What winch to purchase - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > What winch to purchase
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitBrand New! Quadratec LED Headlights!FS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 08-25-2014, 04:20 AM   #1
D700
Junior Member
D700's Avatar
2014 JK Wrangler
I just purchased an ARB front bumper and looking for a winch, I've always like Warn winches but I was wondering about the Smitybilt winches. Has anybody had any experiences with these winches? The winch will not be used that much.
Also what size do you guys recommend? I have 2014 JKU Rubi with soon to be on 35s.
Thank You
D700 is offline   Reply With Quote
Unread 08-25-2014, 10:16 AM   #2
jwmbishop
2011 JK Wrangler
There are two approaches to the decision. The higher the load rating of the winch - the higher the price of the winch, but the lower the amp draw on your system. You CAN save money be getting "just enough" winch for your weight - an 8000 lb will do. HOWEVER an 8000 winch pulling 5000 lbs will draw almost TWICE the load as a 13K winch pulling that same load. SO if you go with the lower minimal rate - you must wire it with heavier guage (higher install cost and weight) and should have a dual battery setup - an 8 wired with 0 gauge will do fine for occasional use. With a single battery I would recommend a 13K and it can be wired with 2GA.
I used a Smittybuilt 8k for about 2 years (used it ~17 times - a couple quite heavily - over that two years) with my dual battery setup - saw a bit of voltage drop - but with a 1 minute recovery per minute of winching (50% duty cycles) it was no problem..
I recently discovered a need for a winch on my trailer - and the Viper13K (kit includes rope, hooks, snatch block, fair lead, both wired and wireless controllers, winch cover and all mounting hardware) was on sale so I got it for the Jeep and will be putting the 8 on the trailer. I was amazed at how much better the 13 performs - at no voltage drop! I was on the button about 80% duty cycle and it never made a bad noise , slowed or gave any issues! And the wireless is SOOOOO handy giving the ability to rig and operate seamlessly.
Either rate - I HIGHLY recommend rope over steel cable. And I also recommend using a 600Amp solenoid to disconnect power (or a manual disconnect like flaming river - I used the Big Switch with lever exiting just under the right front turn signal to make a manual battery master disconnect on our Towed JK - on my Rubi I use a solenoid driven by a switch from the sPod) - live heavy guage wires on the bumper can be a MAJOR issue in even a "small" front end collision - not to mention can be very bad if used to vandalize the Jeep!!!!!!
J Wm Bishop EA, ASADE
How to start an online argument - express opinion - wait.
jwmbishop is offline   Reply With Quote
Unread 08-25-2014, 10:40 AM   #3
D700
Junior Member
D700's Avatar
2014 JK Wrangler
Lots of information.
Thank You
Unread 08-25-2014, 02:25 PM   #4
D700
Junior Member
D700's Avatar
2014 JK Wrangler
Any opinions on this one?
http://www.quadratec.com/products/92122_1310_07.htm
Unread 08-25-2014, 03:03 PM   #5
jwmbishop
2011 JK Wrangler
No opinion - but its more expensive, has a larger profile and draws more amperage at 5000 lb. than the viper max 13000. Also - the connections are UNDER the motor - much harder to service. check the viper out at moto alliance dot com...
That 10K is about the smallest I would go with a single battery setup.
Unread 08-25-2014, 03:11 PM   #6
D700
Junior Member
D700's Avatar
2014 JK Wrangler
No opinion - but its 100 bucks more expensive, has a larger profile and draws more amperage at 5000 lb. than the viper max 13000.
Thats about the smallest I would go with a single battery setup.
So I would assume that the Viper Max 13000 is better?
Unread 08-25-2014, 03:23 PM   #7
jwmbishop
2011 JK Wrangler
For me it was a better choice. Drawing 175 amps at 4000 lb loads the system a lot less than 220 amps at same load. That was important to me as low voltage issues and the JK computer don't mix well. Either one is a good choice but you should look at the manuals for each one - and compare the load at number of wraps, draw at load etc to make a decision that fits YOUR needs. And important to me was the rate - noot just to winch MY vehicle - but others! One of the rigs I wheel with comes in at 5500 when loaded!
Unread 08-25-2014, 03:51 PM   #8
wilywillie
wilywillie's Avatar
Here are a couple write ups. Bishop knows his Jeeps, but my first thought was about how much MORE a winch weighs the heavier its capacity.
My Smitty saved me several times, but I opted for Warn's M8000 after a few years. Piece of mind is an issue when I'm alone in the Wilderness, and I didn't have that with the foreign made Smitty. That's just me.
(people flame about components of US made winches being Chinese, but that's beside the point)
http://www.4wheelparts.com/off-road/winchadvisor.aspx
http://www.offroaders.com/tech/winch...sion-chart.htm
I'm just here for the gasoline. --Max
http://i582.photobucket.com/albums/s...earthquake.jpg
wilywillie is offline   Reply With Quote
Unread 08-25-2014, 04:15 PM   #9
rubicon17
If you can afford a 2014 and a arb bumper you can afford a quality winch. Warn or ramsey! Like mentioned cheap ones work and sometimes they dont. But chances are that warns gonna work rain or shine, wet or dry. I got a used xd9000i and ive had it for years myself and it has never let me down ever!
Selling: tj rubicon locker, tatton drive shaft,xseries bushings
rubicon17 is online now   Reply With Quote
Unread 08-25-2014, 04:21 PM   #10
D700
Junior Member
D700's Avatar
2014 JK Wrangler
Thanks for the info. I'm a fan of Warn but looking at the Smitys also. I have a 4DR the jeep weighs just over 4k. How do you choose a winch? Do you double the weight?
Unread 08-25-2014, 08:48 PM   #11
blackwidow03
2010 JK Wrangler
I have a warn vr8000 and it does what I ask. I'm happy with it.
blackwidow03 is offline   Reply With Quote
Unread 08-26-2014, 01:51 AM   #12
D700
Junior Member
D700's Avatar
2014 JK Wrangler
I've decided on a Warn winch.
Thank You all for the advice & info
Unread 08-26-2014, 05:50 AM   #13
SLADE
Make water proofing a priority. The Warn name alone won't prevent water damage. The bottom line Warn models are not waterproofed.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is online now   Reply With Quote
Unread 08-26-2014, 07:19 AM   #14
HappyTrails
Registered Voter w/ID
HappyTrails's Avatar
I have the same winch. Works for me. Doesn't work so well for those damn JKU's I'm always having to winch up the hill. If I knew I'd always be using it on someone else, those JKU's, I'd have gone a little stronger, 10K or 12K. But that is what the snatch block is for.
Definitely spend the $$ on synthetic rope. It costs more than cable, but the safety benefits seriously outweigh the lower costs of cable. An emergency room visit costs more than a new winch!
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel lift, Fox 2.0 shocks, 37" Nittos, 5.38's, River Raider skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Re-inventing the circle and straight line.
HappyTrails is offline   Reply With Quote
Unread 08-26-2014, 08:06 AM   #15
D700
Junior Member
D700's Avatar
2014 JK Wrangler
Im ordering a Warn Zeon 8000S.
