Weird Shudder when braking while turning? - JeepForum.com
post #1 of 12 Old 04-24-2013, 12:06 PM Thread Starter
HighandLow
HighandLow's Avatar
2010 JK Wrangler
Heading back from about a 100 mile trip I exited the freeway on a ramp that curves downhill to the left. As I applied the brakes to slow down and take the curve I got an awful shudder from the pedal and heard some grinding noises from the front. Got it home and looked at everything, nothing. No scrape marks on the wheels, brake calipers, brake lines. Everything from steering to suspension looks and feels OK.
FYI, Front springs and stabilizer relocation bracket added about 3 weeks ago, alignment done about 2 weeks ago. 35000 on the jeep. Other specs are in my sig.
Since adding the front springs the jeep does feel flighty on the highway. Steering is tight though, and it drives in a straight line with one finger on the wheel.
As I said it, happened going downhill and curving left at about 15 mph, so the full weight of the jeep was on the front left rotor as I braked.
Any guesses as to what caused the shudder?
2010 Rubicon, Auto, Stone White, 3.5"Synergy Coils, DL and TR, MetalCloak TB's and CA's Fr/Rr, 37"Coopers 18" Ions , Adams 1310's, G2 5.13 gears, Synergy Sleeves and Gussets, ORF, PSC, JCR, PIAA,Rancho equipped...
HighandLow is offline
post #2 of 12 Old 04-24-2013, 12:30 PM
socal_rubi
Sounds like the ESC activated. It's basically your ABS coming on and being applied to the proper wheels to help keep you in control of your vehicle. That will produce the symptoms you described. I've had it happen a few times.
socal_rubi is offline
post #3 of 12 Old 04-24-2013, 12:31 PM
JTPhoto
JTPhoto's Avatar
Traction Control kicking in.. Did you re program for bigger tires..?
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, D44HD/J8 w/ OX locker and RCVs, 37x12.50x17 Pitbull Rockers on ProComp 2635 Predator Alloys, AEV Prem Bumper, Smitty X2O 12K ETC..
JTPhoto is online now
post #4 of 12 Old 04-24-2013, 12:53 PM Thread Starter
HighandLow
HighandLow's Avatar
2010 JK Wrangler
I have not reprogrammed. Also, I discovered in looking at everything, that the alignment shop aired me up to 40#.
post #5 of 12 Old 04-24-2013, 01:05 PM
222Doc
222Doc's Avatar
Flighty, or Darty. Can be from not enough toe in. Factory i think is 1/8[ 1/16 per side]. Though on a Jk its soild tie rod means no way to adust one side anyway. So if its less tyan the 1/8 it will get darty, thoughthis means less rolling resistance. You can add a bit more toe with larger tires. This will keep it tracking better, less wonder/darty. I like a bit darty less wear, but in the wind it is a hand full. On roads that have groves it tend to follow them as well.
As long as everythng else is good.
222Doc is offline
post #6 of 12 Old 04-24-2013, 01:10 PM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
Yep. Stability Control kicked in.
Wanna hear a wild one about stability control? I was cruising 80 down the freeway in the caddy and heard a thud and felt a quick shudder that went away. Stability Enagaged showed on the dash - along with check tire pressure. STILL AT 80 - I rolled through the menu and saw RR Tire 0 PSI. It wasn't shaking, shuddering or vibrating so I lowered the mirror to see the RR and it looked okay - not flat so I figured I hit a pot hole and had malfunction of the sender and continued another 12 miles. As I slowed below 40 coming into Waco the back end felt "light" so I hung a right onto a side street. As I came to a stop the tire started shaking as a flat. There was a hole I could put my fist through on the inner sidewall.
The stabilitrac (which uses hydraulics to alter the "center point" of the struts systems) adapted to the blowout by adding weight to the LR and taking it off the RR - I was three wheelin! The only downside I can see is that if I had continued on (and I can picture many an idiot doing just that - lol)- the tread would have peeled and beat the crap outta my car (as it was the sidewalls were smoking even after I pulled the tire off). But for safety? I am SOLD on ESC (even Chryslers lame version - comparatively).
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #7 of 12 Old 04-24-2013, 01:49 PM Thread Starter
HighandLow
HighandLow's Avatar
2010 JK Wrangler
Hmm.. Well now you have me curious. Toe is adjustable right? Sorry, All of the alignment specs are Greek to me. The stabilizer (?) bar in the very front of the steering set up, where the steering stabilizer connects is how thats adjusted right? The bar itself has some play. I can grab it and sorta rotate it up and down as the bushings have play. Normal?
post #8 of 12 Old 04-24-2013, 02:47 PM
jwmbishop
jwmbishop's Avatar
2011 JK Wrangler
The steering stabilizer connects to your tie rod. that should have some play (as you describe "twisting" but should not "flop" - the play should be firm. to check the ends, jack one wheel up and try to steer it left and right at the tire by hand - it should not move a whole lot (without also moving the grounded tire), you should not feel any clicking AND the tie rod should not be repeating that twisting motion. Then check ball joints (while still jacked up) by trying to rock the tire top to bottom - again no play and no clicky feel. Every good alignment shop I have worked with would not even proceed to align if it did not pass these two tests.
Looking at the alignment sheet your toe is in the good range for up to 35s. The sheet does not express it as inches in or out - but rather degrees of steer.
post #9 of 12 Old 04-24-2013, 03:15 PM
JTPhoto
JTPhoto's Avatar
Not having a reprogram for bigger tires will cause the TC to kick in sooner as the rotational differences between left and right side tires are increased.. Reprogramming for proper tire size will bring it back in line.
^^Jeff^^
post #10 of 12 Old 04-24-2013, 03:53 PM Thread Starter
HighandLow
HighandLow's Avatar
2010 JK Wrangler
Thank you very much for the replies. A programmer is on the short list.
Just got finished watching the first of Planmans tutorials. I'll probably need to watch them more than once to educated myself fully.
LOVE JEEPFORUM!
post #11 of 12 Old 04-25-2013, 07:06 AM
jkmatt11
2010 JK Wrangler
LOVE JEEPFORUM!
i had the same issue and it was not the stability control. it was indeed the first sign of my death wobble. it stopped all that when i replaced trac bar and drag link end at the pitman arm. it only happened when going down a certain hill turning to the left. i was like my rotors went from being good to shot but then good again. trac bar holes were wallowed out to 5/8 bad check it out sounds like the same issue.
jkmatt11 is offline
post #12 of 12 Old 04-25-2013, 03:49 PM Thread Starter
HighandLow
HighandLow's Avatar
2010 JK Wrangler
I'll check that out, Thank you!
