-   JK Wrangler Technical Forum (http://www.jeepforum.com/forum/f96/)
-   -   Wet floor boards - 5th trip to dealer! (http://www.jeepforum.com/forum/f96/wet-floor-boards-5th-trip-dealer-1663025/)
Truck11 10-08-2013 11:01 AM
OK folks - need some help here. 2013 JKU that is 4 months old. Dual top - dealer installed the soft top as part of purchase agreement. It has been into the shop 4 times for leaking - both front foot wells soaked every time it rains. They have replaced the header bar on the soft top, 'realigned' it etc, replaced the front side trim pieces above the doors (?) last week... and then yesterday driver side floorboard soaked/flooded again. Passenger side seems fine (for now)
Any thoughts on where else it might be leaking from? Every time I pick it up they say it's fixed and they tested it, no leaks ...... ! DC metro area has not gotten a lot of rain this summer - but when it does rain..... I have wet floor boards. Could the entire soft top be 'bad' - just not fitting correctly or something?
Appreciate any input. Jeep is headed to the dealer... again, either today or tomorrow. Apparently they contract a 'water guy' that comes in once a week just to work on leaks.
dodgethejeep 10-08-2013 11:09 AM
Do you see it leaking, or water tracks down the windshield?have you checked the bottom seal for windshield or the sealant? Need to pin down the leak before you can get a good fix. Is the water guy a culligan man or something? "Water guy" is BS.
HappyTrails 10-08-2013 05:17 PM
Not sure how to cure the leak in the top.
But, I'd remove the floor drain plugs in the meantime. (not trying to be a smart-***, btw).
EDIT: I did some research. Check the plastic door frames. If the dealer sold you the soft top, and not the factory, they may have sold you the door frames from a previous year model. 2007-2009 door frames are different than the newer models, they had a lip in which you had to fold the fabric over on the edges over the door. If the soft top is a 2013, and the door frames are from 2007-2009, there is your problem...not compatible.
Mfrancis 10-08-2013 06:43 PM
I have a '14 with 2k miles on it. When it rains, I have a small puddle of water in my slush mat, driver's front. I have the Mopar door sill guards in my door sills, and water leaks in from the BOTTOM of my door. It is super annoying that the BOTTOM of my door leaks enough to pool. Don't assume it's the top, as that was the first place I looked. Bear with me, this might be hard to explain. If you watch water collect on the top while it's raining (or a hose) you will see the water runs down into a groove on the top of where the door meets the frame. The water then runs down either side of the door. The weather strip that runs around the inside of the door must not be making contact with the door correctly, thus water enters down there. I only discovered this by sitting in it while it was raining with a flashlight looking for leaks. I have not contacted the dealership yet, as I am afraid they will say to just take the door sills off. I want to leave them on, but I haven't figured out how to correct the weather strip issue to keep rain out. I can't imagine trying to drive through any standing water. You may not have the same issue, but given the dealership has had a couple looks at the top, maybe give some other spots a look.
buckscop 10-08-2013 08:08 PM
Had/have the same leak in my '11, '12, and now the brand new '14
mjp83 10-08-2013 08:24 PM
1 Attachment(s)
My 2011 leaks sometimes. However, this is on a used 2008 top. Here is a pic of where the water comes in, right over the door handles.
Attachment 742457
buckscop 10-08-2013 08:32 PM
If that's a soft top, usually the foam mullet under the top is mis aligned or bad/missing
HappyTrails 10-08-2013 10:45 PM
Attachment 742457
The tops on the 2011 are different than a 2008, even though they appear to be the same. I'm not sure what changed, but I do know that they are not interchangeable.
4x4jkx 10-09-2013 04:15 AM
The door channel clip isn't there on the new tops. My 2012 has the mysterious puddle of water on the floorboards leak as well. As far as I can tell the rain runs down along the door sill between the weatherstripping and the body until it reaches the floor and just pops into the cabin. Magic apparently.
Mfrancis 10-09-2013 08:08 AM
^Is this something that can be fixed, or is it one of the "it's a jeep thing" problems people just deal with?
Wrigley 10-09-2013 10:21 AM
I still don't understand how a piece of FOAM is going to stop Florida rain storm water from getting into my Jeep? :)
Mike
Truck11 10-09-2013 10:49 AM
2 Attachment(s)
Interesting replies from everyone..... thanks
Some more background. Bought the Jeep with hard top and had the dealer order me the 'premium' soft top as part of the deal (they did not have the 'dual top' option available). They installed the soft top once it came in.
Pics are from my quick hose leak-test I did yesterday at lunchtime before i took it in.
The water is NOT leaking onto the door (as in the other pics from above poster) or pooling IN my rubber mats, but rather UNDER the front carpet(s) in the edge closest to the frame lip.
Mfrancis 10-09-2013 11:21 AM
I would have to guess we have the same issue from your post. My rubber mats contact the area you described, it's just easier to see where it is collected in the mat. If I feel underneath it, it's wet underneath too. What did you find out when you took it in?
Truck11 10-09-2013 02:46 PM
Soooo..... dealer just called me to advise the leak is now coming from the B pillar mucket seal, and the part has been ordered. Appointment made for next Wednesday and that I can come pick up the Jeep this afternoon. So tempted to let them keep it and i'll drive the loaner - only problem is the loan is a crappy, itty bitty Kia (but it was getting 43mpg!)
But wait...... I said I SAW is leaking from the A pillar???? He assured me it was the B pillar and it was running the channel "I watched it myself" he said. (Insert sarcasm voice here!) But wait.... how does the water leak down the A pillar from the top of the windscreen if it is leaking from the B pillar mucket? I'm confused :confused:
:mad:
toxicwaste29 10-10-2013 09:44 AM
I had a leak that would do this. The leak came from the passenger side by the kick panel there was a rectangular body plug that didnt seal right. I took this off and siliconed the edges and stuck it back in place. Still no issues from this area. I also have a dealer leak test manual that I used to help me. Send me your email and i can send it to you since its a large pdf i cant post it.
The time now is 08:08 PM.
