What kind of antifreeze/coolant? - JeepForum.com
post #1 of 5 Old 07-13-2010, 03:58 PM Thread Starter
goldsmith17
What kind of coolant do you use? The manual says to use the HOAT (Hybrid Organic Additive Technology). Any coolant i see doesn't have this, so my question is is it just a Mopar thing or do I actually have to go to the dealer and get this? Just want to make sure before I go and add an 'any make any model' type stuff to it.
thanks
goldsmith17 is offline
post #2 of 5 Old 07-13-2010, 05:03 PM
Slenny
It's Zerex G-05 that you need. I found it at Napa and don't remember the price but I'm sure you can get it at a Chrysler/Dodge/Jeep dealership but it probably be more expensive. They say don't mix any other coolant because it will cause it to turn to sludge and mess everything up.
Slenny is offline
post #3 of 5 Old 07-13-2010, 06:20 PM
JeffinWesternWA
2010 JK Wrangler
HYBRED organic (HOAT) , not full organic (OAT) nor the old high silicate which is rare anymore. Most coolant manufacturers websites will tell you the formula and compatability w/ todays coolants. Aluminum heads coupled w/ iron blocks and resulting gaskets makes coolant VERY important the the correct type is used and kept in "balance" w/o becoming to acidic. Doubtful it's "lifetime" that's : your's mine, the vehicles or just the warranty? USe the correct type w/ distilled water and check w/ "dip sticks" at least every few years! No the common advertised: "ALL MAKES ALL MODELS is NOT the correct application!
JeffinWesternWA
JeffinWesternWA is offline
post #4 of 5 Old 07-13-2010, 11:20 PM
joe002
I checked the FSM and among other things it says: “The use of aluminum cylinder blocks, cylinder heads, and water pumps requires special corrosion protection. Mopar® Antifreeze/Coolant, 5 Year/100,000 Mile Formula (MS-9769), or the equivalent ethylene glycol based coolant with hybrid organic corrosion inhibitors (called HOAT, for Hybrid Organic Additive Technology) is recommended... Mopar® Antifreeze/Coolant, 5 Year/100,000 Mile Formula (MS-9769) may not be mixed with any other type of antifreeze…
I think the key here is they specifically state to use MS-9769 anti-freeze.
Prestone Extended Life 5/150 states it meets: “property and performance specification requirements of Daimler Chrysler MS-7170, MS-9769”.
2008 Rubicon - 2 Door - Flame Red - Automatic - MyGIG - Power Group - Deep Tint.
AEV Pintlers, BFG KM2s 35x12.50x17, Bulldog Fab Stubby Bump, Currie F/R Adj Trac Bars, Daystar Upper Dash, FireStik FireFly antenna, Kilby Rear Shock Skids, LoD Sig Stubby Bump, Midland 75-822 CB, Mopar Filler Door & Locking Gas Cap, Rancho LCA Skids, Rancho Oil Pan Armor, Riddler Diff Covers, custom Rubi Sliders, Sylvania X-treme Headlights, TeraFlex 2.5" Spring Lift, Warn PowerPlant HD, Woods Evap Can Relo, Woods SS Relo, Yukon 5.38s
joe002 is offline
post #5 of 5 Old 07-14-2010, 12:47 AM
Armycop
2014 KL Cherokee
Hybrid Organic Acid Technology (HOAT) is a combination of IAT and OAT with
nitrites added. This makes HOAT suitable for use in both light duty and heavy
duty systems. Currently, two manufacturers are using HOAT for their vehicles.
Daimler/Chrysler's version is dyed orange and contains 10% recycled antifreeze.
Ford Motor Company’s version is dyed yellow and does not contain any recycled
antifreeze. Both of these HOAT antifreezes use the marketing designator of GO-
5. They are compatible with each other but mixing them with IAT or OAT is not
recommended. The normal HOAT antifreeze service life is 5 years or 150,000
miles (250,000 km).
2014 KL SPORT BILLET SILVER l 9-SPEED l 25% TINT l MB ICON WHEELS l OEM SPLASH GUARDS
Armycop is offline
antifreeze , coolant , JK Wrangler , mopar antifreeze , Specifications , wrangler
AMSOIL Antifreeze and Engine Coolant Tjosh97 TJ Wrangler Technical Forum 15 06-07-2010 10:32 PM
Antifreeze/Coolant Smell but no leak... greta TJ Wrangler Technical Forum 8 04-28-2010 05:28 PM
how much antifreeze/coolant randymack TJ Wrangler Technical Forum 17 12-11-2009 03:54 PM
1997 TJ - Recommended Antifreeze/Coolant Type? steevireno TJ Wrangler Technical Forum 2 02-24-2008 09:42 AM
Cooling System knowledge - Coolant Antifreeze Overheating Thermostat Troubleshooting dragginwagon406 TJ Wrangler Technical Forum 8 03-31-2007 03:03 AM
