Quantcast What Do I Do?!?!?!? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > What Do I Do?!?!?!?
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff Parts
Old 05-22-2009, 01:36 AM   #1
Wolffman201
What Do I Do?!?!?!?
What does swapping out your stock differentials for larger ones do for your jeep?
Should i put lockers on? What are lockers, what are they for?
When i put a 6" lift on my jeep what else do i need to do to it so something doesn't break?
What should i be doing to my Jeep first before i go trail riding?
As an inexperienced "wrencher" should i learn as i go or take it to a mechanic? I'm a quick enough learner but i don't want to be jacking up my Jeep.
What projects are the most difficult thus requiring a mechanic?
I'm not dumb but i need help being put in the right direction with building up my Jeep...it all seems overwhelming because i want that kick *** jeep i just don't know where to go with it or even where to start.
I want a 6" lift on my JK and the ability to go where ever i want. Please HELP!
"Wolffy"
Wolffman201 is offline   Reply With Quote
Old 05-22-2009, 01:57 AM   #2
omnicitadel
Where Did The Weasle Go?
omnicitadel's Avatar
If you are going to regear and you feel like burning some money lockers are a good way to do it. However because you are running the 3.73 gears you do not have to change out your carriers to regear so it is literally spending extra money money. (Lockers will keep both tires on the axle moving at exactly the same speed at all times, if you have a dana 30 this is a quick way to break a drive shaft if you are running larger tires. Personally I prefer to stay open / LSD in the front)
a 6" lift is lots of lift... I would research around and see if you really want to go 6", 3.5" or 4" is enough to break into the 37" category, but if you are a 2 door this will involve better drive shafts as they will break rather quickly. Yet again you may want to beef up the drive shafts (if not the entire axle) to run 37's.
It might be a good idea to fully armor the underside to your likening before going big on the trails. If you really go with a 6" lift and 37" tires your center of gravity is going to be drastically changed. So you might want to make sure you have some one there to flip you back over.
As for wrenching your self. Most things are common sense and a bit of reading to do. With patience you could do the lift your self (so long as you have the tools, as there are quite a few required). As for re gearing your self and installing Lockers etc, It is highly recommended that you find an experienced 4x4 / racing shop to do this as if done wrong the failure is catastrophic.
Just ask questions if you are not sure and use the search button above...
2008 JK-Xs Steel Blue Metallic Dual Top
Mods: Performance Accessoires 1" Body lift, 2.5" Teraflex Lift, 35x12.5x17 Dunlop Radial Mud Roaver, Alpine iDA-X100 Head Unit, Infinity REF6022I 6.5" Front and Rear Speakers.
Docket: Shrockworks Rock Sliders, Rock Hard 4x4 Skid's (all of them), Front and Rear Bumpers (undecided), Winch (undecided)
omnicitadel is offline   Reply With Quote
Old 05-22-2009, 06:27 AM   #3
N2rock
N2rock's Avatar
You ask "What do I do?"
Answer: Slow down! Take some time to learn- don't rush into anything. Sit back and do the build slowly- one step at a time, learning everything about each mod before jumping into it.
Yeah you want a Bad-A$$ rig. But you're going to waste a ton of money if you just dive in without the knowledge.
I highly recommend you go wheeling a few times bone stock so you can get a feel for your rig and know what you need to do with it. Then get on this forum and jkowners.com and read everything.
2 years ago I had never wheeled, never turned a wrench on any vehicle, didn't know the difference between a locker and a disco- had no idea what a locker was and thought disco was a type of music. Slowly I learned by reading. And built up my rig.
Building up a rig is not cheap! And to avoid wasting money you need knowledge. And you can't get that knowledge with one single thread.
for details and info on our JK's, check out http://n2rock.com
His: '07 Unlimited X, Jeep Green, Hardtop, auto, 5.13, 2.5" RC lift and too many mods to list
Hers: '08 X Red Rock, soft top, auto. Bunch of mods
Originally Posted by tlgraham View Post
If you made a snuggy out of a Shamwow, ....would you have to get up off the couch to pee?
Originally Posted by Deepskyy View Post
At this point if Obama tried to move a little to the right, he would trip over Stalin's corpse.
N2rock is offline   Reply With Quote
Old 05-22-2009, 06:44 AM   #4
Little Green
Look up hitmoney's rig, Sweet looking and probably one of the coolest rigs on here. Agree with above, slow down a bit. 6" is an insane amount of lift and may not be necessary. The key to a stable,capable off road rig is low center of gravity coupled with the right sized tire for the Job, since you can't go around replacing tires all the time, pick the right size to start 37's or 40's can be done with a 4" long arm lift kit and flat fenders. This will give you a more stable ride and you may not have to modify as much. Clearly regearing is going to have to be done but unless you are a mechanic I would not mess with them. Most lifts can be done if you have all the right tools up to and including a welder as in some cases you have to weld new mounts. Keep in mind that 37 or 40" tires are so large that they are almost(settle down you guys rocking 40's) impractical for daily driving. Most guys on here get by with 33 or 35's. They look great, are still very practical for daily driving and solid offroading. These JK's are remarkable machines stock and with some upgrades(small lifts with 35's) can do just about anything. Now, If you are building a purely off road machine, start a new thread and take LOTS of pics.
08 JK 4 Dr Rescue Green-6 Speed
Magnaflow Cat Back- K& N FIPK Kit, Olympic front and rear bumpers and side rails.
KC light bar with 2 slimlites up front and 2 windshield mounted. Additional rear lights under bumper.
Reese Hitch. HuskyLiners all the way around. Ultra 16 x 8 Wheels, Mickey T's 33 X 12.5" MTZ radials, 48" HL Extreme, Bestop safari doors
Little Green is offline   Reply With Quote
Old 05-22-2009, 01:26 PM   #5
BigJerm
6” of lift won’t get you anywhere if you don’t know how to drive it. Follow the suggestions of others… SLOW DOWN. We all want that BA rig but without proper research you just end up buying something and replacing it later because it was the wrong decision. Sounds like you need to do a lot of research. Plenty of info on here and JKowners.com. Pick 1 thing, say lift, and research it until you have your answers, then move on.
But to help you with one thing, what to take for trail riding. I speak from east coast wheeling but this is our normal stock or not:
-Fire extinguisher (mandatory for a lot of the private parks here)
-At least a 20’ recovery strap
-At least 1 D-ring
-CB radio
-Simple tools
-Some vehicle fluids
-Food and water
-Change of clothes if you are going to be in the mud
07 Jeep Wrangler Unlimited Rubicon
GA Trail Riders
BigJerm is offline   Reply With Quote
Old 05-27-2009, 09:45 PM   #6
Wolffman201
i appreciate all the help everyone, even though it got a little hostile. I've begun researching the sh!t out of everything i can and doing little stuff that won't change my Jeep too much. I'm looking for a smooth little trail to take it on. Again thanks for everything and any further advise will, again, be much appreciated. I joined this site to get some insight and you guys have provided that along with some much needed perspective. Happy trails, I'll post any and all upgrades.
"Wolffy"
Old 05-27-2009, 10:23 PM   #7
thejafe
This is an excellent post, and excellent advise .
Visit My Homepage!
thejafe is offline   Reply With Quote
Old 05-27-2009, 10:25 PM   #8
thejafe
You need to ask yourself what you want to do with your Jeep first. "Trail riding" can mean many things.
Do you want to rock crawl? Do you want to drive scenic mountain passes? Does body damage concern you? Is this a vehicle that will be driven on highways most of the time?
Visit My Homepage!
Old 05-27-2009, 11:11 PM   #9
Kryptes
Pick up some recovery gear and a CB then contact a local group or club and follow them out onto the trails. You will not only quickly learn about off roading but also what you need and don't need. I have seen stock jeeps do better then jeeps with 4-6" lifts / tires because the drivers of the built up ones knew nothing about picking their lines and how to wheel properly. Take your time and enjoy building it up the way is best for you.
Kryptes is offline   Reply With Quote
Old 05-28-2009, 07:07 AM   #10
tricked919
where in NC are you?
tricked919 is offline   Reply With Quote
Old 05-28-2009, 10:36 AM   #11
Wolffman201
Marysville, CA about 35 min NE of Sacramento. I'm stationed at Beale AFB
"Wolffy"
Glock Forum
