What broke on my drive shaft? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > What broke on my drive shaft?
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! PANDEMIC-USA 50" Double row LED LIGHT BAR!! These thiIRON CROSS Jeep JK Front and Rear STUBBY BUMPERS IN STOCK
Unread Today, 07:52 PM   #1
DTieu1
2014 JK Wrangler
Today, I got done washing my Jeep and engine compartment. When I parked it inside my garage I opened the hood and noticed a small line of oil on my hood. Then I looked under it saw oil or lube, near my drive shaft, I see a piece of rubber or metal piece hanging off a little, Is this a cheap fix or should I take it to the dealer, since I have warranty on it. About 12,000 miles on it. It has a 3 inch lift with 35 inch tires. Can you guys help me out?
DTieu1 is offline   Reply With Quote Quick reply to this message
Unread Today, 08:11 PM   #2
NCRUBI2012
What year? 2012 and up and I would say it couldn't handle the pinion angle of the 3" lift. Mine is 2.5 and driveshaft is pushed to its maximum. Suggest aftermarket driveshafts with that much lift.
NCRUBI2012 is offline   Reply With Quote Quick reply to this message
Unread Today, 08:22 PM   #3
DTieu1
2014 JK Wrangler
Okay, I just looked at it, It looks like the boot of it broke and thats the reason why the oil is everywhere. Would you recommend front and back drive shaft replacement?
Unread Today, 09:41 PM   #4
rich6700
If you have a 4 door the rear shaft will last longer because the angle is not as steep. But I would just get 2 coast shafts and be done with it.
rich6700 is offline   Reply With Quote Quick reply to this message
Unread Today, 09:56 PM   #5
DTieu1
2014 JK Wrangler
Yeah, You're right. Should I have the dealership fix it for now then get it replace. I was going to do it myself anyways. Its a 2014 Jeep Wrangler 4 door.
Unread Today, 10:53 PM   #6
ncb
Explain the line of oil on the hood. I had a leaky power steering pump and the pulley was flinging the fluid on the hood liner making a line.
ncb is offline   Reply With Quote Quick reply to this message
