What's needed to run 37's on a JK unlimited rubicon - JeepForum.com
post #1 of 6 Old 10-12-2009, 07:43 PM Thread Starter
johnjk
I got rid of my TJ and I'm new to JK's. I'm thinking about buying an unlimited rubicon. I already know I'm going to want 37's, mostly because of the breakover angle.
I've been reading a good bit, but I haven't found a clear answer of exactly what's needed to reliably run 37's on an unlimited rubicon.
johnjk is offline
post #2 of 6 Old 10-12-2009, 08:14 PM
Imped
Imped's Avatar
5.13's or 5.38's, a couple inches of lift, trimmed fender flares, and the tires. Maybe weld the tubes and guesset the C's on the front axle.
OlllllllO
IndyORV
Imped is offline
post #3 of 6 Old 10-12-2009, 09:06 PM
denvermitch
2009 JK Wrangler
Lots of money
denvermitch is offline
post #4 of 6 Old 10-12-2009, 09:34 PM
Liquor
BOUNTY HUNTER
Liquor's Avatar
2008 XK Commander
5.13 and youll be fine, (3.8L 6sp, 5.13 and 39" tires here with no problems - kevin at 4ws.com has 42" and 5.13 with hemi auto with no complaints)
4" lift (i vote on Rock Krawler 3.5" Long Arm w/HD tie rod, HD drag link, and bump stops - mgiht as well do it right at get a Long Arm lift)
fenders (i vote on Xenon)
you may have to trim the pinch seam. it can dig into rear tires on full flex. check my build thread for pics of my tire rub issues (link in sig)
Dana 44 front and rear axles, sleeve them, C gusset them, chromoly shafts install, lockers (i like ARB) - if you like to wheel it hard and often, Dana 60's then
fat gas card. even with gears you will have to refill more often. i went from 19-23 mpg to 11-13 mpg. its a Jeep not a Prius
front and rear 1310 drive shafts (i vote on tom woods)
may have to trim front bumper to prevent tire rub. or just get a new bumper
think thats it. with right wheel tire combo you shouldnt have to use wheel spacers. (17x8.5 4.5" backspacing walker evans beadlocks with 39x14.50 pitbull maddogs and i dont have the issues others complain about.) most everyone has had to trim the pinch seam, i havent done this yet.
More information on your JK and what you plan to use it for would be very helpful for us...
2007 Unlimited Sahara Steel Blue - I call it "CAIN"
2002 TJ Sport - Sold
"CAIN" '07 Jeep JK 426 HEMI 685 HP & 650 ft lbs
Your Jeep and Gaming Social Network
2012 Sponsors:
Magazine Feature:
Liquor is offline
post #5 of 6 Old 10-12-2009, 09:41 PM
JKChad
If you run an auto trans.. go with 5:38 gears and dont look back. Lift wise, 3" with trimmed fenders and some adjustment to the pinch seem will do great.. you can always go with more lift, but I like my COG low as I can.. Definitely upgrade the axles, but I'm more of a proactive person then reactive. Other then that you might wanna throw in a set of drive shafts, or atleast the front. then wheel the heck out of it!
I'm still get 15-16mpg with my 35 mtr's w/Kevlar. Gears should put me right back to the 16-17mpg range.
-Chad-
JKChad is offline
post #6 of 6 Old 10-13-2009, 04:07 AM
LHS-Cowboy
DETN8R
LHS-Cowboy's Avatar
3.5 inches of lift, trimmed fenders, fixed the pinch weld and I still had to add an inch to the bump stops to keep them from rubbing. I will be adding another inch of lift to get the maximum flex from my lift. Doing a custom crossmember and skid plate can gain you at least 2.5 inches of breakover clearance also.
'08 DETN8R Yellow Unlimited Rubi
6-Spd / Soft top / Power
Installed:
R.E. Modified 3.5 Super Flex Kit to 4+/Ft. & Rr. U-joint driveshafts/Full Traction Rear Adj. Trackbar/Custom Ft. Heim Joint Adj. Trackbar/Rancho 9000XL shocks/Yukon 4.88 Gears & Superior Rear Axle Shafts/37" Pitt Bull Rockers on Custom Allied Beadlocks/Poly Perf. Rock Sliders/Shrockworks Mid Ft. & Rear Bumper/Custom Trans. Crossmember and Skid/Custom High Steer with PSC Hydro Assist/Plumbed Warn PowerPlant HP/Cobra 75 WS XT C.B./Bully Dog Programmer/Custom Exhaust/Dual Optimas/48" X-treme Hi-Lift Jack on Custom Rear Swing Away Carrier/...
____oooo
[ l_,[____],
l---L -[
OlllllllO]
( )_) ( )_)--)_)
LHS-Cowboy is offline
Surf Blue Unlimited on 37's Antenna_X JK Wrangler Technical Forum 59 11-06-2009 07:22 AM
How much backspacing is needed for 37's? chadroc YJ Wrangler Technical Forum 7 11-21-2008 05:12 PM
37's on an Unlimited with a 4" Lift anyone? PSYCH0 JK Wrangler Technical Forum 8 06-09-2008 11:09 AM
37's, and whats needed Jeepxj96 TJ Wrangler Technical Forum 7 09-26-2004 11:34 AM
Unlimited on 37's.... MasterCujo TJ Wrangler Technical Forum 3 08-24-2004 10:42 AM
