What does it take to make a rubi locker work? - JeepForum.com
post #1 of 8 Old 07-24-2013, 10:39 AM Thread Starter
thunderball
I'm looking at putting a set of rubicon axles in my X and wondering if the electric locker requires anything specific besides the basic switch, relay etc...
Thanx.
thunderball is offline
post #2 of 8 Old 07-24-2013, 10:57 AM
towel33
Just did this last week. Don't even need the relay. Power > Switch> Locker > Ground. Done.
Optional: can wire up an LED indicator too if you want but I skipped it as you can hear it engage/disengage.
towel33 is offline
post #3 of 8 Old 07-24-2013, 11:22 AM
LVCapo
2015 JK Wrangler
Yes, it's a very simple positive/negative switch...just make sure you give the wire plenty of slack (and that it won't get caught on anything). That little rubber plug wire onthe differential is a pain in the *** to fix, and expensive to replace.
LVCapo is offline
post #4 of 8 Old 07-24-2013, 12:07 PM
ronjenx
ronjenx's Avatar
Don't forget to put a fuse in the circuit.
I don't know if this is typical, but the Rubi locker on my bench draws about 4 amps.
ronjenx is offline
post #5 of 8 Old 07-25-2013, 05:46 PM Thread Starter
thunderball
Thanx guys. Those lockers just as good as any other electric?
post #6 of 8 Old 07-26-2013, 11:48 PM
gregaf3
I would put a relay in the circuit. That is 4 amps cold on the bench, how many amps is it hot?
Professional Slacker
gregaf3 is offline
post #7 of 8 Old 07-27-2013, 10:08 AM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
Not just amps - but a toggle simply shouldn't be expected to handle the arc of the connect and disconnect - over time the toggle's contacts will burnish and carbonize... the reduced risk of failure on the trail (and we all know stuff somehow knows exactly when to fail causing the most problems) justifies the cost of the relay.
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #8 of 8 Old 08-21-2013, 01:35 AM
onlyjeep
2011 JK Wrangler
Thinking of doing the same thing,
Can i put a rubi axle only on the rear?
Will it complicate the front if it stay stock?
onlyjeep is offline
