Wen't wheelin and have a question - JeepForum.com
post #1 of 19 Old 10-18-2008, 10:33 PM Thread Starter
jlued
So we go out to Boulder Creek Farms in Marble Falls Texas and had a blast getting dirty and climbing up some steep loose rock hills. Climbing one hill I was in 4hi and just flat didn't have the power to climb the hill. Mid way up I nearly stalled and managed to get it into 4lo and bounced and hopped my way up no problem.
Is this something that is to be expected? I know that is what 4lo is for and all but I didn't think there would be THAT big a difference on an incline. It felt like a whole different vehicle.
(I've had limited climbing experience, most wheeling has been done in mud or sand)
Jeep-2007 Unlimited X, 32" BFG Mud Terrains on 17" rims, 1.5" Spidertrax spacers, Lim Slip Rear, side steps, upgraded sound and sat radio.
On Order-3" Zone Lift, Warn Rockcrawler Front Bumper & tube Grille guard
Future Upgrades-Winch, Under body Protection, Mopar Rear bumper with tire carrier, 5.13 regear
jlued is offline
post #2 of 19 Old 10-18-2008, 10:48 PM
Bitzorock
Yeah 4 lo will do wonders.. so would a locker and good tires.. Its better to just start off 4lo in a climb rather than trying to fumble around with it when your but cheaks wont let go of the seat.. hehe
Richard Clark
06 Wrangler Unlimited
Bitzorock is offline
post #3 of 19 Old 10-19-2008, 06:59 AM
N2rock
N2rock's Avatar
I agree... In fact I never even use 4Hi- when I'm wheeling I use 4Lo exclusively. I never have any need to "go fast" when I'm off road, so 4Lo is always fine. Plus 4Lo turns off the ESP/BAS so I know none of that will interfere.
for details and info on our JK's, check out
His: '07 Unlimited X, Jeep Green, Hardtop, auto, 5.13, 2.5" RC lift and too many mods to list
Hers: '08 X Red Rock, soft top, auto. Bunch of mods
Originally Posted by tlgraham View Post
If you made a snuggy out of a Shamwow, ....would you have to get up off the couch to pee?
Originally Posted by Deepskyy View Post
At this point if Obama tried to move a little to the right, he would trip over Stalin's corpse.
N2rock is offline
post #4 of 19 Old 10-19-2008, 07:22 AM
MacK
2015 JK Wrangler
What about us loser guys that can only go off road on a beach? How would 4 lo do on the beach? Just curious
MacK is offline
post #5 of 19 Old 10-19-2008, 07:35 AM
Gravitytester
4hi is all you need on the beach, just makle sure you turn off the esp. If you don't, when you start to get some wheel spin it will kick in and start braking the tires that are spinning and bog you down.
2008 Jeep Rubicon 2dr with a 6sp manual transmission. I had forgotten how much I missed my other Jeeps.
Gravitytester is offline
post #6 of 19 Old 10-19-2008, 07:37 AM
PILL
I usually use 4LO 2nd gear for trail riding, and go to 1st when I need to climb or crawl something.
Member 134 of the White Jeep Club
31" BFG A/T's, 130w KC Hilites
PILL is offline
post #7 of 19 Old 10-19-2008, 07:42 AM
N2rock
N2rock's Avatar
Exactly the same I do.
N2rock is offline
post #8 of 19 Old 10-19-2008, 07:43 AM
N2rock
N2rock's Avatar
Yup- I've only done beach wheeling twice (not real fond of all that sand everywhere afterwards), and did exactly that. The only problem is that anytime you turn the engine off, you have to remember to turn the ESP off again when you start the Jeep back up. I forgot numerous times.
N2rock is offline
post #9 of 19 Old 10-19-2008, 08:42 AM
MacK
2015 JK Wrangler
I usually leave ESP alone, but it seems like even with it off the light still blinks like it's being activated...
MacK is offline
post #10 of 19 Old 10-19-2008, 09:03 AM
N2rock
N2rock's Avatar
If you are in 4Hi, it is active unless you manually turn it off. So if it is active and blinks, it is in fact activating. And it is probably activating in situations that you don't want its help.
4Lo- automatically off
4Hi- manually turn it off (every time you start the engine)
N2rock is offline
post #11 of 19 Old 10-19-2008, 10:50 AM
MacK
2015 JK Wrangler
Yea, but what I'm saying is when I disable it by the button in 4hi.. if I'm doing between 15-20MPH on the beach (yea I'm a fast driver, hehe) the light is lit up on my dash, but it does blink-- although it does not seem like it's doing anything. Maybe it's trying to tell me that my wheel is slipping but it's not correcting it?
MacK is offline
post #12 of 19 Old 10-19-2008, 05:30 PM Thread Starter
jlued
most of the time I'm in 4hi on the beach...soon as I hit really thick stuff and keep having to downshift to get moving again I just give up goin fast and put it into 4lo and just power through everything.
So next time we go out (which will be very soon...i was too chicken to go up a couple of hills that im now kicking myself for not doing) i will just go straight to 4lo thanks guys.
jlued is offline
post #13 of 19 Old 10-19-2008, 06:42 PM
MacK
2015 JK Wrangler
I'm just thinking that 4 lo would get you stuck because it's doing more digging? I'll have to try 4 lo..
I hit a hill that was 4ft high and my JK didn't even struggle, I just drove up like it was a little bump
MacK is offline
post #14 of 19 Old 10-19-2008, 09:01 PM
1222
RIP John
1222's Avatar
When Iím wheeling I only use 4lo if the situation requires it (large rocks, steep climbs, tricky off-camber parts, etc.) or if Iím going up or down a hill where Iím not sure of. I also turn off the ESP to full off as soon as I hit the dirt. If youíre going to do any type of aggressive off-roading I would recommend turning the ESP to full off. If you donít it will activate at the most inopportune moment. To turn it to the full-off mode you have to be stopped with the engine on depressed hold the ESP OFF switch for 5 seconds. At that time you should hear a chime and the indicator light will come on saying ďESP OFFĒ. To turn it back on just push the switch again and it returns to normal operation. Now, whether youíre in 4hi or 4lo, the ESP will temporarily go back to normal on whenever you go over 40 mph.
(2011-2016)
1222 is offline
post #15 of 19 Old 10-19-2008, 09:47 PM Thread Starter
jlued
most definitely not...4lo makes sand that you would normally have trouble with in 4hi seem silly.
The problem I was having was a steep incline of about 40 yards with rocks here and there that I had to climb over.
I didn't think that 4hi would have a problem with it if i stayed in 1st...i was wrong. I was able to engage 4lo and i nearly went airborne.
fun stuff!
jlued is offline
Wheelin' question staquinas Wrangler General Discussion 10 07-22-2009 11:49 PM
Wheelin auto or wheelin stick KJFactor YJ Wrangler Technical Forum 39 07-15-2009 09:39 PM
New wheelin for 95 Jeep25 Wrangler General Discussion 2 12-04-2008 09:54 AM
Had to go wheelin Skyryder Wrangler General Discussion 3 06-03-2008 05:51 PM
Question about rocklights and East Coast wheelin' OffCamberTJ TJ Wrangler Technical Forum 8 01-07-2006 08:24 PM
