What speed OK to change from 2wd to 4wd? - JeepForum.com
post #1 of 27 Old 07-29-2008, 07:33 PM Thread Starter
strategydude
How fast should or can you be going when you change from 2wd to 4wd high? What about from 4wd high to 4wd low?
strategydude is offline
post #2 of 27 Old 07-29-2008, 07:35 PM
nwm52
nwm52's Avatar
I think it's at 55 mph.
edit: Somehow I messed the 4-low part. Broken_Soldier is right, only stopped or a very very slow roll.
nwm52 is offline
post #3 of 27 Old 07-29-2008, 07:43 PM
Broken_Soldier
...and from 4hi to 4lo 1-2 mph. Just a slight roll is all that's needed for smooth transition, though it can be done (hit or miss) while stopped.
Strength and honor.
Broken_Soldier is offline
post #4 of 27 Old 07-29-2008, 07:45 PM
TheGillz
All this was in my owners manual...maybe they are cutting costs by not including a manual?
2008 Unlimited X-Jeep Green:Dual Top:6-Spd:Tow-Group:Trac-loc Lim Slip:Hauls: HOT wife, two girls (11&7), Newf
.....|||||__.||._|__-
0lllllll0
.....|/\\_|__|---------<=##=>
..... (o)_)-)_)........(o)_))_(o)_))_)
TheGillz is offline
post #5 of 27 Old 07-29-2008, 08:26 PM
SoCalJK
SoCalJK's Avatar
Unless it has changed from 2007 it is in the manual. Page 268 in the 2007 manual lists this info.
2007 Sahara Unlimited
4x4, Auto, Jeep Green, Tow Package, Soft top, 3 inch spring lift, MBRP Catback
SoCalJK is offline
post #6 of 27 Old 07-29-2008, 11:21 PM
Broken_Soldier
He's new, I just figured he wanted to ask a question to get his feet wet here.
Strength and honor.
post #7 of 27 Old 07-30-2008, 06:50 AM
WVUJeeper
My salesman actually walked me through the whole thing. 2wd to 4hi at less than 55, and 4hi to 4lo at VERY slow/stopped. The only problem with stopped if the gears don't mesh right on the shift. He even had me do it on the lot to make sure that I was comfortable with it. He drove an '06 Orange LG with 6" of lift and some swampers.
- Fletcher: Oil Field Trash Extraordinaire
Originally Posted by VetteDriver View Post
BTW, what's with the "if you haven't driven one shut up" nonsense? How can we have a good internet fight if experience and knowledge are going to be a requirement?
'08 Rescue Green Unlimited X - Hard Top, 3.73 gears, Limited Slip, Infinity 7 speaker system, KC Slimlite Long Range, Cobra CB, Rough Country 2.5" BB, 35" BFG KM2's on ProComp 7089's. Fenderless and proud!
My build thread:
RESCUE GREEN JEEP CLUB MEMBER #25
COLORADO JEEP CLUB MEMBER # 1001
WVUJeeper is offline
post #8 of 27 Old 07-30-2008, 10:54 AM
possumface
i would think you can shift from 2wd to 4wd hi at any speed
its on the "fly" 55mph isn't flying
possumface is offline
post #9 of 27 Old 07-30-2008, 11:00 AM
Seabass004
Once your in 4WH and 4Low, what is the max speed you can drive?.....without tearing things up?
Seabass004 is offline
post #10 of 27 Old 07-30-2008, 11:43 AM
BuzzHog
BuzzHog's Avatar
You only want to be in 4WD when the surface you are driving on has enough slippage to allow the front wheels to slip so as not to BIND the driveline during tight turns...
Don't forget the Jeep Wave!!
BuzzHog is offline
post #11 of 27 Old 07-30-2008, 11:54 AM
Avian
I use 4LO just about every time Im off road (it reduces the amount of clutching I need to do). Its about 50/50 trying to put it in/ out stopped, and anything over 4 mph results in a loud clunk.
It just baffles my friend that I can throw 4HI in on the fly. He always comes to a stop with his chevy. He thinks its the coolest thing ever.
Detonator Yellow JK-X
150w windshield mount long range KC's
bumper mount Hella 500's/ 130w KC drivers
Uniden Bearcat CB/PA
Mopar bumper
Moabs/ BFG KM's
Avian is offline
post #12 of 27 Old 07-30-2008, 12:13 PM
ChicagoGuy
Team XBOX
ChicagoGuy's Avatar
I'm trying to figure out when I'd need to shift from 2H to 4H at 55 MPH?!?!
- Bill (formerly VetteDriver)
ChicagoGuy is offline
post #13 of 27 Old 07-30-2008, 12:20 PM
Avian
When you feel the sudden urge to baja while driving down a desert highway?
Mopar bumper
Moabs/ BFG KM's
Avian is offline
post #14 of 27 Old 07-30-2008, 01:06 PM
Tornado
In a manual trans, is it necessary to push the clutch in when going from 2wd to 4hi?
I don't think it would be, but I just do and was wondering if it was necessary.
Tornado is offline
post #15 of 27 Old 07-30-2008, 01:07 PM
XCELER8
Under 55 for 4hi, about 2 for 4lo
2008 Jeep Green Metallic X 2 door
Firefighters Jeep Club
XCELER8 is offline
6-Speed Manual Oil Change Help BPD119 TJ Wrangler Technical Forum 8 11-26-2007 09:42 PM
Speed change dieselcrackel TJ Wrangler Technical Forum 7 08-17-2006 09:07 PM
6-speed Fluid Change HELP!! JeepinYahoo TJ Wrangler Technical Forum 1 04-21-2006 12:33 AM
How often do I have to change the oil in the 4-speed auto? zband TJ Wrangler Technical Forum 5 11-26-2003 03:47 PM
Looking to change to a 5 speed. Phantom5oh TJ Wrangler Technical Forum 2 07-14-2003 07:10 AM
