What gear ratio? - JeepForum.com
post #1 of 5 Old 09-14-2012, 02:05 PM Thread Starter
ptrcrynn
What gear ratio?
Hi, new to the JK ,just got it last night. Still have the YJ. Anyway trying to find out gear ratio can't find a tag on axles anywhere . Wrangler X with auto trans. 08 Thanks in advance. Pat.
ptrcrynn is offline
post #2 of 5 Old 09-14-2012, 02:31 PM
paul84043
jack up one wheel. Spin wheel one full rotation, count driveshaft rotations. That's your Ratio....
It will be 3.21:1, 3.73:1, 4.1:1 or deeper depending on if it's been modded. Diff should have a metal tag on it that has the ratio as well, usually inbetween two diff cover bolts.
Make a man a fire and you keep him warm for a day....Set a man on fire and you keep him warm for the rest of his life....
paul84043 is offline
post #3 of 5 Old 09-14-2012, 02:32 PM
ronjenx
ronjenx's Avatar
If it has not been regeared, it has 3.73 gears. No tags on the JK differentials.
You can also get a build sheet, but that will do no good if there is a chance a previous owner regeared it.
So, jack up one front or rear tire, rotate it 2 turns (not 1 like most people say), while you count the drive shaft turns. That number will be your gear ratio.
ronjenx is online now
post #4 of 5 Old 09-14-2012, 02:45 PM Thread Starter
ptrcrynn
Thanks guys I'll give it a try. It's got some mods so it may have been regeared.
ptrcrynn is offline
post #5 of 5 Old 09-14-2012, 02:49 PM
paul84043
Oh, duh....forgot about taking the Diff function into account!!!
Good catch!
Gear Ratio/Crawl Ratio is my Jeep's Achilles Heel on Advanced Trails (Driving Tips?) TrailRated2011 JK Wrangler Technical Forum 19 04-13-2014 06:59 PM
bigger tires, the right gear ratio vs. speedo gear krafalco YJ Wrangler Technical Forum 3 08-16-2011 07:58 PM
2?'s Which speedo gear and actual gear ratio maxum3300 TJ Wrangler Technical Forum 6 01-15-2010 07:40 AM
Gear Carriers for gear ratio swap bwiencek YJ Wrangler Technical Forum 1 05-04-2006 10:52 AM
Stock Gear Ratio - Speedometer Gear Moxley YJ Wrangler Technical Forum 2 06-06-2003 10:52 AM
