What to do if Death Wobble hits, safty question? - JeepForum.com
post #1 of 18 Old 09-16-2012, 09:18 AM Thread Starter
bmacd
I've read a bunch about Death Wobble, and I'm wondering what to do when it hits.
I've added 35s and a 2.5" lift and I am going to check the torque on all suspension components and replace the track bar bolts.
But if I'm traveling at a high rate of speed (I know, I know) and the dreaded Death Wobble hits, whats my best course of action? Breaks, gas, turn L or R or a hail Mary?
Thanks,
BMacD
bmacd is offline
post #2 of 18 Old 09-16-2012, 09:47 AM
JBWood05TJ
Cut to Fit-Paint to Match
JBWood05TJ's Avatar
Start slowing down immediately by controlled braking. I know it's risky at highway speeds with other traffic, but slowing down is the only way to stop it. Also, it will be VERY hard (nearly impossible) to fight it into staying in your lane, but it's a fight worth fighting.
We save dogs:
JBWood05TJ is offline
post #3 of 18 Old 09-16-2012, 01:20 PM
SubAtomicGenius
2011 JK Wrangler
Slow down and stop ASAP.
Routinely check or have your front end checked by a competent mechanic will prevent it it the first place. As always, an ounce of prevention is worth a pound of cure.
SubAtomicGenius is offline
post #4 of 18 Old 09-16-2012, 01:31 PM
Prot
Prot's Avatar
2014 JK Wrangler
Stop as quickly as you can safely, and pull over on the shoulder if you can.
45 mph tends to be the magic number for death wobble, usually initiated by bumps in the road, pot holes, bad railroad track crossings, etc.
2014 JKU Copperhead Pearl
Too many mods to list. Too awesome to sell.
Prot is offline
post #5 of 18 Old 09-16-2012, 01:51 PM
paul84043
It's not a given that the DW is inevitable. It's a very small number of people that experience it. If you abuse your Jeep and never maintain it, it's more likely though.
Make a man a fire and you keep him warm for a day....Set a man on fire and you keep him warm for the rest of his life....
paul84043 is offline
post #6 of 18 Old 09-16-2012, 03:23 PM
Tyson0717
2011 JK Wrangler
For some reason I was under the impression it was more common then that. Is checking the torque once a year "routinely" enough?
Tyson0717 is offline
post #7 of 18 Old 09-16-2012, 05:23 PM
YJMCBoy
YJMCBoy's Avatar
2010 JK Wrangler
I drive approx. 20k mi a year and change my oil every 5k no matter the driving. I creep underneath with a wrench every other time I change my oil. I would like to say I torque everything appropriately but I really just make sure they're tight. Never had DW, I like to think it has something to do with the maintenance. I've also never found anything loose enough to raise an eyebrow so who knows.
2010 JK 4-Door Unlimited Sport- Soft top, V6, 6-speed standard, bone stock for now
YJMCBoy is offline
post #8 of 18 Old 09-16-2012, 05:56 PM
paul84043
That all depends on your driving conditions and mods. There are literally tens of thousands, probably hundreds of thousands of Wranglers out there that have never exhibited DW. There are also lots of other solid axle vehicles that are not Wranglers that Do get it. It's very commonly associated with worn front end parts. The problem with the Wrangler is that it's also a coil spring suspension which makes it worse. Leaf spring solid axles CAN get an front end oscillation, but it's less likely.
The other three things that lend themselves to DW with the wrangler are that its a highly modified vehicle, probably THE most modded vehicle on the planet right now, the application or the type of driving that they have become associated with tends to beat suspensions to death, and the way Chrysler takes shotcuts and cheaps out on certain suspension items. Those three things all come together to create problems and one potential problem is the front end oscillation.
It's really not even worth worrying about. If you do any wheeling then you should take the time to check out your rig and make sure you haven't damaged it occasionally. It's easy enough to get a torque wrench and hit the half dozen mounting points. It literally only takes about 5 minutes and I actually like getting up under the jeep and checking things out... You never know, you might learn something while you're under there.
post #9 of 18 Old 09-17-2012, 07:09 AM Thread Starter
bmacd
Great info folks.
I hope I never the to experience it, but if I do I'll know hit the breaks and pull over. Then I bust out the torque wrench and make sure we're within spec.
Speaking of torque specifications, can anyone point me to a resource that tell the specs for each bolt?
Thanks,
BMac
bmacd is offline
post #10 of 18 Old 09-17-2012, 08:10 AM
aristobrat
2010 JK Wrangler
http://www.jeepforum.com/forum/f96/j...9/#post9961090
aristobrat is offline
post #11 of 18 Old 09-17-2012, 08:24 AM
Tyranus73
Experienced DW for the first time a few weeks ago in my '01 TJ. Checked every knuckle nut and bolt because it freaked me out. In the end it was as simple as changing a worn steering damper.
Tyranus73 is offline
post #12 of 18 Old 09-17-2012, 10:30 AM
Spaschal
45 is the "magic number". The only way to "stop" it is to slow down or come to a comlete stop. Tyranus 73... it will be back. A worn out steering stabilizer cannot cause DW. It can however "fix" the issue for a short period of time but the shock will soon wear out and your problem will be back. Check your track bar bolts, bushings and bracket holes. 90% of DW is caused by Track Bar issues.
Spaschal is offline
post #13 of 18 Old 09-17-2012, 12:15 PM
SubAtomicGenius
2011 JK Wrangler
My Jeep was 8 months new when I found that my trackbar mounts were wallowed out. I'd say that it depends on use and modifications (ie. bigger meats).
post #14 of 18 Old 09-17-2012, 02:15 PM
Tyranus73
I will definitely check the track bar. If anything it's a great excuse to upgrade. Thanks for the advice.
post #15 of 18 Old 09-17-2012, 02:47 PM
Cutch
How can I make death wobble occur in my mother in law's car
Cutch is offline
death wobble
*jeep "death wobble" hits national* victory red Wrangler General Discussion 32 02-25-2012 07:55 PM
death wobble question mediumdaddy TJ Wrangler Technical Forum 9 05-29-2010 07:07 AM
Death Wobble question Unlimitedlou TJ Wrangler Technical Forum 1 05-02-2010 11:21 AM
Death wobble question tomk864 TJ Wrangler Technical Forum 1 05-19-2008 09:51 PM
Death wobble question happycamper TJ Wrangler Technical Forum 24 03-07-2007 09:47 PM
