What size tires and lift should I get on my 2011 Sport? - JeepForum.com
post #1 of 12 Old 07-08-2013, 09:10 AM Thread Starter
timmah1493
Hey everyone,
I want to upgrade my 2011 Wrangler Sport by getting bigger offroading tires. I have a few questions regarding this:
1) What size tires? I know this is a broad question, so let me elaborate. I would like to significantly enhance my Jeep's offroading capabilities without turning it into a complete monster truck. Price is not too big an issue, but obviously saving money is nice. So basically I'm looking for the happy medium. From what I have seen and read, my gut feeling would be to get 33 or 35 inch tires, but I'm not sure. From here, can anyone recommend good brands?
2) What size suspension lift? I don't want to risk any rubbing. What's the general rule for tire size vs lift size? Again, can anyone recommend good brands? There are so many different lift choices, how do you pick one?
3) With bigger tires, do I need to upgrade my axles or gearing? I've read I do and I've read I don't on different threads. If so, what should I be looking into?
Thanks in advance!
timmah1493 is offline
post #2 of 12 Old 07-08-2013, 09:19 AM
222Doc
222Doc's Avatar
have you read the FAQ's.?
222Doc is offline
post #3 of 12 Old 07-08-2013, 09:51 AM
jchappy
2011 JK Wrangler
Most people will tell you to go 35's and that would be the case if you had the Dana44 combo but you don't. With the D30 front axle the biggest i would go is 33in tires but that just my opinion.
MY NEW JEEP- 2011 JEEP JKUR, Body Armor front bumper, Warn XD9000I winch, Synthetic winch line,XRC Rear Bumper W/Tire carrier, OBA W/1Gal Tank, Terafex 2.5in spring lift, Bilstein 5100 shocks,GY 315/70R17 Duratracs, 4.88 G2 gears, Cobra 75 CB
MY OLD JEEP-1999 Wrangler Sport 4.0L, 4" Pro Comp Lift, 33" BFG's, 8K winch, SYE, Viking soft top, onboard CO2 and all the recovery straps and equipment
jchappy is offline
post #4 of 12 Old 07-08-2013, 10:25 AM
JoonHoss
2011 JK Wrangler
just my humble opinion, but don't go to 35's unless you really want them, or really need them.
a lift of under 3" will suit you fine; look for a budget boost (coil spacers only) to either lift (same size front and back) or level (more front, less rear)
33's look/ fit nicely (I'm biased) with the jeep leveled (but you will likely want spacers for your stock wheels, or an aftermarket wheel with different backspacing to clear the suspension)
front leveling kit only, 33's
front leveling kit, plus 2" coils front and rear, 33's
I did not regear, and have been ok with the driveability of this combo as-is. most everyone will tell you you should regear when going to 35's (and many recommend it with 33's as well)
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is offline
post #5 of 12 Old 07-08-2013, 10:27 AM
RogueStatus
lots of people run 35s on the d30 front axle, they say anything above and you should strongly consider moving up to a 44 for the front according to what i've read.
lots of people like teraflex/aev suspension it seems. I run BDS 3" on my sahara and like it. If i was doing it again though i would probably go with teraflex.
If you want to avoid replacing a lot of stuff, i would do anything more then a 3" lift. once you do more, more things need replaced.
Jeep-less again
RogueStatus is offline
post #6 of 12 Old 07-09-2013, 08:34 AM
jepen
2010 JK Wrangler
Agreed. If you want 35's, get them otherwise you'll be kicking yourself every time you see a JK on 35's pass by. Otherwise, 33's do look great also.
2013 goal: To stop being a mall crawler and start getting this JK dirty.
jepen is offline
post #7 of 12 Old 07-09-2013, 08:41 AM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
As a JK newbie, please check out the FAQs as a lot of your questions are addressed there. That said, get the size of tires you either need to show off (mall crawler or DD) or to off road the trails you want to. How you mod your JK depends on what kind of driving you want to do,and lift no more than needed to accommodate tires if you off-road to keep the COG low.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #8 of 12 Old 07-09-2013, 08:57 AM
JTPhoto
JTPhoto's Avatar
So, my suggestion is to look up the thread where everyone is posting pics of there Jeeps. (there is one for 2dr and 4dr) find the the look you are going for i.e. tire, wheel, height combo etc and ask the owners what they run so you can replicate the look.. EVERYONE has their opinion but everyone is not you.. Let the mods begin.
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, D44HD/J8 w/ OX locker and RCVs, 37x12.50x17 Pitbull Rockers on ProComp 2635 Predator Alloys, AEV Prem Bumper, Smitty X2O 12K ETC..
JTPhoto is offline
post #9 of 12 Old 07-09-2013, 10:04 AM
McKBrew
JK Wrangler
Back when I had the JK, I ran 295/(?)/17 Nitto Terra Grapplers for a while. I also ended up with a broken front axle housing.
I personally think 33" tires look great on a JK and will meet "most" offroading needs while allowing for decent mpg.
If fuel economy isn't a concern, then go for 35"s.
Either way, I would recommend looking at some sleeves for the front axle. I am sure that the vast majority of people have not or possibly will not suffer a broken axle housing, but it can happen. And it doesn't take "hardcore" abuse for it to occur. That's just my own personal feeling.
When I get another JK, it's likely going to be 33"s after a while, but I'm going to invest in bumpers/recovery first.
McKBrew is offline
post #10 of 12 Old 07-09-2013, 10:37 AM
JIMBOX
All good info-but
You don't say what your tranny is--stick/auto and
If auto, you're going to need regearing, even with 33" tires, if stick, you can run any gear you want to, but your MPG is goin DOWN-
My '08 JKUR runs 33.6" Hankooks/w regear and there's nowhere I can't go (he heh, be reasonable)-
I can get up to 18mpg and 14.9mpg towing--
Every jeep is different and every owner has different wants/needs---do a lotta homework-
As soon as you pick any tire larger than your stock 32" BFGs, your gonna wanna change many things-if auto, the tranny is a PITA/w stock gears--even 4.10 !
Good luck
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #11 of 12 Old 07-09-2013, 02:08 PM
HappyTrails
Good luck
JIMBO
True dat! (if it is a 3.8L engine and associated auto tranny)
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Rancho 9000XL shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Political Correctness offends me.
HappyTrails is offline
post #12 of 12 Old 07-09-2013, 08:13 PM Thread Starter
timmah1493
All great info guys, really appreciate it! Great pics too!
Going to do some more research, but this is a good start
Thanks!
lift , sport , suspension , tires , upgrade
