.
Unread 03-01-2013, 07:41 PM   #13
ljrubitm
2011 JK Wrangler
30 psi would be a good start. also check you toe.
ljrubitm is offline   Reply With Quote Quick reply to this message
Unread 03-01-2013, 08:47 PM   #14
Jeepzeroone
My toe looks fine, a bit ugly and maybe needs the nail trimmed but its in good shape. Even had my wife check it and she said its cute
But really thank you for the input i will have it checked out.
