Well the JK needs a crankshaft. - JeepForum.com
post #1 of 17 Old 05-12-2013, 07:40 AM Thread Starter
GeorgiaJK07
Jeep randomly started making a ticking noise from the motor one night. Was going up a steep hill and dropped down in 1 then 2 and that's when it started. Took it to the dealer the following day. They said there was no oil in it. I change my oil every 3000 miles. Never had a problem. I was right at 3000 when this happened. Not to mention 2 days before this my buddie calls and is asking about why his jeep oil light keeps coming on. I've been cursed. ANYWAY. The dealer put 5qts of oil in it and the ticking is still there. They say it needs a crankshaft. $3500. Yes I know it's high and that's why I'm getting a second opinion. The engine is not leaking oil. Nor burning it. The crank seal apparently has a super small leak. Not enough to drip. Where is my oil going!!!??? Have you ran into this?
GeorgiaJK07 is offline
post #2 of 17 Old 05-12-2013, 08:11 AM
ncb
JK 3.8s can be oil burners. Must check the oil frequently. Mine burns one qt. between oil changes.
ncb is offline
post #3 of 17 Old 05-12-2013, 08:35 AM
Drmudgood
1993 XJ Cherokee
Are you mechanically inclined?
Ive read posts here of people picking up low mile 3.8's for a couple grand. May be the way to go if you can install yourself. Get a 2nd opinion on your crank 1st though.
Drmudgood is offline
post #4 of 17 Old 05-12-2013, 08:44 AM
222Doc
222Doc's Avatar
There is a lot of threads on this. One reason i waited for the 3.6. Not that that was much better with the head issues they have. From what i recall it was the rings. I have read that it was that the rings were not clocked right during the manufacturing of them in mexico?. Seems that Jeep even changed the what is "normal" amount of oil burned between oil changes. seems that the 07-08 had the most trouble.
Seems like alot of money to fix, just a crank? or is that a replacment motor/ short block? I would be looking at a swap to more reliable motor and one that has more power.
low oil wll fry the rods, lead to a spun bearing and total failure
222Doc is online now
post #5 of 17 Old 05-12-2013, 09:00 AM
pentastarguy
2015 JK Wrangler
aren't some 3.8 owners using a thicker oil to slow down the leak?
pentastarguy is offline
post #6 of 17 Old 05-12-2013, 09:50 AM
JTPhoto
JTPhoto's Avatar
Yes the easy solution is running heavier oil. Usually 5W30 is sufficient, however, once the engine runs that low on oil, damage has been done.
A leaking rear main seal is sometimes hard to detect without close inspection. The oil just spreads along the underside of the Jeep. If you go through mud and water regularly, the oil is washed away. An occasional belly wash and inspection would help identify a leaking seal, pan gasket leak and tranny line leaks as well.
To the OP a low mileage engine from a wrecker would be my choice. The dealer or any shop could install a complete used motor faster for you then rebuilding your current motor.
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, D44HD/J8 w/ OX locker and RCVs, 37x12.50x17 Pitbull Rockers on ProComp 2635 Predator Alloys, AEV Prem Bumper, Smitty X2O 12K ETC..
JTPhoto is offline
post #7 of 17 Old 05-12-2013, 09:57 AM
TXWK131
2009 JK Wrangler
I've had 10W-40 in mine (basically diesel) and my knock has subsided. Helped a lot but still plan on doin the 5.7 hemi
2009 SILVER JK Sahara
RC 3.5-315.70.17 on Stock RUBI's
PE Front and Rear Bumper
DIY DECK LID
2006 Navy WK HEMI ~RK 3.5 lift - 17" Moabs - Toyo 265.70.17 AT - Bedliner Paint Job - SOLD
'85 XJ... Still tryin to figure out what the heck I have in this piece of Junk! But you gotta start somewhere
TXWK131 is offline
post #8 of 17 Old 05-12-2013, 12:41 PM Thread Starter
GeorgiaJK07
If all else fails ill do a engine swap. Dealer wants $3500 for crankshaft and all new seals everywhere. Guy I know prob wont want near that. Still waiting to hear back from him. Anybody do any engine swaps?
post #9 of 17 Old 05-12-2013, 06:39 PM
222Doc
222Doc's Avatar
replacing the crank and all seals? what about the rings, it was burning oil?
short block
post #10 of 17 Old 05-12-2013, 07:14 PM Thread Starter
GeorgiaJK07
Yea they didn't say anything about rings. I haven't noticed it burning oil. Like someone said above^^^ it leaks from the crankcase and once you go through any water it all gets washed away so It goes un noticed. You can only see it with a close and thorough inspection. Which I can see now that I know where it's leaking.
post #11 of 17 Old 05-12-2013, 07:14 PM
TXWK131
2009 JK Wrangler
short block
Ding Ding... Crankshaft and seals won't fix the burning oil problem. It might help but its more of a bandaid. You need the rings/pistons and rods replaced which is basically a rebuild anyway so you might as well just do an engine swap by the time ur done it will be the same amount of $ if not less. Doc hit the nail on da head
DIY DECK LID
TXWK131 is offline
post #12 of 17 Old 05-12-2013, 08:18 PM
ronjenx
ronjenx's Avatar
Most of the people who have been burning oil have seen no smoke from the tail pipe.
5 quarts in 3,000 miles is a lot to leak out with no evidence.
To those who may not be checking their oil regularly: Change your ways, and pull that dip stick once in a while.
ronjenx is online now
post #13 of 17 Old 05-12-2013, 08:27 PM
ncb
If it's leaking five quarts in 3000 miles are you seeing oil on the garage floor?
ncb is offline
post #14 of 17 Old 05-12-2013, 08:56 PM
222Doc
222Doc's Avatar
^^^ this there would be a puddle if its leaking that much oil. If you are crossing water with that much of a leak the EPA would track you down and the green people would fallow you home.
I had a ford 390 "76" that was a leaker. I should have just tied an oil pan to the bottom and poured it back in.
post #15 of 17 Old 05-13-2013, 02:14 PM Thread Starter
GeorgiaJK07
There hasn't been one drop of oil on my carport. No blue smoke so obviously I assumed it wasn't burning it up and obviously I assumed it wasn't leaking. Had I known it was gonna randomly drink up 5 qts in 3000 miles I would have paid more close attention to checking it more regularly. Gonna replace crank and seals and see. What happens. $700 max. It's my only option right now.
