What's the Real Worth of the Lifetime Powertrain Warranty? - Page 2 - JeepForum.com
post #16 of 29 Old 07-19-2009, 08:57 AM
N2rock
N2rock's Avatar
My diffs are not covered anymore Installed Aussie locker in front, OX locker in rear... And will be regearing soon.
Now, if this was a BS warranty, would they have put some type of obscure requirement in the fine print? I don't think so, they want to get out of it if possible
Well as I stated before... They don't need to attempt to get out of it really. 95% of new buyers will get rid of it within the first 5 years. So that only leaves them 5% to worry about. Now of that remaining 5%, a pretty good percentage of those will modify their rigs to the point of voiding the warranty. Another percentage will wheel them so hard that the failures can be attributed to wheeling. Another percentage will be in accidents where the JK gets totalled. And lastly you'll have a percentage of "dumb" people that won't notice the 5 year inspection requirement in the warranty. So in the end, Chrysler (or whoever owns Jeep down the road) will only have to deal with a very small amount of engine/powertrain warranty claims.
for details and info on our JK's, check out
His: '07 Unlimited X, Jeep Green, Hardtop, auto, 5.13, 2.5" RC lift and too many mods to list
Hers: '08 X Red Rock, soft top, auto. Bunch of mods
Originally Posted by tlgraham View Post
If you made a snuggy out of a Shamwow, ....would you have to get up off the couch to pee?
Originally Posted by Deepskyy View Post
At this point if Obama tried to move a little to the right, he would trip over Stalin's corpse.
N2rock is offline
post #17 of 29 Old 07-19-2009, 09:06 AM
stick_it_
2009 JK Wrangler
I absolutely agree with that statement.
Also keep in mind that if you mod your Jeep using MOPAR products and have a Chrysler dealer install them, warranty is maintained unless MOPAR specifically states that that part voids the warranty.
stick_it_ is offline
post #18 of 29 Old 07-20-2009, 01:32 AM
Prot
Prot's Avatar
2014 JK Wrangler
Rings and cylinder walls wear out. It is inherent in the design. You have one piece of metal that sprung to press against another piece of metal so hard that it makes an air tight seal. There is a thin layer of oil between the two pieces of metal and oil today is better than oil fifty years ago. Still, the coefficient of friction is not zero. Anytime there is friction between two objects, one or both exhibits some wear after a certain period of time. If you can accept that things like brake pads and clutches are wear items, it is not a leap to accept that rings and cylinders also wear out. It is impossible to build piston rings and cylinders that do not wear. The Wankel Rotary engine is a good example of two parts wearing. The seals between the rotors and combustion chamber are notorious for leaks, despite the many years the engine has been in production. Their wear rate is much much higher than a piston engine.
If the warranty was that extensive, I would think their ads would be proclaiming "This is the last vehicle you will ever have to buy!" Wouldn't that be a hell of a selling point and something to capitalize on?
My Jeep only came with 3 year / 36,000 mile warranty. I'm not worried about it. If I was, I probably would not be able to fun in my Jeep.
2014 JKU Copperhead Pearl
Too many mods to list. Too awesome to sell.
Prot is offline
post #19 of 29 Old 07-20-2009, 06:11 AM
stick_it_
2009 JK Wrangler
LOL!!! To tell you the truth, the first thing that I thought when I read your post in this thread was, "this guy doesn't have the lifetime warranty."
post #20 of 29 Old 07-21-2009, 11:29 PM
RRCP08JK
2010 JK Wrangler
Covers the water pump too which I was surprised at. It looks like it covers leaks as well which is nice. I always hated a leaking valve cover or rear main seal on cars I have owned in the past.
The 50,000 mile check-up at no cost is absolutely reasonable IMHO. It allows the dealer to catch a mole before it possibly becomes a mountain. And it isn't in fine print, it's clearly spelled out as a requirement in the warranty docs.
"It is the spirit of men who follow and of the man who leads that gains the victory" ~ George S. Patton
RRCP08JK is offline
post #21 of 29 Old 07-22-2009, 03:42 AM
Hilldweller
2014 JK Wrangler
Is it 5 years? Or is it 50,000 miles? or is it either/both?
I thought it was just 5 years.
My Jeep is turns 15 months old today and has over 36,000 miles on it....
Safety fast,
Security is mostly a superstition. It does not exist in nature, nor do the children of men as a whole experience it. Avoiding danger is no safer in the long run than outright exposure. Life is either a daring adventure, or nothing.- Helen Keller
Hilldweller is offline
post #22 of 29 Old 07-22-2009, 07:04 AM
stick_it_
2009 JK Wrangler
To maintain the lifetime - it is a powertrain inspection every 5 years and maintenance at the the recommended service intervals.
To protect yourself, I recommend keeping documentation of all maintenance done on the vehicle so you can PROVE that the schedule has been followed. If you don't have it and they ask to see it, you could end up with a voided warranty. Just my .02.
post #23 of 29 Old 07-22-2009, 04:17 PM
RRCP08JK
2010 JK Wrangler
5 years. You are correct - my bad. In the Warranty booklet it has the 5, 10, 15, 20, 25 year check up pages to maintain the warranty.
RRCP08JK is offline
post #24 of 29 Old 12-06-2010, 02:39 PM
tjpoolman
2007 TJ Wrangler
lifetime warranty
Has anyone on here actually had to use the lifetime warranty? Engine failure, trans, etc?? If so, was it a huge drawnout painful process? I lease a 2007 wrangler unlimited. Currently 83K miles. There is something really wrong with engine. knocking etc. I am vacationing in FL and live in MA. I had it towed to a local dealer. And started researching. I have found that any vehicle purchased or leased after July 26 2007 would automatically and at no charge will come with a lifetime warranty. It doesn`t say anything about miles, but you do have to be the original purchaser or leasee. Maybe they are figuring on the lease ending and or the vehicle being sold (lifetime warranty not transferrable). I have done regular oil changes like clockwork every 3K. Probably 30 oil changes but not at a jeep dealer...3-4 at jiffy lube....3-4 my mechanic...3-4 speedy....3-4 turbo lube etc.....12-15 I did myself in my backyard. I`m hoping they are not anal about records/receipts because most of them are at my primary residence 1200 miles away!!! I suppose I could go online and get all my credit card statements for the past 3yrs.... Changed air filter when I was supposed to, etc. Did the rear brakes over. Replaced tires with the same goodyear 17" that came with it new. And put gas in it. It has otherwise been 100% worry-free and a pleasure to drive. I have done no other modifications. The end of my lease was a few months ago and instead of buying it outright, I choose to lease for one more year, and plan to buy and the end of the total 4 yr lease. I am over the lease mileage but figured that wouldn`t matter because mileage is not mentioned in the lifetime warranty. Plus if i`m buying it at the end of the lease, I won`t be charged the miles. Any thoughts you have on this would be appreciated. The jeep has been with the dealer since Friday. It is now Monday late afternoon and i havn`t received a call from dealer. I left messages. Thanks
tjpoolman is offline
post #25 of 29 Old 06-01-2013, 06:14 PM
devilsfiddle
2008 jk
I just got my 5 year power train inspection and didn't bring any paperwork with me and they still honored it for me. The service guy said every 5 years to bring it in and they will honor it. I plan on keeping it forever. Or a good 15 years. He said the warranty covers the engine and transmission.
JK 08 X
devilsfiddle is offline
post #26 of 29 Old 06-01-2013, 06:18 PM
devilsfiddle
I have not had to actually use the warranty though, in answer to your question.
JK 08 X
post #27 of 29 Old 06-01-2013, 08:52 PM
Mol
Disclaimer: I'm Polish
Mol's Avatar
Holy thread throwback
Wish I had the powertrain on my '08...bought it used off lease in 2010 with 38K miles, replaced the motor a couple months ago with 58K miles.
Mol is offline
post #28 of 29 Old 06-01-2013, 09:42 PM
jmb6420
Engr. & Mechanic 08 Rubi
jmb6420's Avatar
I bought my 08 used two years ago with 32k miles on it. It had been out of warranty for about 6 months. Bought the Lifetime Powertrain Service contract for it for 1400 and 3 months later had the transmission rebuilt under the service contract. It's already paid for itself and I still have a lifetime to go! Covers engine, tranny, transfer case, drive lines and axles. I hope I never need it again, but it's nice to know it's there.
Mike
08 Rubicon
"You can't fix stupid" Ron White
°ɹǝʌo ǝɯ dıןɟ 'sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
jmb6420 is offline
post #29 of 29 Old 06-01-2013, 10:57 PM
wilywillie
Just in the last 5 weeks, I've had to replace my front driveshaft and my front wheel/unit bearings. I did it myself, but I'd hate to find out the dealer would have covered it
...again, the dealer I used in Richmond (Pearson) was totally mod friendly, and some of the mechanics had Jeeps/boggers; but the one here (Browns), even though they sell AEV bling, doesn't strike me that way.
I'm just here for the gasoline. --Max
wilywillie is offline
Lifetime Powertrain Warranty going away for 2010 BRICKTOP2 JK Wrangler Technical Forum 15 08-20-2009 09:11 PM
Lifetime Powertrain Warranty Question 7elmdale JK Wrangler Technical Forum 10 12-21-2008 07:56 AM
Lifetime Powertrain Warranty?? Dugzilla TJ Wrangler Technical Forum 1 09-24-2007 07:00 PM
Lifetime Powertrain Warranty && Supercharger = ??? ammonm JK Wrangler Technical Forum 7 08-05-2007 04:12 PM
Lifetime powertrain warranty! IndyJpr JK Wrangler Technical Forum 63 08-03-2007 12:23 PM
