What do I need to meet requirements? - JeepForum.com
post #1 of 12 Old 10-27-2013, 10:54 AM Thread Starter
MFisherIT
I have a 2013 JK 4-door stock.
I want to join the JK experience at some point, but still drive my jeep around town.
I need to meet the following requirements:
Lockers, Front and Rear
Sport Cage
37″ Minimum Tire Size (for 4 Door)
Must carry 2 Fire Extinguishers, First Aid Kit and Spill Kit
Working CB Radio
Winch
Working E-brake
From my understanding, I need to following to meet those requirements intelligently:
Dana 60:
o Lots of work I don't understand
37" Tire needs:
o extended bump stops
o driveshaft
o welded diffs to axle tube
o truss front & rear
o 2.5" - 3" lift
o inner axle sleeve
o upper knuckle gusset
o 5.13 gear crawler? maybe 4.88better
I am NOT looking to out preform anyone, do a trail completely unaided, or complete a trail without recovery.
I do want to be at least minimally save and intelligent on low to moderate trails.
Am I correct about the requirement for 37" tires? Do I need a Dana 60? What else do I NEED?
MFisherIT is offline
post #2 of 12 Old 10-27-2013, 11:46 AM
222Doc
222Doc's Avatar
much of what you are looking at will cost as much as the jeep. unless you are doing all the work. The list of what works with 37"s in hard crawling is VERY long and expensive. I would not run 37" with out Hydro assisted steering or in many hard rock the Jk steering is just not good enough. replace all steering parts too. ball joint tie rod drag links all wont last 10k with 37" and the offset and harder and moderate wheeling.
Much of what you need depends on what you are going to wheel? Are you going to take that new Jeep places that 37"s and all that is needed run "Hard core". It wont look new very long.
I would first lean to walk before running. See how far you are willing to get that new jeep in trouble. MOST people will not wheel a new Jeep harder than EASY moderate trails.
You should be able to join a club in your area that will show you what you need and how the trails rate. Go with recovery gear safety and go out with a crew see how she does first. Then perhaps you can drop 20K in it.
222Doc is offline
post #3 of 12 Old 10-27-2013, 11:53 AM
MikeHoncho88
2015 JK Wrangler
Wheel it stock! Just guessing but it sounds like you have not even wheeled your rig yet.
If you wanted to run those type of trails and 37" tires you probably would have been better off to buy a Rubicon. It would have taken a lot less mods to get there. Might even be worth it to trade up to a Rubicon as it will be a much cheaper build.
MikeHoncho88 is offline
post #4 of 12 Old 10-27-2013, 01:25 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Agree, wheel it first and see what you need, then set the requirements to meet your needs. If you can go where you want on 35s, it will make life simpler and less expensive IMO.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #5 of 12 Old 10-27-2013, 02:36 PM
SubAtomicGenius
2011 JK Wrangler
Low to moderate trails do not require 37's. To properly swing those (***properly***) you'll need to spend a fortune. I tend to agree to go with 35's. You'll still need to beef up your front axle to run those without incurring any damage. Best to hit the threads and start reading.
SubAtomicGenius is offline
post #6 of 12 Old 10-27-2013, 04:32 PM
JIMBOX
Very good info, especially about the need for 37s'/Dana 60s-
As a side note, you won't need a spill kit, chances of Primary water contamination are almost nonexistance !!
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #7 of 12 Old 10-27-2013, 05:02 PM
awinski
what is stated above, i know running the jk experience and other huge wheeling trips are fun, but, a club run with the buddies can be just as great. i will admit having 37s and running against big rocks is a blast, but, breaking something is not a blast. especially on a dd, you need to be careful, and have a good spotter. this is where it helps to wheel stock. gain some skill, knowledge, and find a friend that can guide you through the sketchy situations. etc then go and build your jeep to meet your requirements. remember, before you do anything READ READ READ!!!!!!!!!!!!
The ONLY chlorophyll JK
one more horse power than the average pentastar;
twitter/IG - @Becauseracejeep
awinski is offline
post #8 of 12 Old 10-27-2013, 06:17 PM
Butterjeep
2015 WK
For low to moderate trails, a stock JK will probably be just fine...
2014 Mustang GT Track Pack
2015 WK2 Limited 4x4
Butterjeep is offline
post #9 of 12 Old 10-27-2013, 10:54 PM
aznjeep
aznjeep's Avatar
2014 WK
Just to support what everyone else has already said.. if you haven't really been "off-road" (meaning "Jeep" wheeling), go do easy to light-moderate trails to learn how to pick lines; go with people that have been before. You will learn as you go. FWIW, our 2010 JKUR did 5-rated trails all over Moab (during Easter Jeep Safari) with no problems (3.5" lift on 35" tires)--having said that, I also have years of wheeling experience and can do a good job of picking out the right lines because I spent time with my Jeep, and I know what it can and cannot do. I, personally, have seen people show up to EJS with a brand new Jeep, spent $20k plus in equipment/upgrades, and are the ones that have a difficult time on a moderate trail, all the while some stock Jeeps are tackling the terrain just fine. I've even see one break once--blew out the rear end.
In short, wheel your Jeep stock a few times. THEN, decide what you really want your Jeep to do off-road while keeping in mind that you want to keep this as a DD...
-Ken
'96 XJ Sport
'14 WK2 Overland EcoDiesel
'13 JKUR 10A (sold)
'10 JKUR (sold)
'99 TJ (sold)
aznjeep is offline
post #10 of 12 Old 10-28-2013, 11:08 AM
RockyClymer
RedRock4Wheeler
aznjeep - you have just stated one of the facts about off-road - 50% driver and 50% vehicle. I have seen stock vehicles outperform built vehicles based on driver experience alone...
NRA Life member
post #11 of 12 Old 10-28-2013, 02:08 PM
222Doc
222Doc's Avatar
this^ see it all the time. but most of that is "knowing" the obstacles and trails. The harder the trail the more this comes to play.
Some of my best carnage and damage is from taking the wrong line for the set up and finding out how freeking stuck a rubi n 35"s can get. in boulders that 40"s have to tread well. gets expensive real fast if you break anything.
I would say every run or clubs run. someone will have a issue, break an axle lay it over. shread tires on rocks. breaking Ca arms and links. or like me had an air bag go off and break my arm! had to drive it for 12hrs broken arm there be a BIG cow bell for me.... yep you never know what the day of wheeling will bring. GO ready, first aid, recover winch. I carry water food clothes. Tools..like a boy scout be prepared. You just never ever will know what lies ahead, even if you dun 'it before.
222Doc is offline
post #12 of 12 Old 10-28-2013, 03:27 PM
Wonk
For a little added info to the comments above, the gear chart you posted is for a 3.8 motor. Your 2013 JK has a 3.6. Big difference as to what gearing you need. And for all that say you need trussed and tubed axles to run 37" tires, I ran 37s on my TJ with a Dana 30 with no truss, no tubes, no C braces etc for 10 years. All it had was an ARB and 4:56 gears (4.0 - 5 spd). My good buddy did the same with 39" Iroks. And no, we aren't web wheelers or mall crawlers. We've done everything from Paragon in Penn (now closed) to Tellico (also now closed) to Superlift in Arkansas and everything in between. We also usually started with the 4 rated trails to warm up then moved on to the hard stuff. Yes, we broke a u-joint or two and occasionally worse, but that was usually caused by heavy skinny pedal application. My point is that you can do a lot of good wheeling if you learn your rig and drive with some finess.
Wonk is online now
