What lift for 2012 Jeep with 33's? - JeepForum.com
post #1 of 151 Old 05-03-2013, 06:31 PM Thread Starter
RiseAbove
I just got my first jeep--2012 Jeep with 33's. I absolutely love it. I am not wanting to change much as I hardly have the opportunity to go off-road and my primary use is daily driving. I want to put a lift on it however (mostly for looks). I don't want more than a 3-4" lift. I am a newbie and don't know much so here are my questions:
1. Should I go suspension or body lift? I have hear suspension is better and bodylifts make the jeep "bouncy." Is a suspension lift worth the extra money?
2. How high of a lift can I get without changing anything? I don't want to modify a thing. I just want to get the lift and be good to go. I have read at a certain point you have to get lines, bars, etc. changed out.
3. With taking the two previous questions into consideration, what would you recommend for the best, most cost efficient lift?
Thanks!
RiseAbove is offline
post #2 of 151 Old 05-03-2013, 06:43 PM
toxicwaste29
What size tires do you want to run eventually. A 3-4'' lift can clear roughly 40's with flat flares.
toxicwaste29 is offline
post #3 of 151 Old 05-03-2013, 07:12 PM
jeepsnmopars
Get yourself a BB (budget boost). You will have folks telling you it isn't the best option but with stock springs and shocks I think it rides great. I do have to admit I had 0 miles on it prior to the lift and tires as I had them installed the day I bought it and moved to this from a YJ. Here is my Rough Country 2.5" spacers and 315/75/16's.
1992 Sahara "the dull chain saw"
2012 JK 2dr
1968 Barracuda Formula S
jeepsnmopars is offline
post #4 of 151 Old 05-03-2013, 07:14 PM Thread Starter
RiseAbove
I want to keep the 33's I have. I don't plan on going any bigger due to gas prices.
post #5 of 151 Old 05-03-2013, 07:17 PM Thread Starter
RiseAbove
I have read from alot of people that they like the BB for beginners or people that just want a little lift, nothing extreme. I mean don't get me wrong a 6" lift would look BA but I can't afford that being a college student and just buying a 2012. Money is gone for now. lol
Is there a certain brand for the BB you recommend? I have seen Rubicon and Teraflex. I am assuming most brands make the BB its just preference? Also, did you notice a significant difference with only a 2.5" lift or is it hardly noticeable?
post #6 of 151 Old 05-03-2013, 07:23 PM
jeepsnmopars
I thought the Rough Country was a good choice being its only $140 and the spacers are steel instead of some that are plastic. The 2.5" have allowed me to install 35's and I plan to install flat fenders and trim my pinch weld so flex shouldn't be an issue and as far as I am concerned the ride is great. With 33's there should be plenty of room and it should look great for room between the tires and the stock flares.
2012 JK 2dr
post #7 of 151 Old 05-03-2013, 07:25 PM
toxicwaste29
I would keep what you have them just because a large lift and 33's doesnt look right. If anything, be cheap and get a body lift just since your keeping 33's
I know what you mean, im in the same boat, being a college kid sucks.
post #8 of 151 Old 05-03-2013, 07:28 PM Thread Starter
RiseAbove
So would you go with the 2.5 BB or a 3" suspension lift? The BB is a body lift correct?
post #9 of 151 Old 05-03-2013, 07:50 PM
toxicwaste29
I personally, if you want a lift would only go with a 1'' body lift. But if you want to go 2.5" than go for the teraflex budget boost. But i would advise you to look at pictures of a 2.5" lift and 33's to see if you would like that combo.
post #10 of 151 Old 05-03-2013, 07:51 PM
jeepsnmopars
The BB is spacers above your current springs. Look up the 2.5" entry level lift by Rough Country on their site. That is what I got for $140.
2012 JK 2dr
post #11 of 151 Old 05-03-2013, 08:27 PM
buns79
If you don't ever plan on off raiding then I would stick with just a leveling kit and cal it good but if you really want to have it sit higher for looks then go with a budget boost which is nothing more than spacer that sit on top of your stock springs and some adapters to make your stock shocks longer... This is not a body lift and in my opinion is much easier to install than a body lift to. You can get these lift from 1.5in up to 3in it all depends on the look you like! Just for reference here is mine with a 2.5 in sping lift with 33s(pretty much the same as a budget boost) but I do plan on going to a 35in tire down the road!
13 jku 6sp, 4:88s, elockers, 3.5" RK, Ps fenders and front bumber, ace rear, 37" km2s Olllllll0
buns79 is offline
post #12 of 151 Old 05-03-2013, 08:28 PM
JIMBOX
I paid $99 for my RC Steel galvanized 2.5" lift and that was over 3years ago-
Here's a pic with 33" Hankooks and Bushwacker "pocket" flares-
Now the shocks LCAs and the quality of your coil springs will make all the diff. in the world---I can't comment on RCs shocks/springs-etc
With proper bumpstops and shock lengths, extended brake lines--the BB can hang in there with the best !
It's never simple, you can't just add one item, without influencing many more-
Do a lotta homework-
Good luck
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #13 of 151 Old 05-04-2013, 12:02 AM Thread Starter
RiseAbove
Thanks for all of your input guys. I appreciate all the help. With my 33's I think a 2.5-3" lift would look great. If I were wanting a 5-6" lift I could see needing to upgrade to 35's but with only a 2-3" lift and my 33's being wide (315/what ever the other numbers are lol) I think it would look sharp. The only thing with the BB: does it drive "bouncy?" I have a friend that is a car salesman and he told me about people selling jeeps with body lifts and them driving really bouncy as if it werent done right. I guess my main question now is, will I have to change anything if I get the 2.5" BB? Or will I just get the lift and be good to go?
post #14 of 151 Old 05-04-2013, 12:13 AM Thread Starter
RiseAbove
Just saw where you said the BB is not a body lift...that answers that question
post #15 of 151 Old 05-04-2013, 01:02 AM
Matoskah
I would NOT put a body lift. A two inch Poly Kit will do the trick!
traillizardsjeepclub.com or visit us on facebook
Matoskah is offline
2012 , 33's , body , lift , suspension
